Question about RIM BlackBerry Storm 9530 Smartphone
Black Berry storm binkig red lignt but do not wat to turn on
My Black Berry Storm do not want to turn on , when i connect to USB cord or AS power sours blinking of red light one and after 4 more, battery removing did t work also ,if i connect to computer no recognition, thank very much if any one know what to do with that!!!!!!!!
I Just had the same problem also. My phone would not come on. It would go straight to the loading screen and turn right back off. I took out my battery and put it back in and before it could turn off again i quickly put in the charger.
It came back on...hope this works for you also
Posted on May 23, 2009
  • 54 Answers
Had the same problem and it is a dead phone call Verizon and they will let you get a new one. (go to the store first so they know it is really dead)
Posted on May 21, 2009
I lock my black berry storm 9530and cant open the phone what can i do
Just type any password until you fail 10 times, it will make you blackberry storm 9530 unlocked from old password. But this method have side effect which mean all your previous data will be erased after your blackberry unlocked.
May 20, 2011 | RIM BlackBerry Storm 9530 Smartphone
I have a black berry storm 9530 for verison but i have to use it in nigeria but i cant perform simple network operation like rechargeing *123# and other command. i get the number unobtainble message on...
Hi sir,
i think you need to contact your service provider so they can set up a necessary settings for your connection if you're going to other place..thanks :D
Apr 14, 2011 | RIM BlackBerry Storm 9530 Smartphone
Need to do video calling from my black berry strom2 9520
Simple answer. You can't.
The Storm 2 is not equipped with the necessary front facing camera nor other hardware required to make video calls.
Mar 10, 2011 | RIM BlackBerry Storm 9530 Smartphone
How can i downlod mep code for black berry storm 9500
You don't need to download that code since you can get it by your own hand. Try this link and follow their direction step by step to get your mep code. Usually mep code is needed when you want to unlock blackberry storm 9500 network, however if you want simple way to unlock your phone network try to use blackberry unlock code.
Mar 18, 2010 | RIM BlackBerry Storm 9530 Smartphone
My printer will not turn on. We had a storm
Solution one: Press and quickly release the Power button Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold down the button . Figure 1: Press and quickly release the Power buttonc01896071.gif c01733891.gif If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button (c01602202.gif ) again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution two: Check the electrical connections and outlet
  1. Unplug the power cord from the electrical outlet, or the power strip or surge suppressor. Power module Power cord c00745315.gif c00057913.jpg
    NOTE: The power cord detaches from the power module. The term power supply refers to both the power module and the power cord.
  2. Carefully inspect the power cord for visible damage. c01733891.gif If the power cord or power module shows any damage, contact HP to replace the power supply.
  3. Disconnect the power supply from the back of the product.
  4. Wait at least 30 seconds, and then plug the disconnected power supply into an electrical outlet. Do not use a power strip or surge suppressor. c01733891.gif If the green light (LED) on the power supply does not light up, contact HP to replace the power supply.
  5. Reconnect the power module to the product.
  6. Press and quickly release the Power button (c01602202.gif ) to turn the product on.
  7. If the product still does not turn on, connect the product to an electrical outlet in another room, and then quickly press and release the Power button (c01602202.gif ) to turn on the product.
    • If the product turns on , the electrical outlet in the original room caused the issue.
    • If the product still does not turn on , continue with the next solution.
Solution three: Check the USB cable
  1. Disconnect the USB cable from the back of the product. Figure 2: Disconnect the USB cable from the HP productc01896072.gif
  2. Press the Power button (c01602202.gif ) to turn on the product.
    • If the product turns on with the USB cable disconnected , replace the USB cable.
    • If the product still does not turn on , continue to the next solution.
Solution four: Check the batteryIf your HP product has a battery, follow these steps:
  1. Check the battery light. If the light is red, recharge the battery.
  2. If the battery light is still red after recharge, replace the battery. Figure 3: Removing a battery (example only)c01468528.jpg 1 - Slide the battery release slider in the direction of the arrow 2 - Remove the battery
Instructions for recharging and replacing a battery are available on the HP Web site. Solution five: Replace the power supplyIf you have completed all of the troubleshooting steps and are still experiencing a problem, contact HP to replace the power supply for your product. Solution six: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product.
Nov 25, 2009 | HP OfficeJet 7410 All-In-One InkJet...
I put a code on black berry storm and i z=went to
I think that putting different incorrect codes must have completely locked your phone for security reasons. You have to thus change your software and get a new one for your phone. Thank You.
Aug 14, 2009 | Cell Phones
Black Berry Storm Surepress Off
I have the following setup on mine:
Click on Options Click Screen/Keyboard Scroll Down where it says Portrait view, Full keybard. The other options are multitap, and suretype
the other location affects all other screens as well. go to Memopad Use the blackberr menu button Choose Enable full keyboard.
These should help you achieve results
Apr 26, 2009 | RIM BlackBerry Storm 9530 Smartphone
RIM BlackBerry Storm 9530 Smartphone Logo
733 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
