Check phone line - Computers & Internet
Really bad crackling sound on certain calls
if only happens on certain calls it could either be the handset itself, a week point on all corded phones is the cable between the handset and the body of the phone. whilst talking to someone on a call wiggle the cord where it enters the handset, does it crackle if not do the same where the cord enters the phone body, if no crackle likely not phone.
next select a line if you have more than 1 line note which 1 and dial 17070. this will BT autotest the line. if more than 1 line on system do same for all lines. check with your system admin if there are quick codes to select individual lines, eg dial 9 for any line or 81 for line 1 82 for line 2 etc .
if you get crackle still on 1 of the lines get your maintainer to check the lione at the cable head where lines enter building
Mar 02, 2015 | Panasonic KX-T7731 Corded Phone
Tip
Troubleshooting for modem.
Problem:-
User's modem does not dial or does not connect.
Tip:-
Prove that computer is connected with phone line and check that phone line contains dial tone.Therefor check that connection is connect or not.
  • Connection may not be less than six feet (1.8 meter).
  • Check dial tone by plug in the phone in phone jack.
  • If user has many more services (such as call waiting,call messaging OR voice mail) then check that these all are cleared or not and check call waiting is disabled while using modem.
  • Disconnect any answering machine,fax machine or printer which are on line with modem.
  • Check that are you not using digital,rollover or PBX line?These type of lines not works with modem.
  • Try with another phone line. (For this, you have another phone number or another phone line).If user connected with another line then you need to complain in phone company.
  • Try to connect modem with low connection speed.
on Apr 13, 2010 | Computers & Internet
Tip
How to Check main causes of Hissing Noise on phone line ?
The main causes of Hissing Noise on phone line
* Weather:
Precipitation can leak into phone lines and cause disruptions. Lightning, even at a distance, can damage the connection.
Checked the connections the cable and the Sockets
If you have the Test socket or the First Socket where the Telephone is is entering .. check the Connections there
* Electrical interference:
Check the Power lines,
Check radio or television transmitters, transformers and other electronic devices may causing noise on the phone line.
* Other phone devices:
Check for the Connection to the FAX check by unpluging the FAX Machine or answering machines,
Disconnect the other phones and line splitters --
Disconnect the Splitters or devices that allow two phones to fit on one phone jack -- can cause phone line noise.
* DSL services:
The high-frequency signals coming from DSL (digital subscriber line) devices sharing the phone line can create problems for other technology connected to the line.
***Note : high-frequency signals coming from DSL helps for FAST Internet Connection speed which sometime cause the problem to the Phone or Voice signals for this need to contact to ISP to check the Voice margin .. that may effect your internet Speed
IF the above wont work..
You can try keeping the device near Heater .. it could be the Moisture which might causing this issue
or
Show the Device to the Service provider to repair it
on Jan 22, 2010 | Cell Phones
Check line cord phone mean
The cord or cable connecting the phone to your pstn line is called line cord. check the connection at the back of phone and the wall jack. if it is ok change the cord and check.
Jul 20, 2013 | British Telecom Synergy 2110 Cordless...
HP LaserJet 3055 .fax not working
Direct Line:
1.Check telephone line.2.Make sure telephone line is connected in line in port not in extension.3.connect extension telephone phone to the device & check for the dial tone.
Dial the number and observe weather extension phone is ringing?
A. *If extension phone is ringing check display is there any message like "ringing".. wait till fax tone comes,if not check "basic fax settings"... if setting are OK .. Replace formatter
B. *Extension phone is ringing no message displayed on device replace "LIU" card..
If extension telephone is not ringing check telephone line..
No out going faxess:
*Check line is connected though EPABX , if connected Check..prefix setting..
*Check out going..
Best of luck...
Sep 06, 2011 | HP LaserJet 3055 All-In-One Printer
Display check phone line
Either your phone line is dead or your base station is not plugged in correctly (or broken). Buy a cheap non-wireless phone and check the phone jack. If that phone works your Panasonic was had the line plugged in correctly you need to buy a new phone. If not you need to call your phone company and get a repair scheduled. Note, the phone company will charge to repair phone lines if they are damaged inside your house.
Apr 22, 2011 | Panasonic KX-TG5632 Phone
Comm error 345 ? What does it mean?
Check phone line. use a normal phone and plug into the same phone wall socket that the MFP is using, do we have a dial tone? Do we have a noisy line, any buzz or crackel will cause issues if there is no dial tone ring line supplier, If it is noisy line do the same
Also check phone line is plug into "line" socket in the back of machine not "ext'
Also check no prefix is required to dial out, unit needs its own phone line..
Also try using resolution of fax as standard not fine, this requires less info to go threw the line
Mar 10, 2011 | HP Laserjet CM2320nf All-In-One Color...
Phone lines are flashing making a loud beeping noise. The screen is texting funny words. Phone is ringing with ambulance style ring before the normal tone
The phone doesn't like something it's sharing a line with.
First, check to see if the extension number on each phone is different. You may have two extension 11's.
Next, check that line 1 is line 1 one all of the phones, then line 2 is line 2 etc. If one phone has line line 1 showing up on line 2 then you may have wires crossed somewhere. Or if you pick up a line on phone one and line 2 goes red on one of the other phones you have wires crossed.
Last, check in the plugs to make sure the connections are straight. Sometimes when a phone plug is inserted the pins cross and short two lines together.
Mar 18, 2010 | Panasonic KX-T7730 Corded Phone
Constant static and noise on the cordless, have not had this problem with other phones in the same location. I have tried the frequency scan- no difference. The noise is so bad the cordless cannot be used.
* Weather:
* DSL services:
or
Jan 22, 2010 | GE Telephone pr521w
Canon s 35
Some things to check are these.
1 Make sure your phone line is plugged into the Line slot and not the slot for a phone or answering machine.
2. Make sure the machine ECM mode is ON.
3. Make sure Secure Recieve is OFF.
4. Make sure the JUNK MAIL feature is OFF.
There also may be a memory reset procedure for you fax machine to clear and reset the memory.
There is a slight chance that your problem is the phone line. if you have a phone to plug into it, check for static on your phone line.
You can also try replacing the cord from the phone jack to the machine, they get noisy and cause problems at times.
Other phone line issues may be low line voltage, low line current and DB loss, that has to be checked by the phone company.
Dec 11, 2007 | Office Equipment & Supplies
Computers & Internet Logo
David Payne
David Payne
