Question about Peavey Electronics Peavey Sanpera 1
Volumewah no longer work
Led inside pedal not working wonder if small circuitboard can be replaced
My guitar pedal led stopped working
Try replacing the LED like I did on my tuner Pedal. Here's a link to the tutorial video i made. https://www.youtube.com/watch?v=T9LP39WmHF0
Sep 11, 2012 | Music
I have a Digitech wammy 4 v pedal the led light are going out i have 3 lights left how can i fix the led light the pedal works fine with out the lights
Check the burned out LEDS with a 3 volt battery- a computer bios battery works well for these.
If they do not light, which is likely, just replace them with similar sized units. You can even change their color too. Measure the voltage at the LED sodler pads to see if it is more than 3 volts, if it is, add a resistor to drop the voltage and limit current to the replacements. Digikey sells them, and they ship around the world http://www.digikey.com or Mouser, Both are based in the US, I am not sure what Mouser's international shipping is. http://www.mouser.com
If there is no voltage at the LED pads, look for bad solder connections, or burned out resistors. If the few remaining LEDs still operate as they should, the level meter chip "should" be okay.
Feb 14, 2012 | Digi-Tech Music
HI Fixya, My Korg DT-10 is broken, when plugin a cable, the light won't get on. I have some experience with opening a pedal look at the circuitboard to the problem, but this i can't fix it....
Just having "volts" does not guarantee they are the right voltage. Check that the adapter you are using is the right one... this device MAY require a higher current than some and low voltage could cuase the failure. Verify the adapter is the original one... if on batteries, replace them with known good ALKALINE batteries. Music devices for the most part will NOT operate reliably on rechargeables.
Aug 02, 2011 | Korg DT-10 Digital Tuner
It seems to have no power the led light doesn't come on. its brand new, but I havent used it in about five years
Are you using battery or AC adapter for power?
Most pedals won't allow you to use both. Check that there is no battery installed if you're going to plug it in. If you are using a battery, Some pedals won't light an LED on battery power.
If problem persists, your pedal may be DOA
May 04, 2011 | Boss Mt 2 Metal Zone Effects Pedal
Hello my roland street cube won't power on, either with dc or batteries....adapter working .could a fuse be blown inside circuitboard? thanks
That is the first thing to check. They are most likely inside the circuit board. Remember to replace them with the same voltage and amperage ratings.
Feb 13, 2011 | Roland Cube-st Battery Powered Amp Cube...
The foot pedal no longer operates when plugged into the fill jack
The fact that the pedal works in the on /ff is not a complete exhoneration.
Due to certain possible failures the pedal can still be at fault. Test the resistance of the switch and leakage resistance.
The two inputs may have different electrical characteristics where one would tolerate a partially defective switch and the other would not.
Use an ohmmeter to test the pedal before drawing conclusion.
Mar 13, 2010 | Alesis Sr 16 Stereo Drum Machine
My BOSS Distortion(DS-1) pedal buzzes whenever the distortion is up. I've changed the battery, outlet, and amp, but it continues to sound. I tried a different pedal, and it worked fine. How can I stop it...
This sounds like a broken ground wire or trace within the unit if an IDENTICAL pedal does not act the same AT THE SAME SETTINGS.
Sometimes a circuit trace gets broken on the board inside pedals and can cause this.
Since an identical pedal doesn't have the problem, service is required.
If you know electronics you can open the pedal and look for obvious problems.
HINT: Use a bright LED penlight to "candle" the circuit board to look for cracks.
Look for broken solder joints... this can take an experienced eye to spot.
A distortion pedal NORMALLY is very simple circuitry.
Nov 08, 2009 | Boss Music
Can I replace the pedal unit to the Yamaha Clavinova CVP-75?
I can't solve the problem, but just wanted to sympathize because I have the same problem. My pedal is broken on my Yamaha Clavinova cvp85a. It worked wonderfully for years but finally it broke.
I'd be in the market for buying a new pedal or fixing the old one. But I've not found any suggestions in any of these forums for either solution.
Jul 21, 2009 | Yamaha Music
Digitech RP 90 foot switch is not working
I removed the back cover, unscrewed the two (of 4) screws holding down the circuit board, replaced them again, and it worked fine.
Jan 11, 2009 | Music
Peavey Electronics Peavey Sanpera 1 Logo
13 people viewed this question
Top Peavey Music Experts
Ben Armstrong
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
