Question about Jl Audio 12W3 Car Subwoofer
Whats the air space for a pair 12 inch 200 dub subs
  • Jl Audio Master
  • 637 Answers
If you tell me what type of vehicle this is going into I can design free of charge the box that you would need for optimum performance.
Posted on Nov 21, 2014
If I have two 12 inch subs and a 15 inch sub in a box,do I have to keep the air space for each separated
THE IDENTICAL SPEAKERS COULD OR COULD NOT SHARE THE SAME AIRSPACE, BUT THE 15 WILL HAVE TO HAVE ITS OWN ENCLOSURE AIR SPACE. EVEN IF IT WERE A SIMPLE SEALED ENCLOSURE, YOU COULD NEVER MIX THE TWO TYPES OF WOOFERS IN THE COMMON AIR SPACE. ALSO KEEP IN MIND THAT EACH TYPE, THE 12'S AND THE 15 SHOULD BE PLAYING DIFFERENT BANDS OF FREQ. USING A VERY STEEP CROSSOVER. AT LEAST 24DB/OCTAVE AND AN EXAMPLE MIGHT BE TO CROSS THE 15 AT 20-40HZ. AND THE 12'S FOR 40-80 OR SO, THE TOP END OF THE 12'S MIGHT BE HIGHER DEPENDING UPON WHICH MID SPEAKERS YOU ARE USING AND HOW LOW YOU CAN CROSS THEM. OK. HOPE THIS HELPS.....V
Jan 13, 2017 | Car Audio & Video
How do i fix a frozen 12 inch power acoustik FUBAR-12W sub
You have a case of a blown sub. You will need a recone kit. You ca send it in to a company like fix my speaker or google recone kits for Power Acoustik FUBAR. May be cheaper just to get another sub.
Oct 20, 2012 | Power Acoustik FUBAR-12W Car Subwoofer
What size box should i build fro two pioneer 12inch speakers 1200watts each
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. If it is a 12 inch speaker, the box size will be 13 inches x 13 inches x 13 inches.
Mar 17, 2011 | Pioneer TS-W307D2 12" 1200 Watt Champion...
What is the best box to get for a pair of cvr 12 for my yukon
If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long Box size will be 13 inches x 13 inches x 13 inches
Mar 21, 2010 | Kicker CompVR Loaded Sealed Boxes...
What is the recommened air space for kicker comp vr sealed do you know the specs for building a sealed box
Really it all depends on how you want them to sound, and to be set up. There really is not specific air space, but there are general air spaces that work, and some times the manufacture will list some specs for different set ups. It also depends on the size of the sub, which you did not specify.
Kicker recommends as follows.
0.4 cubs per sub for a compact box, and 1.8 for an SQ box. SQ stand for sound quality.
So if you want a small box, do .4 per sub. If you want a better sounding box do 1.8.
Rule of thumb and something to think about.
The more air space in the sub, the less power you can run, the less air space, the more power you can run.
For example you can run 200 watts RMS per sub at .4 cubes, but only 140 watts RMS with 1.8.
As well, the smaller box will be louder, But not sound as good.
Dec 24, 2009 | Kicker CompVR 05CVR84 Car Subwoofer
Getting my son a sony xplod xm-1652 2 channel what subs would sound good and the things says 1000x2 and 500x2 what is the truth
165 watts x 2 @ 4ohms and 200-230 watts@ 2 ohms or 400-460 watts bridged into a 4 ohm mono load is what the amp will actually do. A single 12 inch sub or a pair of 10 inch subs or 12s would be great
Nov 22, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Need dimensions for 12' 450watt IMPP Subwoolfers for proper air space
Subwoofers differ in only one way. You get an "Open Air" and a "Closed air" subwoofer, That being said, you'll have to check on your magnet which one you have to make the boxes for that sub. If it is an "Open air" Subwoofer, you should see a "wire mesh" or "grid" in the centre, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.
If it is a "Open air" sub, your boxes should be sealed with silicone, and no ports are to be cut in your box.
With "Closed air" subs, you should have 2 ports below your sub and the port sizes should be around 50mm in diameter. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 200mm, depending on the frequency of bass you require.
On a 12 inch subwoofer ranging between 80Hz and 120Hz, the box size required should be around 27 liters, meaning that you will end up with a box of 16 inches high, x 16 inches wide, x 16 inches deep. Or 320mm high, x 320mm wide, x 320mm deep.
Enjoy!
Oct 14, 2009 | Car Audio & Video
12 inch subs emit engine noise
You will have to go buy noise filters for the headunit. This will stop engine noise
Jan 31, 2009 | Precision Camera Precision Audio 12-inch...
What is the sealed and ported box volumes for the audiobahn dub 200 subs?
If you can access the inside of the sub box by removing the speaker, you may be able to measure the 3 dimension of each side of the enclosure.  1 cubic foot is 12x12x12 inches cubed.  That is 1728 cubic inches per cubic foot.  If you measure the inside dimensions of one of the enclosure sides as 10x14x8 inches, then that is 1120.  1120 divided by 1728 is 0.648 cubic feet.  Alternatively, you could estimate the volumes of each side of the box by measure the outside, figuring out where the box divider board is, subtracting the width of the boards used to make and then calculate.  Otherwise, I do not know the enclosure that that sub comes in.  Good luck.  Let us know how it goes.
Jan 02, 2009 | AudioBahn DUB200 Car Subwoofer
What air space is needed for the v810d2 sub plus what size of air ports
if its the box it only needs like a 1 to 2 inch hole. i have 4 tens in my car and alls i have is a single 1 inch hole. if this isnt what your talking about try and email me back.
Jun 10, 2008 | Visonik V810D2 Car Subwoofer
Jl Audio 12W3 Car Subwoofer Logo
101 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Matthew Spark
Matthew Spark
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
