Question about Gateway Cameras
Cannot open battery card cover on dc-t20 - Gateway Cameras
Sony t20 battery stuck inside
Open the battery cover, shake the Camera and HIT slowly on the hand by putting the battery side down.
Mar 06, 2012 | Sony Cyber-shot DSC-T20 Digital Camera
I have ibm t20 2647 laptop i just install new window and i couldnt find wireless option now ?
Most T20 models did not have wireless built into the computers by default. You may have to add a wireless adapter to your computer. To verify whether or not you have a wireless card, open the middle cover on the back of your computer (with the computer unplugged and the battery removed) ... you should see a small card about the size of a business card next to an even smaller card. If the larger card has two antennae wires connected to it, you have wireless. If not, you don't have built in wireless and will have to use a USB or PC Card adapter.
Sep 06, 2011 | IBM ThinkPad T23 2647 Notebook
The description said it was an underwater camera but once i took it underwater it turned off and will not turn on.
Welcome to FixYa.
Before using the camera in under water, you have to secure that battery cover,card slot cover snd DC IN terminal cover are completely closed to prvent water from getting inside the camera and damaging it. Please note that the camera accessories are not waterproof.
Yes, Sanyo VPC-WH1 High Definition Camcorder is a waterproof camcorder, however you can not used it in all types of water. Below are the Cautions concerning use in water.
* The waterproof properties of the camera apply to fresh water and saltwater only. They do not apply to cleaning substances, chemicals or water from spas.
* Do not immerse in water at a depth greater that 3.0m (9.84ft)
* Do not subject the camera to high-pressure water.
* Do not immerse in water for longer than 60 minutes.
After 60 min. of use in water, allow it to dry for at least 10 min.
* Do not immerse in water that is warmer than 40 degree C.
* Do not open and close the battery cover, card slot cover or DC IN terminal cover with wet hands.
* Do not open and close the battery cover, card slot cover or DC IN terminal cover on the beach or at the poolside.
* Do not jolt the camera while it is immersed in water. doing so may cause the battery cover, card slot cover or DC IN terminal cover to open.
And one more thing that you have to do is to chaged/replaced the waterproof seals every year with new ones. For replacing the seals, please consult your dealer and take note that there is a fee for replacing the waterproof seals.
I hope this information will give you an idea on how to use your camera under water.
Feel free to send us your comments and suggestions.
Thank you for using FixYa.
Apr 06, 2011 | Sanyo VPC-WH1 High Definition Camcorder
Need instructions for dc-t20
If this is a Gateway DC-T20 their documentation and software can be found here -- verify this is the correct manufacturer and item.
http://support.gateway.com/s/camera/7004853/7004853nv.shtml
Dec 18, 2007 | Cameras
Error message: battery cover open. This message appears in the window and will not let me operate camera until problem is resolved. The cover is closed, but the message will not go away. I have re-set...
try closing the battery cover. if you do not know what that is, it is where the sd card and the battery are held. the cover for that is the battery cover. if it is closed, and still not working, make sure its closed all the way, if it is, take it to best buy or circut city or any other electronics store and ask them.
Dec 12, 2007 | Gateway DC-T50 Digital Camera
Maintain all-weather capability
The camera loses its weatherproof capability if the battery compartment cover, connector cover or DC-IN jack cover is open. Make sure that all the covers are closed before using the camera. Wipe any water off the camera before changing the battery or card. If the camera gets splashed, wipe the water off as soon as possible with a dry cloth. Salt-water spray or droplets can cause damage to the camera if the camera is not wiped dry as soon as possible. Do not apply excessive force to or attempt to peel off the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover. If the rubber packing becomes worn or damaged, contact your nearest Olympus service center. If the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover contains dirt or sand, wipe it off before closing the cover. The rechargeable battery and other camera accessories are not weatherproof. Care should be taken when using the accessories.
Sep 01, 2005 | Olympus Stylus Verve S / ?-181 mini S...
All-weather
Sep 01, 2005 | Olympus Stylus Verve / ?-mini Digital...
All-weather capability
The following steps can be taken to maintain the all-weather: Make sure that all the covers are closed before using the camera. The camera loses its all-weather capability if the battery compartment cover, connector cover or DC-IN jack cover is open. Wipe any water off the camera before changing the battery or card. If the camera gets splashed, wipe the water off as soon as possible with a dry cloth. Saltwater spray or droplets can cause damage to the camera if the camera is not wiped dry as soon as possible. Do not apply excessive force to or attempt to peel off the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover. If the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover contains dirt or sand, wipe it off before closing the cover. If the rubber packing becomes worn or damaged, contact the nearest Olympus service center to obtain a replacement part.
Sep 01, 2005 | Olympus Stylus 410 / ? 410 Digital Camera
Maintain all-weather capability of my camera
The camera loses its weatherproof capability if the battery compartment cover, connector cover or DC-IN jack cover is open. Make sure that all the covers are closed before using the camera. •Wipe any water off the camera before changing the battery or card. •If the camera gets splashed, wipe the water off as soon as possible with a dry cloth. Salt water spray or droplets can cause damage to the camera if the camera is not wiped dry as soon as possible. •Do not apply excessive force to or attempt to peel off the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover. •If the rubber packing becomes worn or damaged, contact your nearest Olympus service center. (A charge is made for replacement of parts.) •If the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover contains dirt or sand, wipe it off before closing the cover, otherwise water may get inside the camera. •The rechargeable battery and other camera accessories are not weatherproof. Care should be taken when using the accessories.
Sep 01, 2005 | Olympus Camedia Stylus 300 Digital Camera
Cameras Logo
14 people viewed this question
Top Gateway Cameras Experts
Steve
mohamed salim shaikh
micky dee
Are you a Gateway Camera Expert? Answer questions, earn points and help others
