Question about Pfister VTP-E70W Kamato One-Piece Dual Flush Toilet
Water level adjustment
Can the pfister kamato e70w toilet be refitted with an old style flapper valve to control excessive water wastage ?
Go to an ACE hardware and talk to the plumbing dept sales representative. They will know.
Dec 16, 2016 | Home
How can I adjust the waterflow to a lower setting to make it 1.2 gallon flush from a 1989 3.5 gallon flush??
Keep in mind that if you limit the amount of water too much, the 3.5 gallon toilet will not flush properly.
This looks like an old Kohler Rialto toilet. The proper way to adjust the water level is to tighten down on the adjustment screw located on the very top of the fill valve. The fill valve is the the piece that the float ball screws into on the left side of the tank.
Tighten the screw down and flush the toilet. Wait for it to refill, and check the level. If you need less water, tighten again, let fill and check level.
There are also two old school methods to save water in your toilet. One is to put one or two bricks into your toilet tank. This reduces the amount of water that fills the tank. The second method is if the fill valve has a float ball on a metal rod, you can bend this rod down into the water. This makes the fill valve shut sooner. Don't bend too far or too fast because the chlorine in the water weakens the brass rod that the float ball attaches to.
Nov 29, 2016 | Home
Water leaking into bowl
I have the exact same problem with the pfister toilet.Anybody with ananswer??
Mar 14, 2014 | Pfister VTP-E70W Kamato One-Piece Dual...
When we flush the toilet there is never enought water left in the bowel after...do i get more water
Make sure the small toilet fill tube in the tank is still running into the tank overflow tube.
Jan 12, 2014 | Pfister VTP-E70W Kamato One-Piece Dual...
Needs two flushes to empty bowel
might be that the water level in the tank is to low. if both buttons release the same amount of water then you have to increase the water level in the tank by adjusting the height of the floater on the inlet valve. look inside the tank and there should be a WL mark meaning water level should be set to this level minimum.
Nov 30, 2013 | Pfister VTP-E70W Kamato One-Piece Dual...
Water level in bowl is too l;ow
There is a float in the back of the tank. It needs adjusted. I will explain more if you would like.
Jan 26, 2011 | Kohler Persuade Two-Piece Elongated Toilet...
Aquia II Dual Flush Toilet: toilet after flush removes to much water from bowl...
Adjust the float on the Fluid-master a little higher if possible. This should allow more water to enter the bowl after the flush.
May 16, 2010 | Toto Aquia II Dual Flush Toilet
Pfister VTP-E70W Kamato One-Piece Dual Flush Toilet Logo
187 people viewed this question
Top Pfister Home Experts
 perry tradesman    ...
perry tradesman ...
Level 1 Expert
Daryl Gleaton
shannon816
Are you a Pfister Home Expert? Answer questions, earn points and help others
