Question about Boating
Evinrude lower unit diagram - Boating
3 Suggested Answers
  • 5546 Answers
SOURCE: 1975 75 hp evinrude water in lower unit
You could take off the lower unit and leave the boat home. All they need is the bottom. The propshaft seal can be cut from fishing line. There should be another seal on the shift assembly and a third on the powershaft. Some you could do, but the shop can pressure test before and replace only what you need. Then pressure test after the repair to verify it seals.
Posted on Jul 20, 2009
  • 46318 Answers
SOURCE: cannot get lower unit off my 1986 70 h.p.
have to disconnect the shift linkage below the carb
Posted on Jul 04, 2010
After running my johnson 4hp 2s for a couple of hours in the bay it starting giving a strange noise and then cut out.i managed to get it started again but coudnt get above half speed.
Hey Pete.. this sounds serious.... will it rev up while in neutral? If it revs freely and high.. the power head should be ok.. if it will NOT rev up freely and high.. STOP - you are causing more damage..
Check the compression with a good gauge..it should be 125psi minimum.. with no more than 10 psi difference between any two cylinders.. DO this WITH the THROTTLE WIDE OPEN...
Can you turn the propeller by hand while it is in neutral?..Of not.. this is the problem.
Shop Evinrude Outboard Parts Johnson Outboard Parts
Lower Unit Replacement Rebuilt Lower Units Aftermarket Lower Units
REMANUFACTURED LOWER UNITS
https://www.boatengine.com/lower-units/remanufacture
Refurbished Lower Units for Yamaha Mercury OMC Johnson Evinrude
Jul 09, 2017 | Cars & Trucks
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views ยท 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
I HAVE A 1978 EVENRUDE 35 HP NO FIRE TO THE PLUGS GREAT COMPRESSION???
evinrude 1978 -1979 have a capacity discharge ignition unit as the control for the spark system
it runs wires to an ignition coil
so I would be suspicious of that unit
check all connections for corrosion and bad connections
I typed in electrical schematics for 1978 evinrude out board engine and found a site --www.maxrules.com which in the list of schematics has 55hp 1977-1978
press on that and you get a schematics of the wiring diagram evinrude 1978-1979 55hp
now I am aware that you state that yours is 35 hp but if it has 2 cylinders then it is a fair bet that the wiring diagram will be the same
any way there are plenty of other sites that may be of benefit
Nov 26, 2015 | Boating
Diagram of the parts and seal to lower unit to a 1989 200 xp evinrude
time for a trip to the dealer they have microfiche of them
May 22, 2014 | Boating
Evinrude diagrams
This is quite normal,may have been blocked before
Mar 08, 2014 | Boating
Evinrude troubleshooting
check lower unit oil if ok . pull prop off see if it has a wod of string around the input shaft behind prop sounds to me its in a bind
Nov 19, 2013 | Boating
Will a 1973 50 hp Evinrude OMC lower unit fit on a 1988 evinrude 50 hp
Tony, that's a problem for the boat motor repair section.
Nov 02, 2013 | Vacuums
Trying to get lower unit off a 88 25hp evinrude motor
www.youtube.com go there and type water pump replacement 25hp Johnson or evinrude. You can also go to
http://shop2.evinrude.com/Index.aspx?s1=gett3uheq5c0nce2mjg11d1eh0&catalog_id=0&siteid=1
Thank you, Lewis Hot Headz Marine
Sep 25, 2013 | Boating
How to replace impeller on evinrude 115
disconnect the lower unit from the power head . makeing sure where the shift rod position is . then you will be getting near the water pump impeller .if you get it wrong the shifting won't work
Apr 24, 2010 | Boating
Jul 20, 2009 | Boating
Boating Logo
106 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
