Question about Compaq Evo Notebook N150 Notebook
Beeping on start up
Removed and cleaned ram card but made no differance ,when checking in system it only shows 120mb of ram not 128mb ,If external ram removed system shows 56mb and not 64mb as expected so presume problem is on mother board, Is it possible to change the mother board ram and how.
  • Compaq Master
  • 32,281 Answers
Your motherboard has 64Mb built-in RAM and the video card needs some video RAM and has grabbed 8Mb of RAM which leaves the system with 56Mb of RAM. When you insert a 64Mb RAM module you have a total of 128Mb of which the video has grabbed 8Mb which leaves the system with 120Mb.
You can't change stop the video card from grabbing 8Mb of RAM, the RAM is essential for the video to work.
You can upgrade the RAM by removing the 64Mb RAM module and insert a 128Mb or 256Mb RAM module. You may even be able to insert a 512Mb RAM module if the motherboard will accept it, you need to check the specification of your laptop to see the maximum amount of RAM the laptop can handle.
Posted on May 22, 2009
  • Chris Hingee
    Chris Hingee May 23, 2009
    When you change or upgrade the memory, the computer will notify that the RAM has changed and you need to go into the BIOS configuration to upgrade the BIOS configuration.
Dramm failer
You don't say if you have tested the graphics card! these have ram on them as well. I would remove the graphics card and try a different (but know working ) unit. Hope this helps.
Feb 02, 2012 | MSI P7N SLI Platinum Motherboard
Display not showing
Do you hear the beep of the BIOS, a single beep is good, meaning all systems go? If you start up with no Ram does it beep at you at all? It should!
Try removing the BIOS/CMOS battery for about a minute then replace it in the corect orientation. This sets the BIOS/CMOS to defaults.
If still no joy check all connections, including RAM and Graphics card push it down firmly.
Clean your RAM modules with tissue paper and then test them by inserting them one at a time while alternating slots.
Than check the VGA/DVI cable it tightened all the way.
Your timely rating of this soloution is much appreciated.
Thanks
Nov 01, 2010 | Mercury PVCLE266 Motherboard
Won't boot, has a steady beep sound.
Beep codes denote that there may be problem with your RAM modules inside your computer Cabinet. Remove the cabinet, remove the RAM modules from the slot, clean the dust particles present and replace the RAM back to the slot properly and try restarting your system. Try 5 continuous attempts like this and at any one your system may come alive. The Beep codes may vary among different motherboard vendors. So refer to your system motherboard manual and there the interpretation for different kinds of beep code will be provided.
I hope this is helpful and solves your problem,
Thanks
Feb 20, 2010 | HP Pavilion m7480n (882780389410) PC...
Pc boots but no display. tried a new video card, still wont work. ram or motherboard?
Hi.
To start the troubleshooting,
Do one thing.
Clear the cmos.
To clear the cmos, remove the battery and the cmos jumper. You will see JCC on the mb and it is attached to pin 1&2
You can Short it to pin 2&3 or remove it completely.
Don't forget to remove the power-cord from the power supply while clearing the cmos. together with the cmos bat & jumper.
After that try a different ram and a different vga card.
At times dust get accumulated in the slot that prevent firm contact with the vga slot or the memory bank.
Use a clean paint-brush and blow away the dust on the card, the mem and also the slot in the mb.
Fix it firmly.
try this
If you need further assitance revert back
Good luck
Uttam
Feb 18, 2010 | Computers & Internet
My nvidia gefoce 128mb is showing 64mb now please
well there is a simple solution but i m not sure if u can handle it,,,,
well if you can then remove ur driver for card and then remove the card,
now boot the system with builtin display and run atleast once,
now after that shut down the PC and again reattach the card and boot the system this time install different driver.
i got the same problem but i fixed it as i suggested here.
Good Luck
Feb 14, 2010 | Nvidia GeForce FX5500 128MB DDR AGP Video...
No monitor display
Remove all data cables and external cards and press RAM than try again
Jul 23, 2009 | Computers & Internet
One short beep followed by two short beeps when POST
If you have Award BIOS you have a problem with your video card
Video Card Error - Either re-seat or replace video card
Jul 15, 2009 | Computers & Internet
I started my HP computer today and it starting beeping, the tower and monitor have power to them, but the display isn't showing up on the monitor, it's just black
You need to open the tower and reset the memory sticks still if you get those beeps then try those memory stick one by one or swap the memory stick
Regards
Samson Ved
Dec 03, 2008 | HP Pavilion xl756 (P1358A#888) PC Desktop
Boot beeps
re check all inserted pci cards and all memory, reseat if necassary. Have you recently upgraded anything, if so remove. Continuos beeps can also indicate processor power failure.
Mar 19, 2007 | Soltek SL-65KV2-T Motherboard
Compaq Evo Notebook N150 Notebook Logo
212 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
