Question about Zanussi FS1255S Front Load Washer
Zanussi fs1255w wont spin
Hi i have a 6 year old fs1255w. last week got a piece of plastic piping stuck in it but managed to get it out through waste pump. the piping broke up and i removed it in 4 pieces. since this incident the spin mode was making an unusual whining noise, now it wont spin at all. am i looking at a new machine or would anyone have a suggestion. thanks in advance
abe
  • 139 Answers
SOURCE: bearing noise
Hi there im the wash docotor. With your zanussis once you have removed the back half of the pannel and the top pannel. you will have to then detach the motor wire plug. then the heater wires and also the there is a sensoer on the side of the drum that also has a wiring connection. Also detactch the earth wires Then here come the tricky part. if you look on the top of the drum you have a rubber pipe connected to it comming from the washer draw detach that its easy. Then you have to dicconect the door seal from the front of the machine by the door (do not dissconect from the seal from the drum as you dont have to . Then disconnect the the drain hose. once this is all done you have to disconnect the legs, from the drum side. these are easily done as the pegs come out easily if you push in the pips from one side you can either knock them out with a hammer but it is best to pull em out with either some long bent nose pliers or gripping em in such a way with a monkey ranch Best way og getting the drum out is once you have done all that is to turn the machine onto its back and lifting the casing off leaving the drum on the floor.
Posted on Oct 10, 2006
SOURCE: zanussi washing machine won't start E10, E40 & E50 at times
It was suggested that the pump had failed and taken out the programmer with it - expensive! Wife wouldn't wait, and bought new machine. Problem almost solved - anyone want an out of order washing machine?
Posted on Feb 04, 2009
  • 193 Answers
SOURCE: will my zanussi 1200 work on flex pipe 5 meters
should be fine as long as the outlet is lest than 5 feet above ground level in theory, but that's an awfully long way for it to pump. i would set it up so that the highest point in the line is as close to the washer as possible( that way the pump won't have to work for it to go the entire way to the waist outlet).
Posted on Aug 14, 2009
  • 215 Answers
SOURCE: How do I install a second hand waher/dryer with limited piping?
1 yes all standard.2 Yes you can get a Y piece. 3 no you will only use water from cold. But you can solve that by going to a good hardware store or B.Q and gettein a self cutting tap for washing machines. You can fit this in just minutes, and do not even need to turn off the water supply. just make sure there is a clean straight piece of pipe to fit it to. 4 yes fit waste pipe to u bend under sink.
Posted on Feb 08, 2010
SOURCE: I have a Zanussi ZWF12070W1 washing machine. It's
Hope I can help.When you press the start button is there a buzzing coming from down by the filter if so Check that there is not something stuck in the filter.You will have to be careful depending on how much water is left in the drum so put some towels down and undo filter slowly or get the machine near a door then release filter out onto a door step.when drained shine a torch up inside filter and see if the little plastic blade on pump can turn but do not try and force it,if you do find anything in there then try it again and check the pockets.If there is still a fault you will have to call out your Engineer.
Good Luck
Posted on May 05, 2010
MY zANUSSI zwh6140P IS LESS THAN A YEAR OLD AND IS JUST OVERFILLING WITH WATER AND WONT DO ANYTHING ELSE
It could be a blockage in a outlet pipe or in the filter or pump. The machine won't advance the program until it knows the water is gone.
Dec 23, 2012 | Zanussi Washing Machines
Washing machine fs1255w does not respond to the programme switch. the end light flashes 9 times, every time
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Aug 07, 2008 | Zanussi Washing Machines
My Zanussi nexus fl881 wont spin. Can you tell me how old this washing machine is and how to fix/whether to get new one?
6/8 years old.....Souynds like new motor brush kit needed. price of parts about £30. plus labour possible 30 mins work to fit..Hope this helps
Apr 01, 2011 | Zanussi F1045W Front Load Washer
I have a Zanussi 1600 Jet System Washing Machine, it has started the cycle and 4 mins into it, an E10 error reads on the display, have turned the machine off, and back on, checked pipes, can see you...
This error code relates to water pressure check that the pipes are not kinked,check the water valves are fully on also check if the little filters in the end of the hoses are cleaned.Make sure that the mains water pressure has not been reduced.There could still be a fault with one of the inlet valves but it is most probably the little gauze filters
Apr 26, 2010 | Zanussi IZ161S Front Load Washer
I have a haier hns1460tve washing machine that is stuck on a spin cycle, no pipes blocked it turns but does not spin and is stuck on nine minutes. can you help me please
I doubt this is if much use to you 3 months down the line, but if anybody else has this problem, we have found that emptying the machine resets it.
Not impressed with this machin at all, though, and the Haier web site is a waste of (cyber) space !!!
Anyway, I hope this helps anybody else who gets this same problem ...
Feb 21, 2010 | Haier Washing Machines
Burning smell and loose drum
If it is really noisey when it spins then this can only mean one thing.... the drum bearing are shot, its a complete strip down job, not an easy job for a beginer. Sorry
Dec 23, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Neff Dishwasher won't drain
I've had this problem a couple of times with my dishwasher. In both cases, the cause was a shard of broken glass that had managed to get past the filters and jam itself underneath the impellor. Hard to see, but easy to fix. First ladle out the water.
Pull off the lower rotor arm, unscrew the filter and take out the filter bowl, tray and cylindrical filter. Get as much water as you can out of the filter cavity.
Then, using a Torx-20 driver, remove the screw holding the impellor cover and lift the cover off. (this is the small bit of plastic at the left end of the filter cavity.) Check whether the impellor can rotate freely by spinning it with your finger several times - if it jams or grinds, then there's probably something jammed under it. (It may seem to be fine at first, so do check thoroughly, as any debris can move around with the water flow and only jam occasionally) You may have to use a cocktail stick or similar to poke out anything that's stuck underneath.
Glass is a particular problem, since it's almost impossible to see when there's any water around (it's easy to cut yourself too!)
Anyway, that's worked twice for me now - and I didn't have to even move the machine out of its cupboard to fix it.
Hope that helps.
Nov 10, 2007 | Dishwashers
Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
Sep 13, 2007 | Washing Machines
Wont clean dishes
Check to see if the Upper and lower spin arms rotate easy .. check to see if there is anything blocking them.. also check the venturi assembly (the tower is in the center of the lower spray arm} As it is what supplies the upper spay arm. let me know if this helps?
Mar 06, 2007 | Zanussi 24 in. DA6141 Built-in Dishwasher
Zanussi FS1255S Front Load Washer Logo
117 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
