Question about Rio Carbon MP3 Player
Broken power button
The button to power up my unit broke. It just sunk in when I pressed it to power it on. It is still in there. It still turns on when I plug it in the usb port. I opened up the unit, but I really don't know what to do. Any suggestions???
  • Anonymous Dec 01, 2007
    Same problem.... having a frustrating time with my Carbon... But, mine won't respond, battery is dead... won't charge.
  • Anonymous Feb 29, 2008
    The button to power up my ce2100 series broke. It just sunk in when I pressed it to power it on. It is still in there. It still turns on when I plug it in the usb port.
Use the reset button locate on the top
Posted on Nov 19, 2007
I need a code for an unbranded remote that is a substitute for an Hitachi RAR-22Z remote (broken) The A/C model is RAS-5242
Turn the unit on. continue pressing the power button until it turns off. press set. (Each press of the power button sends a different signal)
Dec 13, 2014 | Hitachi Heating & Cooling
My power button broke to my mitsubishi hd 1080 and I lost the remote control is there any other way to turn it on?
is the button pysically broke... the unit does have a keyboard lockout feature press and hold menu for 10 seconds... maybe if not then the power button will need repair or a universal remote may be used
Oct 14, 2010 | Mitsubishi WS-65315 65" Rear Projection...
Plastic ruhlatec strip broken
Hi thereThis is only some thing you can try it may work.
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says “System Configuration Menu”. 2. Press and release the “OK” button.
5. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
6. Press and release the “OK” button.
7. Display should say “Hardware failure status: Clear. Press OK to clear”.
8. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
9. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Solution 2:
1. Press the On button to turn the printer off.
2. Unplug the power cord from the back of the printer.
3. Remove all the ink cartridges.
4. Wait two minutes.
5. Plug the power cord into the back of the printer.
6. Press the On button to turn the printer on.
7. Install the ink cartridges when prompted.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 11, 2010 | Canon PIXMA MX310 All-In-One Printer
I cannot start my laptop by pressing the power button anymore. Over the months of use the button sunk a little and I had difficulty starting the laptop in the past, although after pressing at different...
on most HP laptops there is a little notch on the power panel on the right hand side (panel directly below your screen) you will need a small flat head screwdriver to pry it open, on some models it is easier to pry it up where the screen hinges are, after you get it open you should be able to access your power button to see if it has "sunk" into its place on the panel, as for raising it back up i dont suggest you try, try putting something behind the button on the panel you just removed like a small piece of paper or what ever you find, just nothing metal as this might cause a short, hope this helps
Jan 08, 2010 | HP Pavilion zd8000 Notebook
Cant turn monitor back on
broken power switch... .. the "friend" broke the power switch by pressing too hard or as luck had it the switch is broken..
recommend leaving the monitor unplugged for 4 hours
open the case of the monitor up and pull the small circuit board for the "buttons" out and get a replacement board... google the part number exactly as spelled out on the little button board
Sep 28, 2009 | Computers & Internet
The power button is broken and jammed. change it , everything will work fine.
Jul 24, 2009 | HTC PPC-6800 Smartphone
Tomtom 910 power problem
It is very small - a pinhole. Use a paperclip to press the button which is sunk inside the small hole.
Jun 27, 2009 | Tomtom GO 910
On/Off switch will not turn unit on..sunk in
that unit may have the locks open it by screw driver check the power at cord then insert and check ac voltage at fuse if present then check after fuse if not then replace it then check dc voltage across big capacitor if not then check 4 diodes if faulty replace it if dc volt is very low then replace capacitor problem may solved
Oct 23, 2008 | Computers & Internet
Why won't my GPS shut off when I press the on off button?
Alot of the times the place where the button should be making contact with the contacts on the circuit board, don't. I would open the unit up and ensure the ends of the plastic power button aren't broke. ie. you can feel them press in when you press them manually without the plastic button.
Another way to turn your unit off is to press the Repeat button (on top) + Enter + Cancel at the same time.
Oct 18, 2008 | Magellan RoadMate 700 GPS Receiver
Rio Carbon MP3 Player Logo
83 people viewed this question
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
