Question about DeLonghi Esclusivo Gran Dama EASM6600 Stainless Steel Espresso Machine
Coffee grounds are not being ejected properly
Coffee grounds in the coffee
There are a couple things that could cause that, that I experienced:
1. I found that the water injection needle sometimes gets dirty. Coffee grounds are in it and cause the water to go over the top and wash coffee past the k-cup into your coffee cup.
You can use a paperclip to clean out the needle.
2. There is a whole in the k-cup somewhere or the lid is not properly / or strongly enough glued to the k-cup. The water-pressure then pushes coffee out of those holes around the k-cup into the coffee mug.
3. The plastic insert where you put the k-cup in is dirty itself (I have to clean it every now and then).
4. The coffee in the k-cup is ground so fine that it gets pushed through the whole on the bottom that is being punshed for the water to escape.
Feb 27, 2015 | Keurig B60 Coffee Maker
Why does ground flow from the top of brewer instead of coming through the dispenser?
Buy a new K-cup holder from amazon.com. Its the black cone shaped holder.
Jan 11, 2013 | Keurig B70 Coffee Maker
Need a manual for JWX27
You can find the manual for this coffeemaker directly at the following link (for as long as it lasts): http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-mr-coffee-Site/Sites-mr-coffee-Library/default/v1414150683537/documents/instruction-manuals/JWX27_43_56431310.PDF
With this coffeemaker, you can brew with the cover open. I recommend observing a brew cycle to see if the coffee with floating grounds are overflowing the filter into the strainer basket. If this is the case, inspect the strainer basket's valve to make sure it is not blocked and working properly. Also make sure the pot is fully in place so that the lid aligns properly with the strainer basket to open the valve adequately. Otherwise, the filter and/or the coffee grounds are too fine. I recommend a permanent filter basket (around $5) and course-ground coffee. Both will add to better tasting coffee.
Oct 08, 2012 | Mr. Coffee JWX27 12-Cup Coffee Maker
The brew unit is not tamping the ground coffe properly.
Give the brew unit a good wash,then lube all the moving parts with food grade grease.
If you are able dismantle the brew unit and wash in warm soapy water,this removes coffee and any old lubricant.
Feb 21, 2010 | Gaggia Titanium Espresso Machine
Malfunction 8 On Screen
Likely cause of this is a blocked worm drive. The worm drive takes the coffee in and then, after brewing, ejects the used grounds into the Dump box. Over time, coffee grounds accumulate on the worm drive and eventually jam it. This is Malfunction 8. Machine will need to be stripped and cleaned. Hope this helps.
Feb 16, 2010 | Franke Saphira Espresso & Coffee Maker
Krups 7240 ground coffee not ejected
The best thing you can do is find the receipt and exercise the guarantee. The problem you have is not a simple fix.
Mar 21, 2017 | Krups Small Appliances Espresso Machine
DeLonghi Esclusivo Gran Dama EASM6600 Stainless Steel Espresso Machine Logo
52 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
