Question about Microsoft Zune JS8-00001 Digital Media Player
Zune 30 LOCKED, LOCK SWITCH RIPPED OUT FROM INSIDE
Im trying to find out if i can completely unlock my zune 30 because the locking mechanism is completely broken. i ripped it out
  • 3 Answers
Plz the new parchase zune 3d locked
Posted on May 22, 2009
Im getting a "LO" error
The LO error code means the LID OPEN
Here is what the techicians service manual say to check
LO Door failed to unlock Door lock monitor switch does not indicate to the machine control board that the solenoid in the door lock mechanism retracted and unlock the door. 1.Check for debris inside inside the door lock mechanism, which may be jamming the lock solenoid. 2.check wire connections in harness leading from machine control board to door lock mechanism.
3.Check the door lock monitor switch for welded contacts.
4.Replace responsible component.
Jul 30, 2011 | Maytag Neptune MAH5500B Front Load Washer
Brand new 8g black Zune, the lock emblem is on, but the unlock switch is off, I have tried everything and it won't unlock. I've yet to find help from Zune website or anywhere.
Hi if the lock switch is stuck on hold and the lock switch is in the off position you will need to get the lock switch/head phone jack assemble replaced in your player.
If you need more help, parts or repair services you can go to my repair service web page at firehouse7777.weebly.com and find info to contact me if needed. thanks
Dec 25, 2010 | Microsoft Zune JS8-00001 Digital Media...
Lock problem (zune 30)
If it's a zune 30, it's just a glitch in the software timing and so you have to flick it back and forth until it works.
My zune does the same exact thing, it always has. So just bare with them (:
hoprfully microsoft will create a software or firmware update that help itt. (:
Mar 29, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune 30 gb broken "lock" button
The Lock button came right out and the wires attached to it broke, right? If so, y'alls pfft.
or, if not...
Go to this website and follow Steps 1 thru 4 ONLY. Picture 4 of Step 4 shows the top of the device to the left and the headphone jack nearest you. The Lock button should be right below the top arrow on the left of Picture 4. To unlock it, slide the switch **away** from the headphone jack.
!!! Please note that this is all strictly assumptions on my part. I have *never* taken my 30gig apart and am strictly working from the pics & past experience w/ micro-electronics. Do Not Take My Words As Being Absolutely Correct !!!
Mar 07, 2009 | Microsoft Zune JS8-00001 Digital Media...
Zune lock not working
Are you technically inclined? Nerves of steel, and great eyesight?
This webpage has details to open up your Zune. Up to Step Four (and Picture 4) ONLY! Picture 4 shows the spot where the Lock switch is, right below the upper arrow on the left side. Push the lock switch *away* from the headphone jack. Re-assemble.
!!! Operate at your own risk. Do not imbibe before picking up screwdriver. Do Not Trust Me as I have never opened my 30 gig Ever!!!
The pics & info look *fairly* straightforward, tho'.
Feb 17, 2009 | Microsoft Zune JS8-00001 Digital Media...
I can't unlock my Zune.
i had the same problem. my solution was easy since the circuitry of the zune is complex, i bought another motherboard & installed it & as soon as it was back together it fired right up, no problems! check out ebay for this piece. hope this helps.
Jan 19, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune lock and unlock button broke
I fixed mine without opening it up. Read what I did and see if it may help first.
Aug 01, 2008 | Microsoft Zune JS8-00001 Digital Media...
Broken lock switch zune Pink
My zune lock switch completely broke off in the locked position. I used a paper clip to remove the small plastic tray under where the switch use to be. It came off pretty easily. Then I could see a small black toggle switch can I was able to flick it in the unlock position.
Jun 17, 2008 | Microsoft Zune JS8-00001 Digital Media...
My Zune is Not responding
after much research on this matter in the past few hours. To resolve this situation don't shut the zune down by holding play/pause button it does not shut down properly that way.
Hold down the down & back button down until shuts off....zune recommends as the best way to turn off your zune. Also if you are having problems holding charge, a lot of people replaced the original charge plug and found that it worked again. these cables usually become faulty from previous models and 30gigs. So buy a new cable & shut it down correctly.
Still no worky??? Call zune, within 1 year they will accept it for repairs. They may even send you a new refurbished zune...since they no longer are making the 30 gig...probably for those reasons.
I hope this advice not only helps you but myself. Who wants an expensive paperweight...not I!
Dec 11, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Microsoft Zune JS8-00001 Digital Media Player Logo
182 people viewed this question
Top Microsoft Audio Players & Recorders Experts
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
