Question about Epson LQ-2180 Matrix Printer
Epson LQ - 2180 TROUBELSHOOTING - Epson LQ-2180 Matrix Printer
  • 110 Answers
SOURCE: lq-2180 continous blinking
Please read through these instructions first and then follow the steps below:
1. Please power the printer OFF.
2. Remove the printer cable from the back of the printer and remove all the paper as well.
3. Hold down the "FONT" and "TEAR OFF" buttons and turn the printer on.
4. Continue holding the "FONT" and "TEAR OFF" buttons down for five (5) seconds and then release both at the same time.
5. Power the printer OFF.
6. Reconnect the printer cable.
7. Reinstall paper and ensure the thickness selector is in the correct position and that the path selector is also correct.
If the situation persists, remove the ribbon and paper and slide the print head back and forth so that it makes contact on both sides forcefully enough to make a loud noise. Reload the ribbon and the paper and try your test again.
Posted on Aug 22, 2008
  • 110 Answers
SOURCE: Epson LQ-2180 continuous printing problem
An Emulation driver will fix everyones problem... Do this:
1. Click on "Start", then "Control Panel" and then "Printers and Faxes".
2. In the left hand column choose the option "Add Printer". The "Add Printer Wizard" comes up, click on "Next".
3. At the "Local or Network Printer" screen choose "Local" and remove the check from "Automatically Detect".
4. Click on "Next".
5. At the "Select Port" screen choose the appropriate port (usually LPT1: recommended printer port).
6. At the install printer software screen choose "Epson" under "Manufacturer" and LQ-1050 for the printer, then click "Next". If you wanted to install the Windows universal driver, choose "generic" under "Manufacturer" and choose "Text Only", then click "Next".
7. At the printer name screen choose "Next".
8. When asked if you would like the printer to be default make the appropriate selections and then click "Next".
9. Finally click on "Finish". You may need your Windows XP installation disk.
SOURCE: EPSON LQ - 2180 paper settings
I HAVE CUSTOME SIZE OF PAPER WHICH IS NOT AVILABLE IN THE PRINTER LIST .WHEN I DEEL WITH WINDOS XP
BUT WHEN DEEL WIHTH WINDOS 98 ITS OK
NO I DONT HAVE WINDOS 98 . MY QUESTION HOW I CAN ADJUST PAPER TO CUSTOM SIZE
Posted on Nov 24, 2008
dana_eng
  • 41 Answers
SOURCE: my printer EPSON LQ-2180 send me an error code "paper out"
Hi Soulen , This link is very interest and useful for your type of printer : http://files.support.epson.com/pdf/lq2180/lq2180pg.pdf
and also for driver open this link : http://www.driverstock.com/Epson-LQ-2180-driver-download/23-26-3157-53410/index.html
Posted on Jan 22, 2009
  • 4 Answers
SOURCE: epson lq-2180 printer pause light continously on
if u use up tractor use down tractor or inverse the operation
coz your problem is in paper sensor in up or down printing
Posted on Feb 20, 2009
Epson lq-2180 printer paper out & pause Indicator continously on
I have epson lq-2180 printer with the following problem: Paper out & pause indicator is continously on when I try to print. The paper is rolling when I push pause button.
Jan 22, 2013 | Epson LQ-2180 Dot Matrix Printer
How to check paper end sensor for epson lq 2180
have to remove all the covers and its located in the paper load tray at the back has a plastci trigger lever and operates the internal switch what happens is the lever wears off or breaks on the end but the switch does go bad itself
Jan 22, 2010 | Epson LQ-2180 Dot Matrix Printer
How to reset password of EPSON LQ-2180 printer
Printer can't have a password, maybe a network password you are referring to? I double checked in the manual for this printer and there is no way to set a password on the printer...
Jun 30, 2009 | Epson LQ-2180 Dot Matrix Printer
I can't install on vista
i have a problem that i can't installing the wipro lq dsi 5235 dot matrix drivers in windows vista os
Apr 12, 2009 | Epson LQ-2180 Dot Matrix Printer
LQ 2180
There is a problem in panel
u need to check panel cable if it is connected properly
if the prob. doesn't be ended then u need to use another panel
Feb 03, 2009 | Epson LQ-2180 Dot Matrix Printer
Epson LQ-2180 Matrix Printer Logo
64 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
