Question about Idylis 2.5-Gallon Ultrasonic Humidifier IHUM-20-25
Idylis humidifier not putting out mist
Running, but no mist
My diffuser will not mist. The lights are on and it is running fine otherwise. What is the problem?
Did you use distilled water ?
Ours called for distilled water to work correctly, we used tap water and it worked for the first few times. then started making noise and then stopped.
Started using RO water, (like distilled) and started working again.
Apr 07, 2015 | Humidifiers
I have a Cool Mist Homedics Ultrasonic humidifier, Model UHE-OC1A that has stopped working...I have cleaned it, the small lights go on when turned on, but no mist is coming out ... ???
In the bottom of the humidifier is a little disk that vibrates to turn water to vapor. This gets covered in mineral deposits and won't vibrate properly. They usually suggest something like vinegar to clean it. I found that this didn't work for me. What did work was cleaning it with my Waterpic on the highest setting. It chipped away the deposits and allowed it to work. HOWEVER, once you get it running again, buy the slant fin mineral absorption pads to keep it running. If you have mineral-rich water like me, you'll go through them quickly, but you also won't have white deposits on your walls anymore.
Feb 24, 2015 | Homedics Cool Mist Humidfier - Uhe-oc1 -
What is proper procedure for running vinegar through my Hankscraft cool mist humidified?
Not sure why you would want to. Vinegar is typically used to remove calcium scale that remains after a heating element or electrodes boil off water. The Hankscraft 240 doesn't boil the water off. All the minerals in the water go out the spout with the mist.
Dec 12, 2014 | Hankscraft Gerber Model 240 Cool Mist...
I have a Cool Mist V3500 humidifier. The fan
TRY POURING IN SOME WHITE DISTILLED VINEGAR AND RUNNING IT. THE VINEGAR LOOSEN UP ANY SCALE AND JUNK. AFTER RUNNING UNIT FOR AWHILE, DRAIN OUT ANY REMAINING LIQUID AND ADD DISTILLED WATER OR FILTERED WATER. RUN UNIT AGAIN. THEN DRAIN OUT ANY LIQUID. NOW THE UNIT SHOULD WORK AS NORMAL. IN THE FUTURE, TRY USING DISTILLED WATER OR FILTERED WATER.
Dec 13, 2009 | Vicks Cool Mist V3500 Humidifier
We have a Sunbeam Cool Mist Ultrasonic Humidifier that we bought just over 2 months ago. Up until a couple of days ago, it was producing mist and running just fine. I cleaned it with the brush and got the...
I have this same problem. And cool mist humidifiers DO produce mist. I have had my humidifier for a while now (6 years) and have never had any problems. But after the most recent cleaning, it worked at first, but now seems to not be working anymore... Am also wondering if there is anything I can do to remedy the situation?
Mar 17, 2009 | Sunbeam 701 Humidifier
Fan works, but no mist and water isn't going away
Turn on furnace and urn up humidistst to call for it. Tube from solenid to the filter should have water running if water is up to the valve and solinoid is opening . It should be warm to your touch., Using an ohm meter you can sheck the coil it shuold have continuity.
Mar 11, 2009 | Honeywell QuietCare HCM-630 Humidifier
No mist!
unfortunately on a cool mist unit the mist shouldn't show up. on most units that's what it does. the warm mist units show the mist.. the best way to tell is if you put your hand over the spout that the mist is suppose to come out of for about 2 minutes and you pull it away and it feel clammy then it's working. if your hand is still dry please let me know and i'll see what else i can do for you.
Feb 26, 2009 | Holmes Products HM500-UC 1 Gallon...
HUMIDIFIER IS VERY NOISY AND MIST SPRAYS FROM ONE SIDE ONLY
You should have bought a Cleanaer! It's totally silent, reaches all corners of the room with its patented LiquidIon technology not only takes the bad particles from the air, but locks them out for good so they do not reenter the airspace when you cross the room or disturb the furnishings.
Feb 15, 2009 | Bionaire Humidifiers
Sunbeam ultrasonic humidifier runs but produces no mist
It sounds very much like the transducer has failed. This is likely a crystal transducer and since they produce the agitation that should cause a mist, they are running continuously; not a good thing for something that is trying to shake iteslf apart all the time. These require input from a circuit that produces the fairly high level of power needed to drive the crystal so it could also be the source of the problem.
This isn't something an owner is able to diagnose unless they have some technical training.
Nov 08, 2008 | Sunbeam Ultrasonic 81696 Humidifier
Idylis 2.5-Gallon Ultrasonic Humidifier IHUM-20-25 Logo
252 people viewed this question
Top Idylis Humidifiers Experts
Paul Carew
Dennis
Are you an Idylis Humidifier Expert? Answer questions, earn points and help others
