Question about 3M Samsung BD-D5100 Blu-ray Player
Gateway ping fails - 3M Samsung BD-D5100 Blu-ray Player
Where can i find my gateway ping on windows 8?/
There may be a problem in your internet connection.You first read user manual whether it is possible to connect the blueray player with internet or not.If you cannot ping the ip address there may be a problem in it.Try to reset the modem and check ping for any ip address and website using the site Whoisxy.com .
Apr 02, 2013 | Lenovo Computers & Internet
Operating system: Windows XP Home Edition Model: Acer One Aspire Problem: PC sees wireless networks & connects but Internet Explorer &/or Mozilla don't get me on the internet.
please ping your router gateway,for seeing default gateway you take command prompt and type ipconfig, there you can see your default gateway then type ping gatewayip (eg: ping 192.168.0.1) if you are getting reply from that gateway your computer communicating with your router.If you are getting request timedout then there is a problen in communication.If you are getting the reply then you just ping google (ping www.google.com).getting reply the connection to the internet is fine.If not there is problen in internet connection in the router.
Jul 21, 2011 | Computers & Internet
My laptop will not connect to our wireless router at work. It says connected, but no internet access.
The laptop might be connected to your wireless router but is unable to connect to the internet
check if you can ping websites
- click on start > Run > type in "cmd" > in the command prompt type in "ping www.yahoo.com"
- if you get 4 replies the problem might be with your browser.
- if Ping fails try typing "ping 209.191.122.70" which is the IP address for www.yahoo.com
- if ping is successful then the issue is with your DNS server. contact your ISP to get alternate DNS
- if Ping fails try pinging the default gateway or modem IP (you can find the default gateway by typing IPCONFIG)
- if ping is successful then there is a problem with your internet provider
Also you should try disabling your firewall and runnning a virus/malware scan
Mar 30, 2011 | Computers & Internet
I have a samsung tv , and im setting up my INTERNET@TV , it ticks off everything but the Gateway Ping ! Please Help
If the Gateway Ping test fails, then your TV is not communicating properly with your Router or Modem.
To resolve this, follow these steps:
  1. Power off your TV, Modem, and Router.
  2. Unplug the power for your Modem and Router.
  3. Make sure the ethernet cable is securely connected to both your TV and your Router or Modem.
  4. Plug in your Modem and turn it on.
  5. Plug in your Router and turn it on.
  6. Make sure your IP Address information entered into the TV during the Network Setup matches the information from your Router or Modem.
  • If you are using an Automatic Setup (most users), skip this step.
  • If you are using a Manual Setup (advanced users), contact your network administrator to determine what the correct IP Address information is.
7. Run the Network Test again.
  • If the Gateway Ping test passes, but another test fails, click here to go back to the list of Network Tests.
  • If all tests pass, the TV is successfully connected to your network.
  • If the Gateway Ping test fails again, see below....
If the Gateway Ping test fails again, there may be a problem with your network setup. To determine if there is a problem with your network, follow these steps:
  3. Connect your ethernet cable directly to the TV and Modem.
  5. Power on the TV and run the Network Tests again.
  • If all tests pass successfully, then there is a problem with your Router setup. Contact your network administrator or router manufacturer for information on setting up your network.
  • If all tests do not pass successfully, there may be a problem with the TV. Connect another device (such as a Computer) directly to the modem.
  • If the other device connects to the internet, then the TV will require service. Click the Create online service request button below to have the TV repaired.
  • If the other device does not connect to the internet when directly connected to the modem, then there may be a problem with your modem. Contact your Internet Service Provider for help on troubleshooting your modem.
(from Samsung support)
Hope this helps. -Sa_Les_Ski
Feb 28, 2011 | Televison & Video
I purchase a netgear universal wireless internet adapter to connect on my samsung tv to get the internet , netflik etc.....i was not able to pass the test with the gateway ping which failed. the model...
I have a couple of questions
1. What gateway are you pinging?
2. From what device are you sending the ping?
If you are trying to ping the gateway on the modem/router provided by your internet service provider then you will not get a ping response, this is because it's configured not to respond.
Oct 06, 2017 | Computers & Internet
How to gateway ping
jaykid18
The first thing you to check is to see if you are able to ping through your computer firewall. This link will help you check this.
How to allow ping (ICMP Echo) request through Windows 7 Firewall
Next you will need to know what the IP address of you Gateway is. If you do not know what it is the link below will help you find out what your Gateway IP address is.
http://www.fixya.com/support/r4935363-determine_computers_ip_address
After you have the IP address to your Gateway you will need to ping the address. If you need help doing this link will help you do this.
http://www.fixya.com/support/r6097326-ping_ip_address_in_windows
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Sep 21, 2010 | Belkin (F5D8231-4) Wireless Router...
I have the Samsung BD 3600 and the Belkin N router and fail the gateway ping. Help
if you are trying to ping the router from the outside internet, the ping function is probably shut off. If you are trying to ping the router from a local pc either the pc is not connected to the router network or the router network is not the same as the pc network (example: router gateway ip is 192.168.55.1 and your pc is looking for 192.168.1.1. Check the router gateway id. If you can get to the router, you are probably ok.
Send more info if you can't resolve the issue.
Jan 30, 2010 | Belkin Computers & Internet
Can't send e-mail
Check your network connection. Can you visit web pages? If not, check your network cable, modem, etc.
If your connection is good, try pinging your outgoing mail server.
If the ping fails, phone whoever maintains the server, and ask them when it will be back online.
If the ping is successful, try closing, then opening your mail client. Doublecheck the settings for outgoing server, port, encryption options, username and password.
Sep 17, 2008 | Gateway Computers & Internet
Configuration Utility
Can you ping the router? I mean open a dos shell, type ping -tf 192.168.1.254 - what are the results? Maybe the ping fails, because you need to have your pc set to the same subnet address, to access the router on that IP. Test ping to your own gateway address first.. That will work & show you what to expect from a working ping. You get the gateway address by opening a dos shell & typing ipconfig /all - that shows the current IP address plus the gateway address. Actually, the gatway address might be the same as the router config address, unless you have a NAT function turned on.. Anyway, if you change your IP address to 192.168.1.252 - For example, you will no longer be able to access the internet, but shud be able to enter the configuration web page of the router.. Try the router default settings first. Another thing is that some routers require a direct cable called a 'crossover' cable to connect to the router or you have to go via a hub or a switch, with standard ethernet cables.. This probably looks confusing, but if it does not help, pls post your questions here.. Rgds,
Jun 24, 2008 | MSI RG54G2 Router (MS-6848-002)
3M Samsung BD-D5100 Blu-ray Player Logo
16 people viewed this question
Top 3M Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a 3M Audio Player and Recorder Expert? Answer questions, earn points and help others
