Question about DeLonghi CF210 Portable Air Conditioner
Plug gets red hot on A.C. after 1/2 hour running.
I have a 10,000 BTU casement Fedders unit, I had a outlet installed just for the Air Conditioner, has worked fine the last few years. This year after running for a half hour the plug gets hot. I was told that I should replace the plug, will this fix it & where would I find a plug for it.
    President:
  • 1,902 Answers
Local hardware store would have replacement plugs and yes that would help the situation out. But the problem may lie inside the actual outlet also. So you may want to investigate the problem alittle more unless you have already done so
Posted on May 21, 2009
What does it mean when the clean filter come I washed fliter
Its sign of you air con filter has been dirty need go clean it .
Aug 07, 2016 | Arctic King 10,000 BTU Slide Casement Air...
Purchased september 2015 air is cold but fan is extremely LOUD
if it was purchase new then a warranty still applies so have the unit checked by a service agent under warranty
May 03, 2016 | Arctic King 10,000 BTU Slide Casement Air...
How many BTU's is Fedders model A6Q08F2A?
It is an 8000 BTU, I have one myself. The model A6Q08F2A
The Fedders A6Q10F2A, is a 10,000 BTU
Jun 09, 2014 | Fedders Q Chassis A6Q10F2A Air Conditioner
There is an exhaust switch on the front of the unit. (open or closed position). When should each be used?
exhaust when you want to change air inside room more than you want cooling and dehumid efficiency. It ports air to outside, to be replaced by air from the outside (often from elsewhere in house, rather than via the AC unit). Does that answer it?
May 02, 2014 | Arctic King 10,000 BTU Slide Casement Air...
I HAVE A FEDDERS AIR CONDITIONER MODEL AED24E7F-C THIS UNIT TRIPS THE RESET BUTTON ONCE IN A GREAT WHILE IT RUNS FOR HOURS OR DAYS ON END AND THEN TRIPS. IT TAKE AWHILE AFTER THAT BEFORE I CAN RESET...
The reset button is part of the cord. The cord has built in arc detection. This is a complex circuit that monitors the unit and senses potentially dangerous sparks or arcing inside the internal components of the A/C (motors, switches, etc.) It sounds like the problem is getting worse - as they usually do. Sparking and arcing happen when dirt, corrosion, etc. accumulates and can result in pitted contacts. All of these conditions only make the sparks and arcs worse. Page 1 of the manual (left column) says this:
If the Arc Detection Device has tripped, the
reset button will pop up.
Follow these steps to reset the Arc Detection
Device:
1. Unplug unit from electrical outlet
2. Press the reset button
3. Plug the unit back into electrical outlet
4. Check to see if power has returned to the unit
Testing
You should test the Arc Detection Device
equipped power cord monthly, after every major
electrical storm, or if power to your Room Air
Conditioner has been interrupted.
Follow these steps to test the Arc Detection
Device:
4. Press test button. Unit should trip and reset
button will pop up.
5. Press reset button again for use
If above test fails, stop using the air
conditioner and contact customer service by
calling the following toll-free number:
1-800-332-6658 or email:
customerservice@fedders.com
I hope this helps & good luck!
Aug 30, 2011 | Heating & Cooling
I've had this maytag 10000 btu slider casement air conditioner for approx 3 years. its installed in a window & has been used possibly 10 times. the fan motor comes on, however there is no cooling...
Check the thermostat, does it open and close (electrically)?
In the past three years, has the unit been cleaned? If the coil is plugged with dust, there may have been serious damage to the comressor.
With the unit unplugged, using a multi-meter, is there continuity between the switch hot tab and the compressor feed?
Is there a run capacitor on the compressor? If so, is it shorted or open?
These will give you a few places to start. If you do not know how to operate a multimeter, you need a contractor. Another option is to check your phone book and look for an local refrigeration school. Often, these schools will do the repairs if you pay for the parts.
Jul 19, 2010 | Maytag 10000 BTU Slider Casement Air...
Can't find a manual for air conditioner
BTU means "British thermal units" and is a measurment of cooling and heating capacity. Other units are Kw "Kilowatts", and HP "Horse Power".
To convert
Multiply by
To obtain
kW
1.341
hp
kW
3,413
Btu/hr
hp
2,545
Btu/hr
May 21, 2010 | Fedders Q Chassis A6Q10F2A Air Conditioner
My kenmore 12k BTU window unit will not turn on and behaves the same way as if unplugged... no sign of ''life.''
Hi, check house panel circuit breakers or fuses, check receptacle/outlet. if you got plug/receptacle, check for reset button, press reset. if there's power at receptacle, could be faulty circuit board. good luck
Sep 10, 2009 | Kenmore Slider/Casement Air Conditioner
Fedders air conditioner beeps but doesn't turn on.
Unplugged unit first. Take control panel out but dont unplug wiring. Cut Firth wire out from the center on the touch pad six wire plug. Cap both ends and plug back in. now unit will run on high cool and turn it on and off by plug and unplug
Aug 15, 2007 | Fedders X Chassis A6X05F2B Air Conditioner
DeLonghi CF210 Portable Air Conditioner Logo
335 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
