Question about Pioneer Audio Players & Recorders
What two buttons do I hold to reset sx319v receiver
I Have The ONKYO TX-SR603X receiver ALL BY ITSELF I NEED HELP RESETTING IT
Hello, please see the procedure below to reset the receiver
Resetting the AV receiver to its factory defaults To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VIDEO 1] button, press the [STANDBY/ON] button. "CLEAR" will appear on the display and the AV receiver will enter Standby mode
Apr 26, 2017 | Onkyo Audio Players & Recorders
How do you reset the system.
To reset the component Hi-Fi stereo system to factory settings.
  1. On the stereo system, on DECK B , press and hold the STOP button.
  2. While holding the STOP button, press and hold the TUNER ENTER button.
  3. While holding the STOP button and TUNER ENTER button, press the POWER button.
  4. Unplug the power cord from the electrical wall outlet.
  5. Plug the power cord back into the electrical wall outlet.
  6. Turn on the stereo system.
Sep 30, 2014 | Sony STR-DA3000ES Receiver
How too reset pioneer 4800
Check page 69 of the manual :
Resetting the main unit
Use this procedure to reset all the receiver's
settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the BAND button,
press and hold the STANDBY/ON button
for about two seconds.
3 When you see RESET? appear in the
display, press 'AUTO SURROUND/STREAM
DIRECT'.
OK? shows in the display.
4 Press 'STEREO/A.L.C.' to confirm.
OK appears in the display to indicate that the
receiver has been reset to the factory settings.
http://www.pioneerelectronics.com/StaticFiles/Manuals/Home/VSX-819H_OperatingInstructions0508.pdf
Jun 15, 2014 | Pioneer VSX-819H-K A/V Receiver
How to reset pioneer vsx-819h
http://audio.manualsonline.com/manuals/mfg/pioneer/vsx819hk.html
It's in the manual. Page 12.
Resetting the Main Unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front panel controls to do this.
2 While holding down the BAND button, press and hold the STANDBY/ON button for about two seconds.
3 When you see RESET? appear in the display, press AUTO SURROUND/STREAM DIRECT.
4 Press STEREO/A.L.C to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory settings.
Sep 08, 2011 | Pioneer VSX-819H-K A/V Receiver
How do I reset my yamaha receiver htr5730
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Page 52
1 Hold down STEREO on the Front Panel
"Factory Preset" appears on the front panel
2 Press STEREO to select the desired setting.
'Reset' To reset to factory presets
'Cancel' to cancel without making changes
3 Press STANDBY/ON to confirm your selection
Jan 15, 2011 | Yamaha HTR-5730 Receiver
My tom tom is over 2years. I am not getting a signal. Asks if I am in a building
Mainly the problem with this tom tom one is that it comes up with this problem frequently. The solution to this problem is for you to reset your tom tom by holding the reset button for a while, after doing that, it will reset it and it will be able to receive signals.
Solution: Reset the tom tom by holding down the reset button for a while, it will reset it and then it will be able to receive signals once again. To reset: check that your battery is properly charged, by plugging it for at least two hours, make sure the charging light is on. Then you press and hold the power on/off button for about 15 seconds, then it will restart the system for you.
Be sure to have your tom tom in a car or in a outside position where it can receive signals from the satellite.
This should do the job.
Dec 22, 2010 | Tomtom ONE GPS Receiver
Flashing Red MCACC Light
hold the tune down (-) button and multi zone on/off button for two seconds then receiver should reset on the VSX-1019AHK model!!!
May 22, 2010 | Pioneer VSX-1019AHK A/V receiver
I accidently set my tom tom sat nav in foreign mode and I dont know how to get out of it. Please help
try to reset ..
1) Press and HOLD power button
2) While holding power button, press in RESET button
3) While still holding power button, release RESET button
4) Continue holding power button, you should see TomTom reboot
Oct 12, 2009 | Tomtom One XL GPS Receiver
Amp err
Same problem here VSX-916 AMP ERR
Jan 28, 2009 | Pioneer VSX-D912 Receiver
Pioneer Receiver will not come on
press and hold the enter button on the amp then hold the power button down whilst holding the enter button still do this for about 10 seconds then it should reset its self
Apr 29, 2007 | Pioneer VSX-D411 Receiver
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
