Question about Directed Electronics 479V Remote Gen 2 Responder
Responder manual how to program
Program not responding
Have you considered doing a complete recovery of your operational system, I'am suggesting this because of the fact you have to many program conflicts due to device drivers that are not working properly.
Mar 11, 2012 | Gateway One Computers & Internet
I need the list code for a jvc television
Here are the JVC codes. 012,024,036,037,040,048,051
Programming a Device using Code Search:
Manually turn ON your device (TV, VCR, Cable Box)
Press and "HOLD" CODE SEARCH
Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
Release CODE SEARCH.
Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
Once the device turns off, press and release ENTER.
With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
Find codes for each device and brand below.
Press and "HOLD" CODE SEARCH.
Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
Enter the three digit code from the TV, VCR or Cable Box code lists.
With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
GOOD LUCK!
Oct 17, 2010 | RCA RCU403 Remote Control
Trying to find a tv code for an Apex TV using a RCA universal remote control
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code (apex is not listed for this remote)
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Nov 16, 2009 | Apex Digital AT2002S 20" TV
C++
http://www.cplusplus.com/doc/tutorial/
May 01, 2009 | Computers & Internet
How do i program my remote control rcu703sp and my
1.
2.Manually turn ON your device (TV, VCR, Cable Box)
3.Press and "HOLD" CODE SEARCH
4.Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type
5.Release CODE SEARCH.
6.Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
7.Once the device turns off, press and release ENTER.
8.With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
1.
2.Find codes for each device and brand below.
3.Press and "HOLD" CODE SEARCH.
4.Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable).
5.Enter the three digit code from the TV, VCR or Cable Box code lists.
6.Release CODE SEARCH.
7.With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using
Mar 16, 2009 | RCA Universal Remote Control
Need codes
Unit does not have a manual, but I did find this -
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
Let me know if this works, and if not, I'll keep looking.
Feb 01, 2009 | JVC DR-MV100B DVD Recorder/VCR
Code list forToshiba television is ineffectual
You tried all of the following codes?
018,021,023,071,085,090
Doing as follows
Try this if so
Jan 08, 2009 | RCA RCR311B Remote Control
Hi my name is Christy I need the codes for my remote control model rcr311w r55n7 4747p,how to program the remote to my sonya tv? HELPPPPPP
If you mean Sony .. its 002
Jan 07, 2009 | RCA RCR311B Remote Control
Directed Electronics 479V Remote  Gen 2 Responder Logo
70 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
Tre Elkins
Shehu Pro
Shehu Pro
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
