Question about Kenmore Microwave Ovens
Exhaust fan I have a Kenmore microwave oven mdl# 721.85032111 the fan comes on all by itself
  • 43 Answers
SOURCE: microwave oven exhaust fan
The Intake is gentle. It is not designed to have a great pull of air from the Cook Top.
TEST: Turn Exhaust Fan ON
Hold a sheet of your printer paper up to the INTAKE GRILLE (bottom). Will the sheet of paper stay? Held up only by the suction? If it does, Air Intake is OK.
Posted on Feb 03, 2008
SOURCE: The fan on our Kenmore microwave oven is not working.
My husband took the unit off the wall looked down into the fan and found a dead mouse keeping the fan from spinning. We removed the dead mouse cleaned up the area. Turned on the oven. The fan worked perfectly. Then he rehung the microwave.
Thanks!
Posted on Aug 21, 2009
  • 92 Answers
SOURCE: GE Microwave oven vent fan not working
You are correct the fan motor is either stuck or needs replaced.
There is no way to do this without removing the entire microwave. In case your not familiar with how microwaves work, there is a capacitor that is very large inside and can hold a charge even after it is unplugged for up to 24 hours, please take action to prevent getting shocked.
Posted on Sep 11, 2009
erpaalai
  • 999 Answers
SOURCE: Kenmore Microwave Oven model #401.80082700
Sounds like a bearing is tightening up when it get heated up with use. Then after a cool down period it works normally until using it heats it up again. Eric
Posted on Sep 15, 2009
miket756
  • 2702 Answers
SOURCE: I have an overhead microwave oven/exhaust fan
thats a tipical microwave problem they just pop off like a light bulb, it could be turminal or it could be a fuse, what ever it is dont try to fix it yourself there are over 1000 volts kicking about inside the thing and 1000 volts will kill you out right, call a guy in to fix it, look at it this way,, whats your life worth in £???
Posted on Oct 22, 2009
this needs to be serviced by a qualified repair tech there are voltages inside even after unplugged, these voltages can hurt you
Dec 11, 2015 | Kenmore 30" Microwave Combination...
Microwave fan goes on by itself without burners being on or used
It sounds like you understand that the exhaust fan is SUPPOSED TO come on when the microwave oven gets hot when exposed to the heat of the range below it, since you mentioned that no burners are turned on. So in that case, I'm pretty sure that you have a bad fan thermostat. It's usually located behind the control panel on the bottom (inside bottom) of the microwave floor.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Dec 26, 2014 | Kenmore Microwave Ovens
Microwave fan comes on when plugged in
Could be in one of the micro switches for the door or in the board. Most commonly one of the switches though.
Dec 02, 2014 | Kenmore Microwave Ovens
Have Kenmore microvave and the vent starts on its own
Actually, that's a feature! If you cook much on the range (stove) beneath the microwave, the heat will cause the microwave bottom to heat up quite a bit (just touch it!), and the microwave will turn on it's exhaust fan in an attempt to save itself from burning up. It will shut off in about 15 minutes after you turn off the source of heat.
But if the fan comes on by itself even when the microwave is cool (or at least not hot), then you probably have a defective fan thermostat. This thermostat is located behind the control console on the inside bottom of the microwave.
Aug 27, 2014 | Kenmore Microwave Ovens
I have a Kenmore microwave. The vent will just start on its own and can't shut off
Why won't my kenmore microwave's exhaust fan turn off?
It is more than likely one of the door switches has malfunctioned, or there is a problem with the keypad control board.
Apr 19, 2012 | Kenmore Microwave Ovens
Exhaust fan is running constantly, without even
It could be that the fan button is sticking or a contact has welded itself closed therefore its getting power all the time.
Mar 08, 2010 | Maytag Appliances Over-the-Range Microwave...
Sharp Microwave Oven over stove fan goes on by itself
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
So please post a
NEW question, and please include your brand name and the full model number from the tag in or on the unit, as well as the answers to these questions:
Which fan is it?
The
internal cooling fan, which comes on automatically whenever the unit is microwaving?
Or the hood vent exhaust fan which you can turn on and off manually?
Or the convection fan, if it is a convection model?
When is it coming on?
Is it coming on whenever you cook on the stove top?
Thanks!
Oct 09, 2009 | Sharp R-1870 Convection/Microwave Oven
Sep 15, 2009 | Kenmore 62622 Microwave Oven
Kemore Microwave Hood Combination
I HAVE KENMORE 665/61629 LIGHT STAYS ON. AND DO NOT COOKS. AND THE FAN DOES NOT WORK.
Jan 05, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Microwave Ovens Logo
81 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
