Question about Home
I have a caroma Reba ware toilet that continues to leak water into the bowl It looks like the float won't cut off the water Please help
2 Suggested Answers
  • 396 Answers
SOURCE: Water leakes continually into the toilet bowl from
the flapper is not sealing or the water level is set to high and you will need to lower the float. you will not need any parts to adjust the water level and the flapper is under $10.00. Click on the bellow link to see the parts diagram. http://www.google.com/imgres?imgurl=http://www.hometips.com/articleimages/20070913131246_plb_toilet_componentsdiagram1.gif&imgrefurl=http://www.hometips.com/how-it-works/toilet-plumbing-diagram.html&h=428&w=353&sz=34&tbnid=-jD50OHr-goZAM:&tbnh=247&tbnw=204&prev=/images%3Fq%3Dhow%2Ba%2Btoilet%2Bworks%2Bdiagram&hl=en&usg=__WY8gJuebzTLRKmtC489ClS9UH3s=&sa=X&ei=AikpTJXJHIK0lQf66vSCCA&ved=0CBsQ9QEwAA
Posted on Jun 28, 2010
When toilet is flushed and refills water leaks into the cistern.
Are you saying that water is running into the toilet bowl? If so, check the rubber flapper at the bottom, and the valve (tube standing up).
Mar 29, 2016 | Caroma Home
Caroma toilets repair
have to know whether you mean water is flowing into the bowl?, or "over-filling" the tank? Could either be a bad flapper(More common), or the "fill-valve" is leaking.
Aug 24, 2014 | Home
Caroma toilet 12years old, concealed cistern. Water leaking around base when toilet is flushed. water level maintained when not flushing, so the leak must be between the cistern and the bowl. Had a plumber...
Fixing a leaky toilet is actually rather simple, requiring few tools and just a little time and effort. In looking at Caroma toilets on Google, they appear to be just a standard type of unit, and should present few if any problems for yourself or any handyman of modest skill.
If it is leaking around the base of the toilet - where the toilet sits on the floor, the repair item is a simple wax seal. Here is a tutorial to effect this repair: Replace Toilet Wax Ring. The wax ring is very inexpensive, usually $5 to $10 USD.
If the water is leaking from between the tank (cistern) and the toilet bowl, the job is even easier, as it does not require lifting and moving the entire toilet. A good tutorial for that repair is here: How to Replace Tank to Bowl Gasket . The gaskets, new nuts, bolts and rubber seals come in a kit and also cost only $5 to $10 USD.
I am sorry to hear your Plumber insisted you buy an entire new toilet, but do remember he is in the business of making money!
Jan 28, 2014 | Home
What would cause the water in the bowl to leak down to a little water left in bowl after flushing?
The float is stuck and the flapper leaks. Adjust the float so it won't touch anything, it needs to move up and down freely. Replace the flapper,
Sep 12, 2011 | AMERICAN STANDARD BOWL Elongated Bowl...
I have a dual flush corona and there is a stream of water leaking into the bowl. It periodically has to continue to fill when it gets low. I have replaced the round seal inside the tank at the very bottom....
There should be a float inside the tank of the toilet. Be sure that when the tank fills that the float is not getting stuck, or not floating all the way up and not sealing the flush valve at the bottom of the tank.
Apr 05, 2011 | Caroma CARAVELLE270ADAW-EL Caravelle...
Water runs after it fills up?
I am not familiar with that model, but it sounds like your fill valve is leaking or the water level in the tank is too high. Take the toilet tank top off and flush the toilet. When the water gets full and you hear the water stop ( except for your leak) look at the flush valve. Is water running over the top of it and running into the hole in the middle? Then the float need adjustment.
If you are hearing you leak still, lift up on the float. Did it stop? if so the valve may need adjustment due to it not seating completely. You can probably find something online (youtube) easier than I can explain it.
Sep 08, 2010 | Caroma 270W-RF Reflection Round Front...
Hi, i have a caroma duel flush toilet possibly 10 years old, it is leaking into the bowl and then constantly re filling, i replaced the washer/ring/ thing at the point where the water exits into the bowl...
First make sure it is not overfilling. The water level must stop before it reaches the overflow pipe. If it continues to run it will overflow into the bowl and continue to run. Adjust the fill level to the mark inside the tank. Make sure nothing is getting under the flapper and holding it open. You replaced the flapper so we know that is not the problem. Just make sure the flapper is centered on the drain hole.
Jan 09, 2010 | Caroma 270W-RF Reflection Round Front...
After flushing, the water slowly leaks into the bowl
It's suppose to do that. The internal P-trap has to be reprimed everytime it is flushed.
Nov 08, 2009 | Caroma toilet - water saving Elonged...
Home Logo
49 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
