Question about LG Tone HBS-730 Bluetooth Stereo Headset - White Original OEM HBS-730
Where do you plug the charger - LG Tone HBS-730 Bluetooth Stereo Headset - White Original OEM HBS-730
How do you set up the chargers
You plug the small plug of the USB cable (OTG) into the OTG socket.
You plug the large USB plug into the charger.
Plug the charger into the wall socket.
Jun 16, 2014 | Kocaso MID-M750B MID-M750B 7-Inch Tablet...
No light comes on my charger when i plug in my new p103 battery into charger no 1423701?
does the outlet work that the charger is plugged into... is the battery completely dead and the charger can't see it... is the charger even plugged in... or is it even any good ???
Oct 23, 2013 | Ryobi Multi-Volt Battery Charger
Just replaced batteries and unit is operating good since i installed the battteries and i try to put on charger it says it is in the charge inhibit mode that is according to the flashing lights what does...
All that eans is that when you are charging the batteries you are unable to drive the chair. Its a safety feature to ensure that you won't accidently make the chair move with the charger plugged in. Just plug the charger into the charger port turn off the chair and then plug the charger into the wall charge overnight and in the morning unplug the charger from the wall and then from the joystick. Always have the charger off when plugging ang unplugging from the chair. With the M41 charger get a power strip with an on/off switch plug the charger into the strip and use the on/off switch to turn the charger on and off before you plug it into the chair Hope this helps you
Jun 20, 2011 | Electric Mobility Invacare Pronto M41...
When I plug in my Jet 3 Ultra 4500, it seems to charge - the charging lights come on - but it never charges. In fact, I can't get it to move at all, even when plugged in. I think I am using the...
when you plug in the charger do you get any amp reading on the meter located at the rear of the chair near where the charger cord plugs into the chair. When you plug in the cord the meter should deflect and read 6 amps or so. If you aren't getting any deflection of the amp meter then either the batteries are dead or the charger is bad. If you have a voltmeter you can set it to 200 volts dc and plug the leads into the charger port located under the front of the joystick Plug the leads into the 2 outter holes of the port with the charger plugged into the wall you should be reading 27-30 volts. Unplug the charger and you will be reading the battery voltage and fully charged they should read 25-27+ volts. If you aren't reading 25-27 volts without the charger plugged in you will need new batteries( anything less than 10 volts will not let the chair turn on) if you aren't getting 27-30 volts with the charger plugged in then the charger is bad and you can get or borrow an off-board charger and charge the chair thru the joystick port Hope this helps
May 07, 2011 | Jet 3 Ultra Power Chair
I need to know how to charge the batterie om my sisters merits wheelchair,i do not know how to plug it up,,or if the charger is located on the frame someplace or if its freestanding.plain and simple i do...
sking the off board charger is a 5 inch by 3 inch rectangular box with a power plug on one end and a round silver 3 prong plug on the other. The charger plugs into the charger port located under the front of the joystick. Plug the charger plug into the joystick and then into the wall socket. When it is fully charged the light on the chrager will turn from yellow to green. Unplug the power from the wall socket first then unplug from the joystick In ither words always have the charger unplugged when you plug the charger up to the chair Now if the chair has an onboard charger there should be a power cord that just plugs into the chair usually somewhere in the rear of the chair all you have to do is plug it into a wall socket and charge away Hope this helps you
Mar 10, 2011 | Electric Mobility Merits Electric...
Batteries won't charge, bought new batteries and they won't charge either
Moore well it looks like you have a charger problem. With a digital voltmeter plug the on-board charger into the wall then take the voltmeter and plug the two leads into the two outter plug holes of the charger port under the front of the joystick set the meter to 200 volts dc. with the charger plugged in you should read 26-30 volts if you don't get that you are reading just the current battery charge 20-24 volts. If you can try to find someone locally that has an offboard charger and borrow it for a few hours. Plug the offboard charger into the charger port under the front of the joystick and let it charge the new batteries. I would try to find someone with an extra charger you could buy or contact your local provider and have them get you an off board charger to charge your chair. Hope this helps you
Sep 23, 2010 | Jet 3 Ultra Power Chair
Hello, i have a invacare wheelchair that has 2 12v sealed batteries, wired in series at 24v. I wanted to find out the charge plug has 3 prongs, which should be -. ground, . over vice versa, how come there...
Salty The charger detects the batteries when it is plugged into the charger port. With the older chargers you could measure the output of the charger by measuring across the two outter pins. With the newer chargers there is no output until the charger is plugged into the charger port. Now on the M51 you should have an on-board charger and the cord plugs into the back of the chair into a three pronged plug. Now if you plug the on-board charger into the wall socket and look at the rear of the chair low to the ground you should be able to see a red and yellow light (red and green when fully charged). With this charger plugged in you can take a digital voltmeter set it on 200 v dc and plug the leads into the two outter holes in the charger port under the front of the joystick you should read 27-30 volts when charging and 24-27 volts fully charged and the charger unplugged. Hope this helps you
Sep 20, 2010 | Invacare Pronto M51 Power Wheelchair
How do I charge my scooter I have lost my instructions
Look in your manual if you lost it then, go to razor.com and request one. But the simple answer is to:
1. Turn off the scooter
2. Plug charger into wall outlet.
3. Find the hole on the side that matches the charger plug(not the wall outlet plug) .
4. Plug the charger into the scooter.
5. Wait until the charger turn off ( if the charger is a smart charger), typical charging time is 4-6hours.
*If not a smart charger you can calculate the charge time by using an online battery charging time calculator.
Jul 02, 2010 | Razor E100 Electric Scooter
Travel Pro Scooter charging problem. I plug in the charger there is no light indication on the charger when it is plugged into the scooter or when it is unplugged from the scooter. Batteries will not...
hi , sounds likek a charger problem but if you have tried another charger then check the charger plug connection where the charger plugs in,
Check the batteries are connected correctly.
Regards
GeWiz.
Jan 13, 2010 | RTO Mega Motion 3 Wheel Travel Pal Scooter
Have lost charger or the 2 prong adapter. Not sure as we have a 16 volt charger with single prong that may be for our light. Need to know what voltage required for the light to be sure.
According to the instruction manual for these swimming pool lights, the charger specifications are the following:
USA and CANADA: 14 VAC,1.5A UL/CSA-approved wall plug
adapter and charger
AUSTRALIA and NEW ZEALAND: 240VAC 50Hz/14VAC 1.5A wall
plug adapter and charger
EU: 220-240VAC 50Hz/14VAC 1.5A CE-approved wall plug
adapter and charger
SOUTH AFRICA: 220-240VAC 50Hz/14VAC 1.5A wall plug
adapter and charger
UK: 240VAC 50Hz/14VAC 1.5A CE-approved wall plug adapter
and charger
Aug 13, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
LG Tone HBS-730 Bluetooth Stereo Headset - White Original OEM HBS-730 Logo
11 people viewed this question
Top LG Radio Communications Experts
TO Lady
Computer Repairing
Computer Repairing
Michael Vincent Cruz
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
