Question about Mitsubishi VS-50705 50" Rear Projection Television
I have a mitsubishi rear projection tv vs 50707. The picture scrolls. How do I fix it ? I think it's the pic in pic. Can I bypass this ?
techman
  • 3130 Answers
SOURCE: Mitsubishi VS-5041 (TV turns on but no pic or sound)
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
Posted on Jun 16, 2006
  • 4 Answers
SOURCE: need help repairing Mitsubishi VS 4541 rear projection TV
I have the same type of TV, and I think it has a filed "power rail", as the LED does not burn at all, nor do the heaters of any of the CRT's. When I plug it in, I can hear the relays click in, and hitting the power button will cause the relays to click. Other than this, there is no sign of life from this TV. I really would like to find a repair manual or a schematic to aid in troubleshooting. The self-diag trick may be handy if the LED would come on. I'll try it and see what it does.
Posted on Sep 09, 2007
SOURCE: Mitsubishi VS-60609 50in. Rear Projection
Hi did you find a solution my 60 " tv has a similar issue.. the green light stays on but nothing.. please help
Posted on Oct 09, 2007
SOURCE: Mitsubishi VS-50707 shuts down sporadically
what if the pic doesnt stay on long enough to run the test? Mine doesn't stay on more then 15 seconds before it powers off. This happens everytime now.
HELP and THANKS
Posted on Apr 07, 2008
SOURCE: mitsubishi model vs-5043
I just had this same exact problem. I looked for an answer on here and could not find one. So I took the back off, vacuumed and cleaned everything out with the hose on my house vacuum, cleaned the bulbs and wiggled them around some. Voila !!!! lights on and all is working fine and better then ever. I hope this helps someone fix their problem. Just saved me tons of money and a morning of hassle.
Posted on May 06, 2008
I have a Mitsubishi 50" Big Screen Model VS-50707. When trying to turn it on, it blinks once and clicks, then doesn't turn on. It has been doing this for a while, but eventually would come on and need some...
The picture tubes are warn out or the deflection circuit is failing. The power supply is struggling to fire them up. Takes a lot of power.
Some TV shops have the know how to replace the tubes. About $1000 parts and labor.
Dec 30, 2009 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-50707 screen is jittery when it first turns on
Sounds like the verticle circuit is failing a honest shop will take of this for you around 180-230 if you want to do yourself youll need a iron and some filters and an verticle ic
Sep 26, 2009 | Mitsubishi VS-50707 50" Rear Projection...
Tracking on my tv Mitsubishi 50707 50in
i have the same tv cant fix the tracking .model 50707 mitsibishi
Dec 26, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi vs-55707 or vs-50707????? bouncing horizontal lines weird color
If the picture looks like a 3D then you have a convergence failure.
I would suggest to visually inspect the STK Ics for dry or crystallized solder joints.
IC8C01 - STK392-110
IC8C02 - STK392-110
Dec 11, 2008 | Televison & Video
Mitsubishi vs-50707
The problem could in the 9Volt, and 3 Volt regulator supplies.
Replacing C2P05 (100ufd. @ 16 VDC), and C2P08 (also 100 @ 16 ) might fixed problem. They are located near IC2P01, and IC2P03.
The numbers(C2P05, C2P08) means the place where to find the parts that need to be change.
Apr 29, 2008 | Mitsubishi VS-50707 50" Rear Projection...
you can do a self-diagnosis test by pressing the menu and input/device button on set for 5 sec and see what error code it gives you. Count the blinks followed by a short pause then more blinks. This is the error code.
Mar 10, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi TV
run from it bring to shop you would not sit in front of atrain blowing its horn
Feb 27, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi vs 50707 50 inch projection tv problem
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Dec 15, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-50707 - Scrambled picture
Nov 08, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-50705 50" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
