Question about Car Audio & Video
Eclipse com 54410
Eclipse car stereo 54410 displays call 800 after disconnecting power
5 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: cd/stereo not working
Hi, The "sec" could probably stand for security lock. It is a feature to discourage car stereo theft but is prooving to be more of an owner's problem when battery dies or are replaced or simply when disconnected for maintenance or whatever. The sad part is you have to get in touch with the original dealer of the car who would probably ask you for registration papers, proof of ownership (deed of sale), VIN, make/model/serial number of the stereo and/or other documents. I know its a bit of inconvenience but there is not other way since they have to check a database and fill in so many data themselves. I just hope the dealer is friendly enough. Good luck and kind regards.
Posted on Aug 06, 2007
SOURCE: cant set the time
you need to hold the display button while you depress the #1 to change the hour up, the #2 for the hour down. The #3 and 4 for the minutes. My 14 year old figured this out for me. Hope it is help full
Posted on Feb 12, 2009
  • 7 Answers
SOURCE: NO security disk for my eclipse 54410 deck....
this worked for me
http://www.automobilitydistribution.com/common/SiteMedia/Eclipse%20Unlock%20procedure%20for%20radio%201999-2000-web.pdf
Posted on Feb 04, 2010
I have a jack that fits w the wrong color wires meaning i need the pinout..power wires layout..?
The easy fix is t buy a wiring harness adapter for your new radio. Walmart sells many, car stereo shop will have more. This keeps you from cutting up your wiring in case you sell the car but keep your radio.
Mar 22, 2016 | Cars & Trucks
I had disconnected the battery on my truck. After reconnecting the battery. The eclipse avn 5435 has a screen that reads "security please insert disc". What disc? I bought this truck about a...
Eclipse radios are set up so the first cd inserted in the cd is used to unlock the radio if power is ever disconnected or the radio is stolen. You are going to have to call eclipse and see if they will unlock the radio for you. If the radio has been reported stolen, chances are they will not help you. You should be able to contact them at their website. If you can get the radio out of the dash, there is a phone number for eclipse on the chassis also.
Jul 31, 2011 | Eclipse Car Audio & Video
Eclipse AVN5504D radio only displays eject cd, eject dvd, open. What is the solution, I dont have the eclipse disc.
plorer Stereo Problem - Ford Forum - Enthusiast Forums for Ford ...
www.fordforum.com > ... > General Ford Forums > General Tech
Nov 5, 2011 - The Eclipse AVN5504D stereo only displays eject cd, eject dvd, open. plus some asian writing at the top which I don't understand sorry.
Japanese navigation toyota,eclipse insert map disk solution ...
www.pakwheels.com > ... > In-Car Entertainment (ICE)
Oct 9, 2012 - 21 posts - ‎16 authors
Despite the radio having all the instructions in Japanese, it has been ... The Eclipse AVN5504D stereo only displays eject cd, eject dvd, eject ... More results from www.pakwheels.com
- avis des utilisateurs [ tradecarview ]
Jun 23, 2011 | Car Audio & Video
Mitsubishi Eclipse Spider Gt-S I cannot figure out how to get the fascia panel and face plate off of the radio to get to the numbers needed to retrieve the radio code. How do I take the panels OFF?
Hi
The stereo in the Eclipse can be removed with nothing more than a Phillips screwdriver
Disconnect the negative battery cable from your Eclipse's battery. Remove the two Phillips screws along the bottom of the radio/climate control trim panel. Lift up the bottom of the trim panel to unlock the lower retaining clips. Work your fingers around the sides of the panel to loosen the other clips and remove the panel. Remove the four Phillips screws holding the stereo in place. Slide the stereo out of the dashboard and disconnect the wiring harness and antenna cable from the back of the device.
Also check this link if it helps:-
http://www.ehow.com/how_5938157_remove-eclipse-car-radio.html
May 04, 2011 | Mitsubishi Car Audio & Video
Eclipse model 54410 car stereo with a model 3650 amplifier. Stereo is turning on and playing for several seconds, then shuts off. Can repeat this over and over. Have any ideas as to why?
the ohms might be wrong the fifth channel on the amp is only capable of 4 ohm load and the lowest on the others is 2 ohm load i think this is what i have read about the amp so far
hope this helps
Feb 24, 2011 | Eclipse EA3532 Car Audio Amplifier
yes, call an authorized Eclipse dealer and pay them $25 to reprogram the head unit.
Jun 15, 2009 | Pioneer DEH-P2900MP CD Receiver...
How can i find the fuse for my clock and stereo display?
had the same problem with my 03 eclipse. check your cigarette lighter fuse. powered on the same circuit. that was my issue
Mar 13, 2009 | 2003 Mitsubishi Eclipse Coupe
Cant set the time
Dec 31, 2008 | Eclipse CD3422 CD Player
Eclipse 54400
the unit is locked up eclipse has a feature called esn or eclipse security network. you use a cd to program a passkey that only the owner knows. then if it is stolen the unit is useless. unless you know the right cd cool huh? if the unit is registered to you they will help you unlock it but if not they wont. cool huh. kinda makes you feel good that even if someone does steal your radio they cant use it.. ever.. eclipse also offers a one year theft guarantee out of the box if you register it with them. cool huh..
Feb 21, 2008 | Eclipse 5440
Car Audio & Video Logo
18 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
