Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool washer LHA780 drains very very slowly
Seems to go thru all the cycles will not drain. Top loader closed lid will spin
  • Anonymous May 24, 2009
    washer not draining all the way and not spinning fast
  • john170 May 11, 2010
    It sounds like the pump is broken. You say it drains slowly, then you say it doesnt drain. If it is draining slowly, your pump is likely partially clogged with lint buildup or other debris. The only way to tell is to remove and inspect the pump.
    Sergeant:
    Champion:
  • 214 Answers
You will need to remove the hose from the pump to drain and also from pump to tub.Make sure there is no obstruction in the hoses.You may want to look in the pump also.Hopr i fixya :)
Posted on May 22, 2009
Why won't my whirlpool model #LSR8233JQ0 go through the rinse cycle or the spin cycle
i have no info on this model, but if its a front loader then you will be looking at your drain pump motor as at the start of the rinse and spin cycles it will need to drain if it cannot it will not even attempt to continue on, so take that little drain pump cover off and have a look inside the propeller it may just be jammed up, if not it may be blocked somewhere along the hose or just a faulty pump altogether, if its a top loader you will be looking for the same thing but if it isn't the pump it will be the lid switch that senses the lid has been shut as all whirlpool top loaders must be able to activate the lid switch or else it cant spin (simply a safety feature to prevent injury), get back to me if you have any questions
Nov 21, 2011 | Whirlpool Washing Machines
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Water doesn't drain
1) Be sure the drain hose isn’t kinked.
2) Check the tab on the lid that strikes the lid switch; if it is broken, the washer may stop during the drain cycle. Press and release the lid switch. If it doesn’t click each time you do this, it’s probably broken. If you’re experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repairperson.
3) The water pump may be broken or clogged with a small article of clothing, or the controls may be broken;
Feb 25, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
sounds as if you have a lid lick/door switch issue, the machine is not recognizing the door being closed and for safety reasons will not enter spin/drain.. open anc\d close lid a few times slowly, cam you hear a "clicking noise" whe njust about closed?? id assume not replace teh lidswitch
Jan 21, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Whirlpool Washing Machine that doesn't complete the cycles
I too have a whirlpool top load and it did the same thing. I would put a load in and go back and the clothes were sitting in water. I found that if you close the lid and press gently til you hear a click, it will finish the cycle. So now when I load the washer, I press the lid like that and I have not had the problem since. I hope this helps.
Jan 20, 2009 | Whirlpool GR399LXHS Electric Kitchen Range
Washer will wash and drain but not spin
Sounds like the lid switch is not working.It is a safety feature to prevent the washer from spinning if the lid is open.If you look a the lid,you will see a small point that sticks out,The switch is locate under the rim,right where that point would contact with lid closed.
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool LSQ8543JQ1, washer stopped full of water, will not start back up, seems like no power to it, check fuse box and everything else that is running of same.
Pretty much exactly what guest above me said. I have a lsq8543jq1 also, was stopping after agitation.
At first thought it was something more serious, since the dial seemed to make a humming/grinding/buzzing noise when it was switching to agitation cycle, but that seems to just be a timer before the drain/spin cycle kicks in.
I had a washer full of water, so rather than wait till I could get a part (or hand drain -what a pain), I just grabbed a paper clip and rigged the switch so it thinks the door is shut and voila, drains and finishing cycle as I type.
The switch is a safety device to prevent accidents; bad injuries could result if the door is opened while the washer is in spin cycle. I don't recommend this as a long term solution - especially if you have kids. I have 2 and will be ordering the new part asap.
Apr 06, 2008 | Washing Machines
Drain/Spin won't work unless lid is lifted up
Curdy, it almost sounds like your lid switch is loose or fractured and the lid actuator is not making the switch. Check this out first and post back...Catriver.
Oct 19, 2006 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
