Question about Watches
Anne Klein V121E battery
How do i get the back off of a V121E watch
  • 110 Answers
SOURCE: I want to change the battery of an Anne Klein watch
I suspect the case back can be opened by prying up on one of the corners. But you may need a specail tool for this. I would hate to see you scratch up the back or cut you finger.
Posted on Oct 29, 2009
SOURCE: Need extra link for an Anne Klein 10-7977MPTT watch
I called Anne Klein saying I wanted to purchase additional links for an Anne Klein watch I had purchased, and I was (very kindly) instructed to call the following number between 8am and 5pm EST: 1-800-937-0050 ext. 203. I'll be calling tomorrow. Good luck!
Posted on Nov 04, 2009
SOURCE: anne klein watch battery replacement
My Anne Klein uses an EverReady #377. The internal time module from Hong Kong is stamped with "AL21E."
I hope this helps you.
Posted on Dec 09, 2009
disap1
  • 98 Answers
SOURCE: How do I remove links from an Anne Klein watch
Many watch companies are including extra clasps on the bands so customers can adjust the band easier on their own. Check the bottom of the band for those.
If not I suggest going to a reputable watch repair shop and have them do the adjustment for you. It will save you time and frustration of trying to do it yourself. If a screw or pin drops and you cant find it you may end up having to reorder them from Anne Klein!
Posted on Jan 10, 2010
escapement
  • 2334 Answers
SOURCE: where can i purchase 3 extra links for my Anne
Click on my profile, then click on TIPS AND TRICKS, There you will find a phone number for ordering parts from AK. Rate me, plz.
Posted on Feb 20, 2010
Watch battery for anne klein 10-6927 watch
If you are unable to open your watch, take it to a jeweler who, for a reasonable sum, will replace the battery. Make note of the battery type for future replacement.
Jul 31, 2016 | Anne Klein Watches
How to adjust Time and Date on Anne Klein 10/7899 6P05 Ladies Watch
You need to pull the crown out 2 clicks and rotate to set time.
1 click and rotate for day/date functions.
Push in fully to lock settings and resume time keeping.
Nordstrom provides a generic Anne Klein manual here:
http://i.nordstromimage.com/images/default/shop/image/misc/watch-manuals/anne-klein/anne-klein.pdf
Mar 20, 2016 | Anne Klein Watches
How do I set the date on an Anne Klein watch with only a stem?????
-GB&q=anne+klein+watches+how+to+ http://i.nordstromimage.com/images/.../watch-manuals/anne-klein/anne-klein.pdf .
Hello, you can download a pdf instruction sheet at the above site. Hope it helps. Bye.......
Mar 10, 2015 | Anne Klein Watches
What size battery do I need for an Anne Klein 10/4838-9 watch? There is also 753H printed on the back of the watch.
You most likely will need a 364 or a 377.
You may even need a 379. The only way to tell is to either open it up or search online if someone is selling the watch with the "Specs" (specifications)
Aug 11, 2013 | Anne Klein Watches
Need to Replace back piece of my watch?
No. Most likely not. Try contacting the manufacturer and give them a description of your watch. They most likely wont be able to help you becuase you need the numbers off the back of the watch in order for them to identify the watch...
Jul 18, 2013 | Pulsar Watches
I need an Ann Klein watchband replacement - model 10/9168 (has gold hardware in the band). Where can I go for this replacement?
You can just call 818-2496007 (in LA) and order any anne klein parts you need. For 10/9168 watchband, its price is about 22$.
Oct 19, 2012 | Anne Klein 10 6419SVTT 106419SVTT Watch
I bought a watch and we can't get it to work. We think the battery needs to be changed.
If you take a look at the back of the watch, look for screws holding on the back plate. If there are screws (usually, if they are there there is one in each corner -- unscrew them. If there are no screws in the back of the watch, look VERY carefully at where the backing for the watch connects to the front piece of the watch. There should be a small indentation somewhere along the rim -- use a knife or a small screwdriver in that groove and pop the watch backing off.
Once you have the back of the watch off, you will see the battery right there. Sometimes they just pop out (held in by the watch back) ... sometimes there is a small piece of metal holding it in (in which case you should try to rotate the metal piece off the battery -- don't bend it).
Once the battery is out, take it to a store that sells watch batteries and match the battery type exactly (a lot of watch batteries look the same, but you need an exact match). Put the new battery in, cover it with the metal tab (if there was one) by rotating the tab back over the battery like you found it. Put the watch backing back on (and replace the screws if there were any).
Hopefully, that will kick start your watch for you, and you should be all set :-)
May 24, 2011 | Cars & Co Disney Pixar Cars Mcqueen Analog...
How to open the back
Determine the type of case back on the watch. Set the watch face down on a soft surface and look at the back. If it has slots, it is defined as a screw-back case. If it is smooth, it is defined as a snap-back case.
To open a screw-back watch, use the metal blade of a standard screwdriver to turn the slots counterclockwise. A case-back wrench, which can be purchased at watch-repair stores, can also be used. Set the metal tips of the wrench into the back's slots and turn it counterclockwise to open.
For a snap back case, place the metal blade of a standard screwdriver in the indent between the watch and the case. Gently apply pressure to lift the case up and off of the watch.
Close the case back by setting it back onto the watch. For snap-back cases, line up the indent on the side of the watch and press gently on the case back to close. For screw-back cases, use the screwdriver blade or case-back wrench to turn the slots clockwise, thereby closing the case shut.
Feb 06, 2011 | Bulova Watch
Watches Logo
361 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
