Question about Nordic Track NordicTrack A2550 PRO Treadmill
The speed does not work properly. it is set at 4
Heater blower does not work on settings 1 2 and 3 but does work on setting 4 do you know why?
Bad ignition switch. Speeds 1,2,&3 go thru switch. Speed 4 does not and will work all the time provided fuse and motor is good. Your AC will not work either on speed other than 4.
Dec 03, 2015 | Cars & Trucks
Husqvarna 445 starts and stops running
check carb settings. turn low speed adjusting screw all the way in then turn it out about 1 1/4 turns out. repeat with high speed screw. when running readjust low speed until proper idle and high speed for proper high rpm .
Nov 24, 2013 | Garden
I have a KM800 and the speed setting doesn't work properly, on slow it will go fast then slow and doesn't speed up and slow down as it should. is this repairable, as it's bloody annoying when you disa
Hi Emma,
Not going to be much help here to be honest. We have the KM020 and this is the only problem we have had with heavy machine use in 4 years - and a minor issue at that.
This place is good for spare parts http://www.buyspares.co.uk/
If you're in the UK, you can call this number 02392 392 333 and give them your post code, they'll let you know who the local service agent is.
All the best,
Dec 17, 2011 | Kenwood KM800 Major Classic Stand Mixer
Hi, I own a Pulsar 150 DTSi (2007). I want to know the correct/most effective technique for setting the idling speed and carburetor volume control screw setting. I have already read many articles on the...
First and formost make sure air filter is clean.Then start bike and warm up engine.with engine warm adjust idle screw(the big screw with spring around it)Turn clockwise to increase and counterclock wise to decrease.with bike idling properly the low speed air adjustment screw (small screw located just above fuel bowl on side of carb)Adjust in small increments 1/16 turns at a time till bike has smooth throttle responce.This screw contols air flow during idle and up to 1/4 throttle.From 1/4 throttle and up the needle setting on plunger inside of carb takes care of 1/4 and up.You usally dont have to mess with needle unless you do upgrades to get more power out of bike.But over time the low speed settings can change due to wear on idle needle and air needle.So thats why you have to make adjustments.If bike still dosent respond or idle correctly I would purchase carb rebuild kit and your problem will be solved.
Mar 21, 2011 | 2007 Bajaj Pulsar 150
High speed setting of fan does not work
If your motor only works on low speed and not on high speed first check to see if you have the proper voltage to high speed. Check with a voltmeter or multimeter, check from common on the motor to high speed on the motor at the switch. If you have the proper voltage then you have an open winding on high speed and the motor needs replaced. If you don’t have the proper voltage or any volts, then the switch is bad and needs replaced. This also will be the same if, medium speed won’t work and low speed does.
May 29, 2010 | Kenmore 72115 Air Conditioner
1 set of 4 jets won't work properly?Jacuzzi 6 place tub any solutions?
check the face of the jet trim to make sure it is turned on. most jets today turn clockwise and counter clockwise to turn the water on/off on each jet.
Feb 27, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Jeep TJ Heater Fan Repair
blower motor resister has burnt out also check wiring going to your blower motor resistor these must have a good tight connection or they will burn if any sighns of being hot change the complete wiring pig tail to your blower resistor
Sep 19, 2009 | 1999 Jeep Wrangler
Heat/ac blower motor works on high. intermittent on other speeds.
Check the blower resistor pack - usually located in the heater air ducting in the blower fan airflow. Check for loose connections and open circuit resistors on the unit.
If speed 4 works always, its unlikely to be the blower motor ground connection.
Aug 10, 2009 | 2004 GMC Canyon
2000 Pontiac Grand Prix interior fan speeds 1-4 not working
Check the ground, the resistors are accully resisnting the Negitive Current.
Jul 28, 2008 | 2002 Pontiac Grand Prix
Smc2804wbr barricade G
Check the network settings on the computer connecting to this ports (speed, half or full duplex, etc)
Aug 03, 2007 | SMC Barricade g SMC2804WBRP-G Wireless...
Nordic Track NordicTrack A2550 PRO Treadmill Logo
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
