Managemylife com Kenmore elite oasis won't drain and makes a rattle sound How to fix it
  • 7 Answers
SOURCE: my kenmore elite oasis runs fine but wont go through spin cycle
Try replacing the motor coupler between the motor and pump three small pieces about 18.00 dollars at sears parts store.
Posted on Feb 04, 2009
e-ware
  • 776 Answers
SOURCE: my kenmore elite oasis washer will not drain or
Washing machines don't drain like a sink, there is a pump inside that pumps the water out at the end of a cycle, usually before the spin cycle starts. If the machine is not draining, there is a problem with the pump. Assuming you have an electric pump, either it is not getting electricity due to a defect in the timer or the wiring, or the pump itself is defective.
I don't know what your powers and abilities are, but if possible you can check for power using a multimeter. The pump will be located in the base of the machine, and will be connected to the outer tub with a hose. Turn the water taps off. Remove the power lead from the pump and cycle the timer by hand to see if power is coming to the lead after the wash cycle. If it is not, the timer is likely defective.
If you are getting power, the pump is defective. Depending on the manufacturer, sometimes you can get a repair kit for the pump, but practically your best bet is to go to an appliance place and get a replacement pump - they are common because pumps and timers are the most common machine failures.
Replacing the pump is usually pretty simple, and involves undoing screws for the most part. Just be aware that even in a machine that drains properly there can be up to a liter of water left in the pumps and hoses.
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
Posted on Oct 22, 2009
jsrock516
  • 5911 Answers
SOURCE: I have coins under my tub in my kenmore elite
DO NOT attempt to turn this washer upside down! The wash tub is suspended by suspension springs and it will dislodge the wash tub from its mounts. The washer also weighs about 200 lbs. Not a bright suggestion.
In addition, if this is an OASIS, no special tools are required to remove the wash tub. It usually involves removing the center cap from the wash plate and loosen the bolt underneath with a socket. You will need to remove the wash tub ring in order to get the wash tub out, however. This is the pastic ring around the top of the wash tub. It simply snaps in place and can be removed by popping the retaining taps free with a screwdriver.
If you hear a rattling noise, I would recommend you check the drain pump first as "titelines" suggested. It is common for items to get lodged in the piump impeller and make noise. Keep in mind...there are TWO pumps on an Oasis. One is a recirc pump. Check them both. If anything has been left in the pump for any significant period of time, it can damage them.
You will need to access them both with the rear panel removed and the wash tilted up so you can access the mounting bolts and screws from underneath. I would STRONGLY recommend you drain all residual water from the wash tub prior to disconnecting any drain hoses. If you own a wet/dry shop vac, this can be accomplished by removing the drain hose from the standpipe and pulling a vacuum on it. This will minimize any mess you may have to clean up later.
If your model number differs from the one you posted this question under, please post back with your correct information. I hope this helps you.
Posted on Nov 30, 2009
TheMobilian
  • 8220 Answers
SOURCE: du error code on a kenmore elite oasis he what
Door unlock failure
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state. See TEST #8, page 14
Posted on Jun 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Oasis Wash Machine Error Code F54
The F54 fault code indicates that the control board senses high motor current.
This can be caused by excessive friction in the spin basket.
With the washer off, open the lid and see if the basket spins freely.
If not, you may need to remove the basket and check for an item stuck between the spin basket and the outer washer tub.
The second and third images show procedures for removing the basket on the Oasis washer depending on whether you have an impeller or agitator in your model.
If the basket spins okay, then you can follow the technical troubleshooting described in the first image.
This may help you determine the cause of your washer problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Removing Tub, Basket, lint filter: http://media.fotki.com/1_p,srfssgbktsdgrrqxgtqsskgwtqkq,vi/rstsfdwbbxwwdskwfgkxrrdqddwqb/1/1303472/5961857/image5139789143943268173img-or.jpg
Removing basket & Hub: http://media.fotki.com/1_p,sqgwstkfwtfwsqwxgtqsskgwtqkq,vi/kbkbfbkgwxbfdtwrdxkrkggrdrw/1/1303472/5961857/image27197img-or.gif
Wiring Diagram: http://media.fotki.com/1_p,srfssgbdfbbkfwsxgtqsskgwtqkq,vi/rstkrrqkkxwrtdkbbrbxbqdswfffs/1/1303472/5961857/image3973684248966800668img-or.jpg
http://media.fotki.com/1_p,wktkgtrtsbsgwfrxgtqsskgwtqkq,vi/wrskkfsfrxwwqgrkddg/1/1303472/5961857/image35809img-or.jpg
Posted on Sep 25, 2010
I have a model 27096 top load kenmore elite oasis he washing machine that keeps flashing code F2 and keeps turning itself on. Help
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore Elite Oasis HE washer model #27092600. It is making a loud noise before and during most of the spin cycle when it is trying to drain. What would cause this. I have had this machine since...
Mine was making a high pitch sound, thought a rock got under drum.... now it stopped yesterday full of water ... and won't spin or drain. What can I do here at home to fix it?
Apr 04, 2010 | Kenmore Oasis HE 27082 Top Load Washer
I need the installation manual for a Kenmore Elite Oasis gas dryer. Specifically I need to know what water line attaches to the dryer (for steam), the hot or the cold?
Hello, Here's the link to view the owners manual and exploded view of the parts for your model. Once there, click on the exact model # you have (it's listed on your dryer's data plate) so you get the right one.
http://www.managemylife.com/mmh/owner_manuals/search?query=kenmore+oasis+elite+dryer+7808
Mar 09, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
Makes a rattling noise inside like coins are stuck in it. Does this on the last spin cycle. Never find any money inside the drum though?
Having some trouble using this webiste. I have the exact same problem with my Kenmore Oasis top-load washer. Were you able to find a solution?
Dec 29, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Oasis HE elite washer Sounds like coins rattling occasionally during spin cycle.
there are coins or small items in the pump. We used a wet dry vacumn to clean it out thru the drain hose.
Oct 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore washer elite top load makes nosise when spining.
If it also tends to walk around, there are pads under tub supports that tend to wear out in this model. They are easily replaced.
Sep 04, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
