Question about Apple iPad 2 Wifi 16GB
Disabled ipad how do I unlock or rest through iTunes
2 Suggested Answers
SOURCE: can you show me steps to unlock my ipad is disabled connect to itunes
Jailbreakme.com
Posted on Feb 23, 2012
Ipad is disabled connect to iTunes. how do I fix it.
Hi Judith.
this is all i could find if this does not work go to the link at the bottom of this page.
The first thing you should try to unlock your disableddevice is a simple iTunes backup. Connect your iOS device to your computer via USB and open iTunes. Select the device in the upper right-hand corner to display its properties in the main screen. Click on the "Back Up Now" button to start a sync.11 Feb 2014
How to fix an iPad that's been disabled after entering the wrong ...
https://www.engadget.com/.../how-to-fix-an-ipad-thats-been-disabled-after-entering-the-...
Ipad is disabled connect to iTunes Google Search
Nov 04, 2017 | Tablets & eReaders
I forgot my unlock code for my old ipad1 haven't used in in months
If your iPad is disabled, the only way to unlock it is to completely erase and reset it. If you have a backup, you'll be able to restore it, otherwise you'll lose all of your data. There is no way to unlock a disabled iPad unless you use the correct passcode or you erase it. And the following guidance will show you how to unlock a disabled iPhone with iTunes.
Step 1. Connect your iPad to the computer with via a USB cable that your iPad has trusted.
Step 2. Launch iTunes. If you've synced your iPad with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPad and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by clicking "Back up Now" in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it to reset your iPad. Once the reset process is complete, you'll be taken through the iPod's initial setup process.
Step 5. Select "Restore from iTunes backup" during the setup process. This will load the backup that you created so that all of your data is restored.
http://www.leawo.org/tutorial/how-to-unlock-a-disabled-iphone-with-without-itunes.html
Feb 18, 2017 | Apple iPad Tablets & eReaders
How do i reset my iPad that's currently disabled and won't let me connect with iTunes?
You connect your iPad to a COMPUTER with iTunes on it. That is the only way to load the Operating System if you can't do it from Settings on the iPad.
Also, iTunes will give you the option to back everything first. Then after the Reset, you Restore to the back up and all your App, music, mail and everything come back.
If you can get into Settings on the iPad, reply back as a COMMENT below this post.
Jan 23, 2017 | Tablets & eReaders
Ave a lock screen on my Ipad and cant remeber my apple ID
If your iPad is disabled, the only way to unlock it is to completely erase and reset it. If you have a backup, you'll be able to restore it, otherwise you'll lose all of your data. There is no way to unlock a disabled iPad unless you use the correct passcode or you erase it. And the following guidance will show you how to unlock a disabled iPad with iTunes.
Step 4. In the Summary window, you can see the option "Restore iPad". Click it to reset your iPad. Once the reset process is complete, you'll be taken through the iPod's initial setup process.
Dec 04, 2016 | Apple iPad Tablets & eReaders
My ipad says its disable wont let me in it so how do i resat it
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by clicking "Back up Now" in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it to reset your iPhone. Once the reset process is complete, you'll be taken through the iPod's initial setup process.
Nov 03, 2016 | Apple iPad Tablets & eReaders
How can i transter pictures from my disabled ipad to the laptop?
If the pad doesn't work then there is no way to transfer the pictures that I know of.
Sep 21, 2016 | Apple iPad (16 GB) WiFi Tablet PC
Ipad is disable
Hold down the on off button on the top of your Ipad and hold it until it says 'swipe to turn off". After wait until it completely shut down and put it on charge for 30 minutes. After turn it on by pressing and holding down the same button for 10 seconds and then it should be fixed.
Sep 05, 2016 | Tablets & eReaders
How do i fix my disable ipad
Go to iTunes then sign in, connect your iPad to the PC/Laptop and factory reset the iPad, that is the only way it can be done!
Aug 30, 2016 | Apple iPad Tablets & eReaders
My iPad is disabled and i don't know what to do i've gone on iTunes but nothing seemed to work,what should i do please help me.do you think that you can help me
disabled how if icloud locked we or itunes cant help you --if battery or screen problem bring to a repair shop or sony store
Aug 30, 2016 | Apple iPad Mini
My ipad is disabled how do i fix it
Try connecting it to iTunes, turning off the ipad, then hold both the lock and the home button for 10 seconds, then relese the lock button while continuing to hold the home button until iTunes recognizes the iPad. Then you should be able to reset it without problem.
Dec 02, 2011 | Apple iPad 64 GB 3G Tablet PC
Apple iPad 2 Wifi 16GB Logo
206 people viewed this question
Top Apple Tablets & eReaders Experts
Virgil Wolter
Level 1 Expert
Aaron Galvan
Level 1 Expert
Yoav Shilon
Yoav Shilon
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
