Question about Epson Office Equipment & Supplies
Red light on Flatbed Printer.
I brought this flat this A3 printer from China using the 1390 epson printer board. I think the XP driver for the epson 1400 xp will work with it. I am not too sure. Anyway the red light is always on and it does not recognized the ink. It has been like this about a year now. I changed the board, the print head, change the continuous ink system and still it does not work. It is from this company http://www.magnetic.com.cn/en/smyx/sbtj/sbjs/pbdyj.php Their technician cannot help me. Will you be able to help me?
  • 624 Answers
SOURCE: Black ink print failure after cartridge replaced
The Edge, -Clean the electrical contacts on the printer where the cartridge connects with alcohol. After it dries clean the same contacts with a regular pink, non-abrasive pencil eraser making sure you remove all the debris when done. -Its also possible there is an air bubble preventing the flow of ink. You can try inserting a full cartridge of ink in the printer and letting it sit overnight then running a nozzle clean job or two. Another alternative if you have a syringe you may want to try gently forcing ink into it. If you?re really desperate you can try drilling a small hole into the cartridge to give gravity feeding a hand. BE WARNED the air hole will let ink flow pretty well and you run the chance of making a mess. Before you pull the cartridge out of the printer make sure you cover the hole with tape so the ink doesn?t make even more mess. -Check the cartridge alignment making sure the contacts are mating to the printer. -If it still doesn?t work I would try cleaning your nozzles. Even though I doubt you have clogged nozzles its worth a try because of the following: If you search the Internet you?ll find that this specific model is know for failing to print some or all colors after about 1 ½ to 2 years of use, even with Epson inks. Most of the posts I?ve seen blame it on clogged nozzles but I suspect a good number of them, like yours, have another explanation for their failure. Ink jet printers use resistors to create heat to create a bubble in the ink to eject it out of the nozzle (Bubble jet) or in the case of Epson, vibrating crystals push ink into and out of the nozzles (piezoelectric). We?ve already cleaned the electrical contacts and cleaned the nozzles so what remain are defective nozzles, short between the nozzle and the controller board or a defective controller board. Since the printer is only worth 1 or 2 hundred dollars repairs at a shop or buying these repair parts can easily exceed ½ its cost. Hope something here works for you, I just recently had to toss a great printer too. Let us know what happens and please don?t forget to rate the posting.
Posted on Jan 20, 2007
SOURCE: epson c43sx does not print
change the cartridge thats simple red light indicating you must change your catridge
Posted on May 16, 2008
frcs68
  • 1605 Answers
SOURCE: Epson C66 red light stays on for ink
The first time you install ink cartridges, the printer must charge its print head for about 90 seconds. Wait until charging finishes (the green power.jpg power light stops flashing) before you turn off the printer, or
it may charge improperly and use excess ink the next time you turn it on. If the printer stops moving or making noise, but the green power.jpg power light is still flashing after 5 minutes, turn off the printer. If the light is still flashing when you turn it back on, contact Epson.
Turn off the printer, then make sure the ink cartridges are inserted completely and the ink cartridge cover is closed completely. Also make sure no packing material remains in the printer. Wait a moment, then turn the printer back on to clear the error.
Posted on Nov 13, 2008
yooperbud
  • 8637 Answers
SOURCE: communication error between Epson Printer and iMac
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
  • 421 Answers
SOURCE: I have no way of changing the ink cartridge in my printer.
Hi, the information you need is here:
http://support.epson-europe.com/onlineguides/en/sc46/index.htm
Just click on the replacing ink cartridges on the left hand side, follow the instructions and pictures there.
Posted on Jan 13, 2010
I bought a epson 1390 flatbed printer but the red light is always on and the computer doesn't recognise the printr. What can I dop
Ba more specific please.I am tehnician of this kind of printers.What type of printer you have?Its produce in China?are 2 led red, bouth are on?
Jan 02, 2014 | Epson Office Equipment & Supplies
Epson 1390 red ink light remains on
we have a r1390 power on carries move laft or when carries home possion than red led balking same time
Aug 25, 2012 | Epson Stylus Office Equipment & Supplies
Error in Epson 1390. both red lights are blinking
we have r1390 when we power on printer carries move left side proper & or when hi come at on home possion then red led blinking
Apr 22, 2011 | Epson Office Equipment & Supplies
Epson 1390 service is required.
download free software resetter epson stylus photo 1390
Jan 10, 2011 | Office Equipment & Supplies
Can we use epson photo 1390 A3size printer as a
if it has scan option you can ....you need a driver ...and connect it with the cable ...but if it is just a printer ..you can not ...
http://www.epson.co.id/epson/drivers/driver_download.htm?dc=1&mode=3&m=false&catid=1&pid=1118
You can download the driver in this link for any of the operating system you use...but I have to tell you that I red some reviws about this ...and its just a small business printer with a wide range of paper to use..but I found nothing about scanning ...
Nov 04, 2009 | Office Equipment & Supplies
You have to reset the printer's counter. Read this link
http://tricks-collections.com/reset-epson-stylus-color-printers/
It also have links on adjustment programs to your printers' model. Just browse down to see the link.
Goodluck
Sep 29, 2009 | Epson Office Equipment & Supplies
Paper jam error
Dear Sir,
I have Epson Stylus-1390 Photo Printer. Problem is when giving photo printing option thru printer driver printer get error is paper jam..
can you give me solution for the same.
thanks
Jan 09, 2009 | Epson Stylus Photo R300 InkJet Printer
20 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
