Question about Jandy Laars Lt 250,000 Btu Heater
Pool heater not heating water - don't know model number
I have just lit the teledyne (12 yr old) pool heater at a house I recently bought in UK - have no previous experience of this unit. After three hours the boiler is very hot (too hot to touch some parts of panels) but the outlet pipe is not much warmer to touch than the inlet pipe though I know that water is circulating. Is that right or is there some internal bypass possible that is failing to pass the heat into the circulated water? HELP PLEASE!
    Top Expert:
  • Jandy Master
  • 8,143 Answers
Sounds like manual bypass spring broken or weak remove inspect if ok see if you have valve bypass should only be open half way or close all the way
Posted on Jan 30, 2016
5 Suggested Answers
  • 5 Answers
SOURCE: I have Jandy RS4 system with 4-button poolside
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Posted on Oct 09, 2009
  • 246 Answers
SOURCE: My TELEDYNE LAARS Boiler hammers when the main
the hammer is due to boiling inside some one has been messing with the safety controls or water to slow or no flow at all
Posted on Oct 15, 2009
  • 10 Answers
SOURCE: I have a Jandy Laars LX Pool/Spa Heater...when I
If the unit is lighting then shutting off then repeating it isn't rectifying, means not sensing the flame. May have a bad flame sensor or ignition control. I'm guessing your AGS is indicated on the GUI also.
Posted on Mar 07, 2010
  • 990 Answers
SOURCE: I have a Jandy Lite
This sounds very much like spider webs in the gas orfaces. If you shut the power off and remove the wires to the gas valve then shut the gas down and remove the fed pipe from the gas valve you should be able to pull the burner tray out of the heater. Now if you remove the burners you should be able to remove the brass orfaces connected to the main gas feed pipe. If you use an air hose or a can of compressed air you can blow this out now. Now take the orfaces you removed and clean them with a tooth pick or a small piece of wire. The webs will look like small cotton balls or lint. They don't stop the gas they just slow it or disperse it and keep it from firing clean and evenly.
At this point you can reassemble the tray and install. This should fix your problem.
Posted on Nov 14, 2010
Teledyne laars model #LLD400N nat gas input 999,000 btu"s everything fires up...just no heat.
check for the manual bypass if closed water passes through to fast and doesn't heat if open water bypasses heater and heater starts to shake then shuts off
Jan 26, 2011 | Teledyne Laars Pool & Spa
Pool heater stays lit for approx. 30 seconds then shuts off. pilot stays lit whole time but burners wont stay lit. water flow is good
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
Jun 02, 2010 | Teledyne Laars Laars Lx Pool Heater /...
Pool heater will not stay lit
Miles
Apr 05, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot will light but heater will not ignight
You may need to replace the Ignition Module. Have someone check to see if it is sending power. I have the same problem and need to replace the Fenwal automatic ignition system. The part cost $390 - check inside the heater for the model #
Jul 16, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Heater comes on but getting cold water in pool return, heater is 7 years old never had problem before!
if you have a two speed pump,try it at slower speed to keep water in heat exchanger longer
Jun 20, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Starting a teledyne laars heater
check for proper millivolt reading( 400-600).it could be 20 different problems and/or components
Jun 15, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Jandy Laars Lt 250,000 Btu Heater Logo
169 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
