Question about KitchenAid Architect Series KEMC308KSS Electric Double Oven
KEMC307KSS Microwave High pitched noise on and off during heating
When I first got my microwave, it was nice and quiet. Now, anytime I cook anything it has a high pitched sound as if the microwave was revving up. This, I believe, used to only happen when it was defrosting an item. Now it happens all the time. I had a technician in here and he didnt want to dig through the microwave because it is still working. I want it to keep working, but would prefer it go back to its old, quiet ways.
Thanks for any help!
  • 770 Answers
SOURCE: "door"
your door or interlock switch is not closing press on the door see if it stars if so you will have to check you alignment if not the switch could be bad you wuill need to open the ctrl panel to get to the switches unplug first
Posted on Jan 21, 2008
  • 1314 Answers
SOURCE: Kitchenaid builtin microwave oven # Kemc307KSS
ok the meat probe error is the meat probe is wired backwards yor microwave is a blown fuse in line with the primary interlock switch send me an email at can help the primary interlock switch is a fancy way of saying one of the three micro switches in the door that the hooks on the door trip when its closed
Posted on Jan 25, 2008
  • 2651 Answers
SOURCE: Service Manual
when you took down the control panel and gained acess to the upper cavity , there wasnt a service manual just to the left inside a red plastic bag???, if not there is another fuse loacted just behind the micro front looks to be atop the capacitor area
Posted on Mar 09, 2008
  • 1913 Answers
find your manual from here.
Posted on Oct 11, 2008
SOURCE: Oven unit not heating up - Kitchenaid KEMX377GWHO
This sounds like a blown thermal fuse, a common problem. What model oven was this?
Posted on Jan 14, 2009
Mirowave do heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Troubleshooting Tips
Mar 09, 2011 | Samsung Ovens
Microwave work but will not heat
If will does not heat or boil water, then your microwave is defective even if it appears to turn on.
If you do not hear the 'usual' humming noise that the microwave normally makes when heating, then the Magnetron is most probably defective: if the unit is out of warranty, it will not be worth replacing as it is quite expensive.
Hope it helps!
Dec 17, 2010 | Ovens
Why does food get hard after cooking or reheating in a microwave
It's basically a loss of moisture during the cooking process, to avoid this in a standard oven cook on a lower temp for longer and cover with the microwave, drop the power setting and always reheat or cook with the food cover with a microwave safe cling wrap or microwave specific cookware with lids.
Hope this helps.
Sep 08, 2010 | Whirlpool Ovens
Pleace HELP!!! How do I set the clock on my Russell Hobbs RHM1712 microwave?
You can set the timer on a range slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking. The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day.
Set the timer on a range slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
Fill the insert of the range slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours.
The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat.
A small indicator light will come on below the word to tell you the cooking temperature.
thank and thanks for using fixya.
Aug 20, 2010 | Ovens
Sorry, I have the same oven and the same complaint. The manual doesn't indicate anything. BTW- the service manual is inside the oven frame, between oven "lining" and the outside sheet metal.
Jan 03, 2010 | KitchenAid 27 in. Built-in...
Can a microwave listed as a countertop be installed over an oven or should an over the range type be installed?
over the range should be installed
they are desined to take the heat being over the stove will generate
as well as become your vent for the stove top
Oct 09, 2009 | Ovens
Convection works but Microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
May 26, 2009 | GE Monogram® ZMC1095BFBB /...
GE Advantium Microwave portion not working
There is a fuse for the Hi voltage transformer and the magnetron tube. You have to take the cover off to access the fuse.
Sep 02, 2017 | GE ZSC2001FSS Advantium Electric Single...
Sparking when microwaving
Mar 08, 2008 | GE Profile Advantium SCB2001KSS Stainless...
Microwave will turn on but not heat
Test the high voltage capacitor, the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Nov 26, 2007 | GE JTP85 Electric Double Oven
KitchenAid Architect Series KEMC308KSS Electric Double Oven Logo
366 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
