Question about Briggs & Stratton Garden
Husky generator model 030437 gas engine runs but generator does not put out any voltage
CarlGehrke
  • 169 Answers
SOURCE: generator wont put out enough voltage, only get 107 volts, is this a voltage reg. problem
This problem is either that the engine RPM is too low (most likely), or that there is something amiss in the voltage regulation. Get yourself a DMM that measures Hz, plug it into the output and see if you get 61.5 Hz, if not look for the adjustment on the governor spring. On some Powermates this is a screw that pressed on the governor arm, on others it's a little tab the governor spring attaches to that you bend. Do this at no load. FWIW 61.5 Hz is also 3750 RPM of the engine.
Posted on Dec 01, 2008
54generator
  • 3 Answers
SOURCE: portable generator low voltage
85 volts represents residual voltage. It is possible that your unit sat for an extended period and lost it's magnetism or the excitation system failed under load. check your manual for a procedure to "flash the field". If that is not successful, e-mail me and I'll tell you how to trouble shoot the failure.
Posted on Jan 04, 2009
  • 174 Answers
SOURCE: husky 2400 psi honda engine ran fine all day
It sounds like the bypass valve is stuck. Do you have a parts diagram?
Posted on Jun 27, 2009
Rebgagnon
  • 382 Answers
SOURCE: Husky 5000w Generator with a Subaru engin.
Fuel system needs cleaned. Dirt or build up get's in the passages and it can not properly regulate the fuel/air mixture. Being it runs well in choke position I would suspect it is plugged on the idle passage. Sometimes you can add a very small amount of "Seafoam" to the fuel and let it run while slowly moving the lever to the run position and this will clean it out. It is also possible that the fuel tank has a small amount of water in it. Good luck and have a great day.
Posted on Feb 15, 2010
  • 112 Answers
SOURCE: Is there anywhere I can download the pdf file -
http://pdfcatch.net/ebook/coleman+generator/
Posted on Jul 24, 2010
Mitsubishi MGE 5800 generator won't start. Will run for seconds when I put gas directly in the carburetor. I cleaned the carburetor etc.
If the engine will start when starter fluid is sprayed into the carb, you missed cleaning some small orifice in the carb. Recheck/reclean the carb and you should be OK.
Aug 18, 2017 | NEC Mitsubishi MGE 4000 Generator ROU...
Why does my husky 6250 generator run but not produce power?
Anon, If it has sat for quite a while, you may have to field flash/re exite the generator. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to re energize Dead Generator
Flash Your Generac Portable Generator with Corded Drill
How to test your Electricity Generator AVR Brushes and Alternator on...
Diagnosing Generator That Has No Power Output
Jun 08, 2016 | Husky Electrical Supplies
What kind of oil?
It actually depends on the environment but you will be okay with 10W30
Mar 27, 2016 | Husky 3650 Watt Generator with Subaru...
Coleman 3500 with subaru engine no power to outlets
Hello there.
I'm assuming that engine runs fine. if there's no power output then the AVR or carbon brushes are dead. remove the back cover of the alternator very carefully and look at the center to find the rotor rings and check if the plastic brush holder hasn't melt or heat deformed and make sure the brushes make good contact against the rotor rings. if everything's fine then the AVR is dead. The AVR is a crescent shaped plastic container similar to this one.
http://www.ebay.com/itm/Automatic-Voltage-Regulator-AVR-For-5KW-5-5KW-Single-Phase-Gasoline-Generator-/221461125389
replace it with any similar found on Ebay, just make sure that connectors and cables are similar in shape and number. Regards
Jul 06, 2014 | Husky 3650 Watt Generator with Subaru...
Generator will not produce electricity, why
Why wont my husky generator put out electricity
Jun 05, 2014 | Husky Portable generator
3650 generator won't start!!
I assume that the spark plug are good and the gas line is clear. Try to adjust the gas line supply and default engine startup revolution settings try it full half and minimum back and forth it works. Other gen sets requires a mix of oil with its gas, please do it when it is required with exact proportion. Hope this helps. Goodluck.
Mar 18, 2014 | Husky 3650 Watt Generator with Subaru...
Husky generator 1850 watt wont stay running
does ithave fresh gas theres a chance there is water in the gas if thats not the case is the choke could be stuck on or the carb. is gummed up
Oct 28, 2012 | Husky Electrical Supplies
Model pm0525312.18 serial 914080230 engine runs good but the voltage drops of from about 125volts to 90 volts when you put on about 1500 watts. does this model have a voltage regulator? what is a bridge...
According to the parts pdf, there is no voltage regulator. Voltage is adjusted by the rpm of the engine. If your have a meter that reads hertz (Hz), you can set the engine rpm by adjusting hertz to 60 cycles (Hz). At 60 cycles the engine is running at about 3600 rpm. Most engines develop their max horsepower at this rpm. If you are loosing power/voltage and the engine speed is not dropping below 3600, than most likely could be problem with capacitor, brushes or diode (bridge diode). The diode converts ac voltage from stator to direct current to power the magnet (rotor). Check for brush wear and test capacitor for value printed on part. It should test with 5% of stated value. Diode can also be easily tested with meter. Good holidays
Dec 05, 2010 | Coleman Powermate Powermate 5000W...
Garden Logo
76 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
