Question about Radio Communications
Bluetooth yes i purchased a bluetooth headset from big lots today an i was wondering how i could activate it to my nextel ic502 walkie talkie
msmichalko
  • 17 Answers
SOURCE: motorola talkabout ta288 walkie takie
http://www.theusermanualsite.com/manuals/mfg/motorola/motorola_twoway_radio_product_list_4.html
You will find the manual here. The radio is part of the 280 series radios, so there is a general manual on all in that series.
Posted on Jan 09, 2008
eradiostore
  • 1654 Answers
SOURCE: Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press
MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either
+ or to turn On or Off.
3. Press the PTT to confirm or
MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
Posted on Oct 23, 2008
SOURCE: binatone MR 250 walkie talkie is locked how do i unlock it?
Try holding down the ENTER button
Posted on Jan 13, 2009
  • 18 Answers
SOURCE: Instruction manual ?
Here is the link for manuals:
http://www.midlandradio.com/owners_manuals.asp
Posted on Feb 04, 2009
  • 4 Answers
SOURCE: walkie talkie symbol stuck on cannot remove it
In order to reset the radio, power on while pressing both volume buttons (+ and -) together with the PTT (speak) button, until you year a high-pitched tone.
But I have found that the "stuck on receive" problem is related to the battery voltage: non-rechargable AAA or incorrectly charged batteries can give 0.2-1.0V above the nominal voltage. Try to leave the radio open for a few hours or replace some of the four AAA batteries with slightly exhausted ones and see if that helps.
Posted on Sep 19, 2012
The walkie talkies work fine, but they do not work with the headsets on. They came with headsets.
Three thoughts: You could be plugging in your headsets with the radios turned on, or your headsets are not fully plugged in all the way, or you have a VOX (voice activation setting) set incorrectly. Note: With any audio device the radio should be turned off when plugging in or unplugging. When audio jacks are new sometimes it is difficult to get the plug pushed in all the way. Feel for a slight click to know your plug is completely in the jack.
Jul 19, 2015 | Walkie Talkies Radio Communications
Want to know how to make old nextell / boost Mobil phone walkey talkey or chirrup work for free
Yes it is free, You should have a walkie-talkie ID number. Friends of your walkie talkie also have ID numbers install number to Your contacts scroll down on contact to (Options)D C. From there follow directions try to make a walkie talkie contact by pressing the side (PTT) or push to talk button , It a cinch. This may only work 4 sprint
Jan 22, 2013 | Cell Phones
Why wont my boost sim card work in a nextel phone
you either have to do a factory reset on the phone or the previous owner of the phone (assuming there was one) has to release the phone or request a bill by calling nextel
Jul 31, 2009 | Nextel i930/i920/i870 Stereo Headset [OEM]...
What is the use of push to talk how can we acess it
Push to talk is a kind of wireless service provided by the service provider.You might have to activate it for some charge said by the provider.Once activated, your phone becomes a walky talky that can detect around 200mts of another walky talky around.Hope this answers your question.Please do rate my solution.Thank you.
Sunny
Apr 06, 2009 | Nokia Consumer Headset
Voice activation
The Motorola T-5000R does not have VOX capabilties. Page 23 in the manual explains this.
Here is the Link: http://www.giantintl.com/ContentManage/manuals/Moto/T55xx.pdf
HiTech Wireless
Mar 18, 2009 | Motorola Walkie Talkie 2-Way Radio
Cellphones with walkie-talkie features
Nextel uses WIDEN (network) for most two-way communication. Some, if not all, have DirecTalk. This is a feature which allows communication as a short range radio allowing everyone on your channel in the same mode to hear you.
Nov 06, 2008 | Motorola Walkie Talkie 2-Way Radio
Unlock codes
You may need to purchase a new sim card for it to be compatible with your nextel phones BUT it won't hurt to call customer service and try to activate that sim card under the ic902's serial number. Because your ic902 is also a sprint phone it works off of a different network and will need programming. Customer service will be able to activate your phone and give you the info needed to get your phone up and running.
Oct 20, 2008 | Motorola Mobility i870 Cellular Phone
Nextel i850 can't receive calls
  • may be the walkie talkie can recieve signals only to an certain distance,so it may be due to the signal problem........
  • if the reciever is beyond the permitted distance it loose its frequency...........
  • or else the person who is calling walkie talkie might not hav signal in that area.....
  • and if the walkie talkie does not recieve any signal then the receiver component present inside the walkie talkie might be damaged.........
  • and if it does not reply to an signal transmitter might be damaged..........
  • i hope my answer would be sufficient for u.....thank u......
Sep 10, 2008 | Motorola Mobility i850 Cellular Phone
Blue tooth not transmitting to caller
Did you check that you didn't by mistake activate mute? Also, check that there is nothing obstructing the microphone hole on the headset.
If it is indeed on mute. Press both volume buttons at the same time you will hear two descending audio tones.
Jan 08, 2008 | Motorola Mobility H500 Wireless Headset
Walkie-Talkie wont work and the Outside buttons wont work.
This is called the PTT buttons Back housing assembly: Open your phone make sure the wire is attached correctly: If the wire is attached correctly you need a new back housing. www.cdphonehome.com Nextel Repair Parts
Oct 30, 2006 | Nextel i860
Radio Communications Logo
43 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
