How to access menu on an LXI TV without a remote
Hi, I had a Series LXI TV given to me last week, and I do not have a remote for it, nor the money to buy one right now. I'm needing to access the menu so that can scan for my cable channels.... however, the only buttons other than the "ch.& vol." Buttons, are "picture" and "Audio" please help
snakehead
  • 1074 Answers
SOURCE: Is there a way to access the T.V. menu without a remote?
YES YOU HAVE TO PRESS THE CHANNEL UP AND VOLUME UP TOGETHER OR THE CHANNEL DOWN AND VOLUME TOGETHER.THEN THE MENU WILL APPEAR AND DO WHAT YOU WANT TO AFTER,GOOD LUCK
Posted on Mar 26, 2007
  • 1694 Answers
1) Check for add / erase recessed buttons on set
2) Or consider buying a Sony universal remote for ten bucks
For further help,please supply model number from back of set
........................T.
Posted on Dec 08, 2007
MikeMaierTV
  • 206 Answers
SOURCE: Magnavox TV accessing menu without remote
There may be away but need the model number to narrow it down, most remotes can be found at www.vancebaldwin.com and for usaly under $20.00
Posted on Feb 13, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony TV channel stuck on 56 I need it on channel 3
Doesn't Channel + & - button work?
Let me know to guide you more.
Posted on Oct 27, 2008
SOURCE: AV input selection without a remote
I had the same problem. I hooked up the DVD player and then got into the set up. I used the add/erase feature to go through all of the channels. At channel 91, I saw the logo for the dvd player. I added that channel and now the dvd player works.
Posted on Mar 13, 2009
How do I access the menu from the tv touch panel as the remote isn't working
Hi Susan,
There is a menu button in almost every tv's touch panel. Please press it to access the menu.
Unfortunately if your TV does not have a menu button, there is no way you can access the menu without a remote control.
Jun 30, 2015 | Televison & Video
Very old tv don't know name need code for vizio vz043 DC20110304
Check these Vizio codes. 0034,0019,0082,0091,0000. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 15, 2013 | Televison & Video
Could someone please tell me who carry the series lxi tv
I have a 94 LXI, and my set has Sears on the back. I don't think they still do. (if that's what you mean by 'carry the series').
May 21, 2010 | Televison & Video
Will a remote work with this tv?
A universal remote will most likely work at least the most needed features. When shopping for a universal remote, look on the back of the package for a skeleton list of models to see if LXI is covered.
Jun 14, 2009 | Televison & Video
No remote on LXI series TV
I PURCHASE FROM A TV FROM A SALE AND I CAN'T HOOK UP THE DVD PLAYER AND I DON'T HAVE A REMOTE. THE OPT ARE CABLE AND AIR AND NOTHING WORKS WHEN I SWITCH IT OVER LIKE MY OTHER TV HELP.
Jul 31, 2008 | Rio Go Video DDV9475 Dual Deck VCR
Lxi television
I am looking for how to change my tv into video mode without the remote and found an answer for your problems....
http://www.howtomendit.com/answers.php?id=4239
Aug 30, 2007 | Televison & Video
RE; Remote control TV/AV button doesn't work LXI series
Hi, Based on your post/description: 1. the TV is stuck to A/V; 2. you have two video sources - VHS & DVD (assuming both are external and both have A/V outputs with the VCR also with inputs); 3. you want to use either VHS & DVD, one at a time. You can do it the old fashion way, remove yellow, red, white RCA connectors from DVD and plug them at the outputs of the VHS when you want to use the VCR; or Connect the A/V outputs of the DVD to the inputs of the VCR, connect the outputs of the VCR to the A/V inputs of the LXI TV. Hopes this give you an idea. Post back how things are or should you need further information. Good luck and kind regards.
Aug 23, 2007 | Rio Go Video DDV9475 Dual Deck VCR
Crazy menu, comes on periodically without using remote
believe it or noT: try replacing all of the switches on the control panel (((power button switch,menu button switch, etc...)))
Oct 27, 2006 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
