Question about Dishwashers
Lamona 8601 Water heater stays on even after the wash is finished
I have a Lamona HJA8514 intergrated washing machine and I cannot find the filter to clean it. Can't see it on manual either
the only filter some washing machines have is at the water supply where hoses hook up.if front load some were right inside door at bottom hope this helps
Feb 12, 2015 | Washing Machines
Dishwasher washes dishes but does not dry even though that display shows dry icon
First ,Check for a water puddle on the bottom of the dishwasher .If you have water there, you more than likely have a plugged drain or drain hose, or bad drain pump (less likely) If no water is there see if the dishes are hot after a cycle. If they are not you could have a bad heater (that circular thing on the bottom of the dishwasher) other problems could be the timer or computer Depending on the model brand and age of the dishwasher .One last thing there is a vent to let moisture escape that could be bad but then you would have hot wet dishes
Aug 07, 2014 | Blomberg Dishwashers
Lack of hot water
washing machines are a hgigh demand water usage sytem anyway..I would use the regular water heater with the washer as it holds 40 gallons and most washers pump in a minimum 20 gallonson the low side..
Mar 08, 2014 | LG WM0642H
Lamona HJA8553 Washing Machine door release has suddenly stopped working!! Is there an emergency door release to get my wet washing out??? tried turning off at the wall in hope of resetting the machine...
My Lamona integrated washing machine HJA 8553 has a nasty smell coming from it like an old damp mop its making the whole of the house smell any ideas why
Jun 30, 2011 | Washing Machines
Hobart LXIH stuck in Wash mode after running multiple loads. Shutting off breaker for several hours fixes problem until multiple loads have been run again and then it is once more stuck in Wash mode.
How long does it stay in the wash cycle? Indefinitely? Does the display continuously show "WASH"?. If it stays in the wash cycle indefinitely (i.e. continuously shows "WASH" for significantly beyond approx. 3 minutes), it's probably a control board malfunction. If it continues to wash after the "WASH" indicator goes out, it could be a shorted wash motor relay on the relay board or a fauly control board.
If the internal rinse water booster heater doesn't reach it's programmed setpoint temperature in time, the dishwasher will run an extended wash cycle to give the booster heater more time to finish heating the rinse water. If this is what's happening, the wash cycle would last approximately 3 minutes, then it would rinse regardless of whether the booster heater has finished heating or not.
The booster temperature thermistor may be bad, giving a false booster temperature reading, causing an extended wash cycle as described above. The booster heater elements or contactor may be bad, preventing the booster heater from heating and reaching proper temperature, also causing the same extended wash cycle to give the booster more time to heat.
Jan 06, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwasher stays in cleaning mode and does not cycle to rinse.
Hello their sounds as though water heater has failed if it doesnt heat it defaults to a 3 hour cold wash and never finishes cycle eg doesnt go through rinse stages.will need a new heater service tech to change as fairly complicated.
Nov 02, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
The washing machine barrel fills up with water even after the wash has finished and all clothes removed, why?
The water inlet valve is passing a little water through in the unenergized state. Turn the water supply valves off and wait. If the filling up stops replace the machine's inlet valve and if you can, flush your water pipes and water heater before hooking the washer back up
May 26, 2010 | Hoover Washing Machines
What is the F20 error code?
F-20 error code in Whirlpool Duet Sport washing machine is indication of inadequate water supply. Check both hot and cold water supply lines to make sure machine gets enough water intake. If you do not have a hot water supply to the machine you can only run it with the cold temperature setting. This machine does not have an internal water heater and relies on the hot water supply from the house water heater.
Jul 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dishwashers Logo
22 people viewed this question
Top Dishwashers Experts
Owen Barnes
