Question about KitchenAid Professional Hd Stand Mixer Kg25hoxmc - Chrome
Kitchenaid mixer kg25hoxmc wont start
Wont start
3 Suggested Answers
SOURCE: kitchenaid mixer
I have a Kitchen Aid Mixer K45SS. I do not have a manual. What must I do to turn it on? I have moved the lever that said Off to another position and the lock lever is Locked. Please help !
Sincerely,
B. Phipps
Posted on Nov 26, 2008
SOURCE: KitchenAid Artisan KSM150BOB Stand Mixer won't start
It could be very easy. It maybe you have a the brush in the wrong way round or they have simply run out. They are on the sides under the black plastic caps. Although they will fit in the hole any one of 4 ways round, there is a key on one corner which means it will only go in one direction. Use a torch to look into the hole before you put it back in.
They shoud look like this : brush
Posted on Jan 24, 2010
How to fix a Kitchenaid Professional HD Stand Mixer?
Remove the top cover, screws are under the metal trim band with the writing on it. Get a multi meter and follow the power. Where the power stops is a good place to start looking. I think the electric internals consist of a PCB complete and a motor complete. If the motor has a circuit and both field windings are even resistance then you are probably looking at a pcb replacement unless you are an electronics whizz. There may also be an interference suppressor across the mains power supply in some countries, unlikely that will stop it though. Certainly look for any unplugged or broken connections inside from mains cable to pcb.
Feb 04, 2015 | KitchenAid Professional Hd Stand Mixer...
Kitchenaid mixer wont turn on
There are different answers depending upon which model KitchenAid mixer you have. Please be more specific.
Jul 20, 2014 | KitchenAid Food Mixers
How do i change the brushes in my kitchenaid mixer?
Solution for these KitchenAid Stand Mixer Models
  • KitchenAid Stand Mixer Service Manual - K45SS
  • KitchenAid Stand Mixer Service Manual - K5SS
  • KitchenAid Stand Mixer Service Manual - KP50P
  • KitchenAid Stand Mixer Service Manual - KSM50P
  • KitchenAid Stand Mixer Service Manual - KPM5
  • KitchenAid Stand Mixer Service Manual - KPM50
  • KitchenAid Stand Mixer Service Manual - KSM75
  • KitchenAid Stand Mixer Service Manual - KSM90
  • KitchenAid Stand Mixer Service Manual - KSM103
  • KitchenAid Stand Mixer Service Manual - KSM110
  • KitchenAid Stand Mixer Service Manual - KSM150
  • KitchenAid Stand Mixer Service Manual - KSM151
  • KitchenAid Stand Mixer Service Manual - KSM156
  • KitchenAid Stand Mixer Service Manual - KSMC50
Fix KitchenAid Stand Mixer Workshop Service Repair Manual Download
Jun 18, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer wont start
Check for broken wire under back cover. Check operation of switch contacts on black speed control plate. Check carbon brushed under black screw caps on the sides. The brushes are keyed, they only work one way.
Jan 08, 2014 | KitchenAid KSM150PS Artisan Series Stand...
It wont start
Check the carbon brushes under those black screw caps on the side. If not that then look for broken wire under back cover.
Dec 14, 2013 | KitchenAid KSM150PSOB Mixer
Kitchenaid wont start
The possible problems could be in no real order>>>
1. your power outlet in your house
2 the power cord to the mixer broken or shorted
3 the speed control plate inside the mixer needs adjusting or replaced
4 the carbon brushes inside the motor head of the mixer need replaced
5 the armature a motor part
6 the stator a motor part
The first four are easy fixes the last two will require a full tear down. but there are lots of things to test first. let us know.
Feb 22, 2013 | KitchenAid KSM150PS Artisan Series Stand...
The planetary fell off the mixer a few months ago. It has done it a few times since but happens much more often now. When I went to put it back on this time I noticed the that you put it on was very...
The planetary is held in by a push pin. I suspect this is missing. Now the base where the planetary inserts is damaged and allows a wobble. This is very bad since that is molded into the main case of the mixer.
Jul 02, 2012 | KitchenAid Food Mixers
DONT WORK
Hi. Before you get too far, call kitchenaid parts to find out if they still have parts for your mixer. They no longer show a parts list for the KSM90 so your mixer may end up in the trash.
Go to mendingshed.com and select the Kitchenaid products button then select Kitchenaid mixer parts. Near the top of the page locate the button for the free kitchenaid service manual. Download the manual and read about the disassembly and reassembly of your mixer.
This manual does not cover your mixer but is a usefull tool for working on any mixer. Good luck with it.
If this solution has assisted you, please rate it. ricardok45
Apr 18, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
The kitchenaide mixer mixer head wont turn
there must be something in that clean it carefully
Dec 14, 2008 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid mixer
Try replacing the moter brushes,if not its probably ether wiring or in the switch board.
Jun 01, 2008 | KitchenAid K45SS Classic Stand Mixer
KitchenAid Professional Hd Stand Mixer Kg25hoxmc - Chrome Logo
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
