Question about GPS
Garmin nuvi 350 reset pin number - GPS
SOURCE: garmin nuvi 350
Heres what to do:
- Connect to computer using USB cable
- Flip up antenna and hit reset button.
- The unit should power up.
- Then put unit on wall charge to get a full charge.
That should do it if not call 1-800 800 1020.
Posted on Jan 07, 2008
sharcnet
  • 2130 Answers
SOURCE: nuvi 350 on off problems
This is a common problem with the Nuvi series. The on/off switch is a surface mount switch that is mounted vertically off of the main PC board.
The problem is, that there is no support behind the switch, so when you press down the button, the solder leads of the switch are stressed and eventually break off the main PC board. This is a design flaw and could have been easily prevented by wedging a small piece of plastic between the rear of the switch and the SD card housing to give the switch support.
Also, the solder pads for the mechanical connections of the switch could have been made bigger, allowing for more surface area and more solder application.
I have repaired many of these before and I'll be posting a step-by-step procedure on how to fix this and prevent it from happening again.
I must point out however, that in order to make this repair, you will need to have skills in dissassembly and soldering.
Also, please only attempt this procedure if your unit is out of warranty.
If you would like for me to repair your GPS, please email me at KS3R at sharc dot net.
- Jim
Posted on Jun 25, 2008
sharcnet
  • 2130 Answers
SOURCE: Garmin nuvi 300 asking for pin number
You only have (2) solutions:
1. Take the unit to where the secure location where the PIN was set and it will not ask your for the PIN. Then you can delete it or change it.
2. The PIN is located in non-volatile memory and can not be reset except by the factory.
Attention FIxya: Any other solution promotes hacking. The above options are from the user manual.
- Jim
Posted on Oct 06, 2008
  • 3 Answers
SOURCE: garmin nuvi 650 unlocking
If you are the legitimate owner, you can send your unit back to Garmin to be unlocked. Be prepared to provide rock-solid proof of ownership because Garmin has a program that prevents stolen units from ever working again. It's one of the reasons that I purchased it. As word gets out that you cannot unlock a stolen unit, thieves will be deterred from stealing them in the first place. And if you try to open the unit to see if there is any easy jumper or something, you will permanently destroy it.
Posted on Mar 14, 2009
SOURCE: how to reset my gps device
Steps to fully reseting Your Garmin nuvi
1:remove sticker located at bottom
2. There should be a reset button located to the far right.
3. Hold down the reset button ( at the same time push the power button to the left) hold these for 10 seconds.
Posted on May 27, 2009
Garmin nui 350 Tried everything. My brother-in-law past away recently and dont no his pin # . is it possiable to reset and use garwin ?
Going back to the security location will unlock the unit but in order to reset the pin code, the original pin code must be input.
To unlock the unit, it must be sent back to Garmin.
Aug 21, 2011 | Garmin nuvi 350 GPS Receiver
How do I reset the pin without being at the secure location on the garmin nuvi 350
The unit can not be reset without knowing the pin code used to activate the security feature.
The unit must be sent back to Garmin to have it reset.
Mar 30, 2011 | Garmin nuvi 350 GPS Receiver
How do i unlock a nuvi 350 without a pin....
Take the unit to the location at which you first set the PIN. This is your Security Location. The unit will unlock and you can reset the PIN.
Sep 12, 2010 | Garmin Nuvi 350 Car GPS Receiver
I bought a garmin nuvi 350 at a flea
Take it back and get your money back, as it is probably stolen. The PIN cannot be broken as it is set by the original user and cannot be reset by a third party. Even Garmin will not reset it without the original receipt from a Garmin dealer.
Nov 22, 2009 | Garmin nuvi 350 GPS Receiver
Okay when i went to turn on my Garmin nuvi 260 it ask me for a pin or password and i forgot it. Then it says to go to your safe location and i dont remember if i set one of those. So how do i unlock it?
Your safe location is where you entered the PIN number (probably your driveway). If it still won't unlock, send it to Garmin with your original receipt from an authorized Garmin dealer and they will reset it for you. There is no master unlock for the Garmin units, it must be reset by Garmin.
Oct 12, 2009 | Garmin nuvi 350 GPS Receiver
I forget my pin number and i can't open the screen
Go to your secure location (safe zone),
the pin will not be on it then.
or if you didn't set it or don't know it,
Garmin Repair's only.
Regards.
Jun 26, 2009 | Garmin Nuvi 350 Car GPS Receiver
Unlock code for my garmin nuvi 350
Unfortunately, even if you perform master reset on Garmin GPS unit, it does not reset Garmin Lock security feature, which password-protect most Garmin electronic devices to deter theft. If you forget the PIN or password unlock code to unlock the Garmin unit, the best solution is to bring it to Garmin to get unlocked. “Secure Location” does not unlock a locked Garmin unit either as it’s only a temporary fix as when it’s turn on outside the security location, the device is locked again."
So unfortunately, there is only one option: You have to send your nüvi into the Garmin, who can unlock it. Remember original receipt.
Jan 02, 2009 | Garmin Nuvi 350 Car GPS Receiver
Garmin nuvi 350
Take the unit back to the "Security Location" you set and it will automatically unlocked. You can then change the PIN number.
Did you find a way to unlock the garmin?
The only way to unlock a PIN locked Garmin is to enter the correct PIN number or take the unit to the location at which the PIN was set. Your only other option is to return the unit to Garmin.
May 07, 2008 | Garmin nuvi 350 GPS Receiver
GPS Logo
22 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
