Question about Sharp CV-P10LC Portable Air Conditioner
A244j split system Aircon timer light flashes after a few minutes
My Mitsubishi split aircon stops after a couple of minutes, and green operation light flashes. I have checked filters and timer, both OK. Will turning it off at the main switch board reset things?
your main board more so the pipe sensor connected to it, is defective. if the pipe senor can be changed it will work but in most cases the whole main-board will have to be changed as well.
Feb 07, 2015 | Mitsubishi Heating & Cooling
LG aircon operation flashes blinking light 8 times and then shifts to timer light flashes blinking light 4 times
Sounds like a 48 code. (There is no 84 to my knowledge).
Outdoor unit coil outlet (liquid line) thermistor has disconnected or has shorted out.
call a LICENSED hvac repairman
Apr 21, 2014 | LG LS-L1210CL Mini Split Air Conditioner
Not cooling and shutting off, indicator light flashes
the outdoor indictor light on my lg split comes on after some minutes on the one inside and the cooling has reduced please can any1 tell me what the problem is
Jan 18, 2013 | LG LSC121PMA Split System Air Conditioner
My panasonic ceiling aircon model cs-d24db4h5-1 timer light on and not cold.
is your filter dirty? i could see it stoping if the filters dirty. check the filter and if that is not it take it into a shop or send it in. if it cost's more to fix it just forget about it and get a new one good luck.
Jun 24, 2012 | Panasonic CW-XC104HU Air Conditioner
Aircon runs for a few minutes then shuts down and timer light flashes
when we start the AC indoor working and out door unit compressor working but fan motor not working and indoor timer light blinking
Dec 16, 2010 | Mitsubishi MSZ-A24NA Split System Air...
I have split system aircon model no ese21hra wont
You should change the remote sensor receiver unit on the unit.
Nov 14, 2009 | Heating & Cooling
TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Jun 09, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Timer green light flashing when turned on but aircon isn't workn
reset the unit by disconnecting the power supply for 10 sec. then "on" again and start the unit. If it wont work you need a qualified tech. to solve the problem.Some of your safety device might be defective.
Jan 31, 2009 | Heating & Cooling
Toyo Aircon. Starts perfectly. Runs for approx 5 min and then the yellow "timer" light starts flashing and machine stops working. Green power light on...yellow timer light flashing. When you switch unit...
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck!
Dec 28, 2008 | Toyotomi TIN/TIG-329D Air Conditioner
Sharp CV-P10LC Portable Air Conditioner Logo
13 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
