Question about Westinghouse Televison & Video
Tv stuck mute - Westinghouse Televison & Video
Targa Visionary LT 3220 television is stuck on mute. tried pressing mute button on remote but nothing happens.
Unplug the TV for 5 minutes and see if it clears. Is there a mute message icon on the TV screen (picture of a tiny speaker with a line through it)? It turns off anytime the volume control is touched automatically, so if that doesn't happen you have a problem with the TV itself.
Aug 18, 2016 | Televison & Video
Mute button not working and tv stuck on mute
See if you can can go on the TV direct to teh control panel and reset if it does not work check teh remote or you need to change teh censor on the TV that is the power setting are.
Oct 30, 2013 | Bush Televison & Video
Tv is stuck on mute and I do not have remote for it I do not know how to take it off mute
There should be +/- volume buttons on the TV somewhere (usually under the screen toward the center.)
These buttons, when pressed, should automatically override the Mute and restore sound to your TV.
You could also purchase a universal remote from a local wal-mart, Kmart, target, or other electronics dealers.
Jan 15, 2013 | Televison & Video
We lost sound on our Sansui TVD2798 even though the speakers work. Mute button has no effect. Using the remote, we can't find any option for sound off or on.
There usually is an option for turning off the internal speakers as part of the TV setup routine...BUT you may have had a failure of the internal audio in your TV. Your Zenith remote might have a MUTE button which turns off TV sound and displays a mute message or the MUTE buttton might have been pressed accidentally and has become stuck
Jan 08, 2013 | Sansui Televison & Video
Sony Bravia stuck in mute
The fault is with its main board itself. It will be best to get this set repaired by skilled technicians. This is not a user repairable one.
Aug 24, 2012 | Sony Televison & Video
I lost my remote and the tv is stuck on mute, how can i unmute it?
For now go to the tv manual control on the tv right the volume + - will get ur tv out of mute and work.Try Remotes.com to buy an exact or very close to the original remote.
Jun 21, 2010 | Sony V SERIES BRAVIA KLV40V300 40 in. LCD...
The sound/volume turned to mute automatically?
Assuming that you are using one, take the batteries out of the remote, then turn the sound up with the switches on the monitor. Tactile switches somethings get stuck. The mute switch could be one of them. If it is the one on the screen, check the "feel" of the mute button compared to the others. Damaged ones usually feel "flat".
Jul 18, 2017 | Computers & Internet
TV STUCK ON MUTE??????
You did not give a make and model for the TV so I can only offer a general solution. You may need to reset the sound board. This can be done simply by unplugging the TV for about 10 minutes.
Jun 22, 2009 | LG 42PX5D 42 in. Plasma HDTV
Akai TV volume control stuck on 100%
try leaving the set unplugged for several hours, this will reset it to factory settings. If this does not work you need service.
Jan 10, 2009 | Akai PT5492S 54" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
