Question about HP Compaq (319612-001) for Pavilion ZE4000, ZE4600, Presario 2100 Series Motherboard
Bios shows not hard disk even after putting to Auto and trying User settings
My hp pavillion ze4600 laptop gets a message that media test failure, check cable than no operating system found. When i go into Bios it shows internal hard disk none. I have tried to change to Auto and to user putting in sectors, head etc but it still comes back to hard disk none. can you help?
  • 3505 May 21, 2009
    tried putting in different hard drive still same problem. thanks
  • 53 Answers
This usually means Hard Drive failure, are your connections good? Is this a new drive? If you know you have a drive with os on it then boot files could be damaged. Can you boot with os disk? You can do a repair from the windows disk in recovery mode. reset bios to default values. Last resort before saying maybe the drive controllers on motherboard are bad. Take apart and do good cleaning. This worked believe it or not on a stubborn laptop that I replaced Hard Drive and still was giving me similar errors. Client says computer has been working ever since.
Char S.
Posted on May 21, 2009
    President:
  • 948 Answers
Remove the hard disk and try it in another computer (use an external enclosure with the correct connection type). If the other computer sees your hard disk, you have a motherboard problem on your laptop. If the other computer can't see the disk either you have a bad drive.
If my HP pavillion g4, self test says "hard disk
pjotobey:
The message "Hard Disk Failure" is what is called a "Fatal Error" it means that some component in the hard disk has stopped working for some reason. The hard drive in your machine will have to be replaced.
Mar 16, 2013 | Computers & Internet
Pxe-e61: media test failure, check cable
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. Next - to check if the hard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an USB mass storage device and you cannot open the various folders and files on this drive, then this confirms the hard drive is faulty. Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Sep 22, 2012 | HP Compaq Presario R4000 Notebook
Laptop won'y start up has non-system disk or disk error
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 02, 2012 | HP Computers & Internet
PXE-61: Media Test failure, check cable
Mar 11, 2012 | Toshiba Satellite M45-S269 Notebook
Gateway nv7915u error message i'm getting is pxe-e61 media test failure check cable pxe-m0f exiting broadcom pxe rom no bootable device--insert boot disk and press any key but when i do that nothing...
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Nov 04, 2011 | Gateway NV7915u Notebook
My laptop had a ''smart failure predicted on hard disk 0: toshiba mk4025gas-(pm) Warning: immediately back up your data and replace youre hard disk drive. A failure may be imminent'' what does this...
This means that your laptop's motherboard has detected that the hard drive (where all of your data and operating system live) is operating outside of normal parameters. Hard drives are supposed to read/write/respond within specific parameters. If the drive stops operating within these parameters, it usually means that the drive is failing, and therefore your information should be backed up, and your drive should be replaced. Once you back up your data, you can contact HP support to get the hard drive replaced.
Mar 03, 2010 | HP Computers & Internet
I have a latitude c610 and on start up a message saying media test failure check cable.can any one help.
Press F2 to go into the BIOS and reset it to factory defaults and reboot the laptop. If you still get the same message, go back into the BIOS and see if the hard drive is showing up in there, if it is then that means the OS has corrupt files and you would need to wipe out the drive and restore the laptop back to factory defaults.
If the BIOS doesn't show the hard drive in the BIOS then that means the hard drive is bad and would need to be replaced.
Jan 01, 2010 | Dell Latitude C610 Notebook
GETTING ON MY LAPTP: PXE-E61: Media test failure, check cable
This error message can be caused by a faulty connection to the hard drive or a faulty hard drive or a faulty disk controller.
Go into the BIOS configuration to see if it has detected the hard drive, if it is not detected that is why the laptop won't bootup.
To confirm or check if the hard drive is faulty, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port (you may need assistance from a computer savy friend).
If this computer cannot see this as an external drive then it is faulty. If the computer can see this drive as an external drive and you can open the folders and files on the hard disk then the hard drive is OK and the fault is probably a faulty disk controller on the laptop. A faulty disk controller is part of the motherboard and the only fix is a replacement motherboard. This may not be a cost effective solution and it may be better to put your money towards a new laptop.
Jun 27, 2009 | HP Computers & Internet
Computers & Internet Logo
356 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
