Question about HP LaserJet 4100n Printer
HP LASERJET 4100N Accessory interface port
It looks like a SVGA Video port on the back of the HP LASERJET 4100N. The manual calls it a "Accessory interface port." What is it? What does it do?
  • admin977 May 27, 2009
    No, sorry that does not answer my question. Franky everything on the printer is a "paper handling accessory." : D
    I was aware of the FIR port, but as you said that looks like a S-Video port. The port that "looks like a serial port" is the one I was referring to, it is not of a "serial conguration" but exactly like a SVGA video port. A monitor cable will plug right in!
    Thanks so much for trying to help me!
  • HP Master
  • 4,338 Answers
The port that looks like a S-Video port is called the Fast infrared (FIR) port.
The port tah looks lik a serial port is an accessory port for optional paper handling accessories.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 21, 2009
  • JDTec
    JDTec May 21, 2009
    The port that looks like a serial port is an accessory port for optional paper handling accessories.(My keyboard malfunctioned.)
  • JDTec
    JDTec May 27, 2009
    My solution is straight out of the User guide in the Unit View section.
    If you go to HP's site and search for your unit, you will see the user manual with this description.
I have a HP Laserjet 4100N with an error code 51.2. What part do I need and is it something I can do myself after receiving the part?
http://www.printertechs.com/printer-troubleshooting/401-51-01-51-1-error-hp-laserjet-4100-laser-scanner-failure
Jun 28, 2016 | HP LaserJet 4100n Printer
How can i fix the 81.0180 EIO 2 ERROR on the hp 4100n printer
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
    NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 28, 2010 | HP LaserJet 4100n Printer
I want to print from my HP Laserjet 4100N tray 2 instead of tray 1. How can I do that?
Do a Configuration Page print out from the printers 'Information Menu'
Perform a paper path test from tray 2;
<Information Menu> , <Item> , <paper path test> , <Select> , use <Value> to select <Input Tray =2> , <Select> x 3 times.
Is the print out correct?
Check the paper size setting for Tray 2 matches the size you are trying to print onto.
Check / Adjust setting in the 'Paper Handling' menu.
Make sure Tray 1 has no paper in it when you send the print Job.
Check your Driver settings in Windows
Dec 22, 2009 | HP LaserJet 4100n Printer
Regular Maintance
200,000 pages is pretty good, most people get around 150 - 170,000. The parts can be ordered from HP here:
http://partsurfer.hp.com/cgi-bin/spi/main
Maintenance kits come with clear instructions and are usually done by the user. At most you will need a crosspoint screwdriver to undo a couple of screws (depends on the model).
Hope this helps, please take a moment to rate this solution. Thanks.
Mar 26, 2009 | HP LaserJet 4100n Printer
50.4 fuser error for hp laserjet 4100n
If unplugging the power cord for 30 minutes does not cure the problem, you have a bad fuser.
Look in the back of the printer for 2 blue levers.
Make sure the fuser is locked in.
Dec 25, 2008 | HP LaserJet 4100n Printer
Hp laserjet 4001n
The cable you need to connect to your pc is a regular parallel cable. It is called, IEEE 1284 Bi-directional Parallel Cable.
If you intend to use the a USB port this is what you need; USB to DB-25. The printer connection of the cable is the same the only diffrence here is the USB female adapter for the pc.
Nov 14, 2008 | HP LaserJet 4100n Printer
HP Laser Jet 4100n Printer
This sounds like the swing plate assembly is starting to wear. It is not a job your average user can complete and It may be worth getting an HP eng to have a look for you.
Ring their technical helpline as their call center tech guys are red hot on diagnosing the issue on the phone.
Jul 03, 2008 | HP LaserJet 4100n Printer
Printer Pauses every few pages, seems to print slower than it shouls
More likely to be Network print spooler issue, check settings on driver.
Nov 09, 2007 | HP LaserJet 4100n Printer
HP LaserJet 4100n Printer Logo
244 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
