Question about Canon PIXMA MG4250 Inkjet Multifunction Printer - Colour - Photo Print
Install the print head
When installing the cartridges i get message on the lcd "Print head not installed, install the print head
komguy
  • 2306 Answers
SOURCE: We keep getting an error message
Yes, you need a new printhead, QY60061-000
around $40.00
Posted on Jul 01, 2009
  • 4088 Answers
SOURCE: Canon MP470: "Print Head is not installed. Install Print Head"
Some printer brands have a cute scheme that reads a "new" cartridge as good, but the refilled one has a small fuse link that is burned out by the printer. Try factory new cartridges. Unplug the printer power for a bit to reset the printer.
Posted on Jul 17, 2009
don_farr
  • 1011 Answers
SOURCE: cartridge problem
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Posted on Nov 19, 2009
  • 284 Answers
SOURCE: The printer won't print. Shows the following
It's mean you should replace a new print head
Posted on May 28, 2010
Testimonial: "Thanks! I had resigned myself to buying the print head. Now, I've got to find the least expensive, I don't want to throw away this printer that has worked so well for me."
SOURCE: I have error message UO52
I have the same problem. turned up 45 min. ago
Posted on Sep 19, 2010
Hi, I refilled cartridge CLI-526M fromCanon Prixma MG5250 and I have the error U130. How can I resolve the error to reprint? Thanks.
FAQ: An Error Message Is Displayed on the LCD
Issue
If an error message is displayed on the LCD, take the corresponding action described below.
Cause
The following ink may have run out. Replacing the ink tank is recommended. U041 Print head is not installed.Install the print head.U051 / The type of print head is incorrect.Install the correct print head.U052 Some ink tanks are not installed in place. U072 / More than one ink tank of the following color is installed. U071 The remaining level of the following ink cannot be correctly detected. Replace the ink tank. U130 The following ink tank cannot be recognized. U043 U140 U150 The following ink has run out. Replace the ink tank. U163 There are no photos in memory card Contact the support center or service center for ink absorber replacement. Press OK to continue printing Ink absorber full. Service required Timeout error has occurred The device may be incompatible. Remove the device and check the manual supplied with the connected device An unsupported USB hub is connected. Remove the hub. B200Printer error has occurred. See the manual **** Printer error has occurred. Turn off power then back on again. If problem persists, see the manual
Jul 06, 2011 | Canon MG5250 Printer
Message on printer says "The
The HP D145 uses a special print head cartridge for each ink cartridge. They are not interchangeable.
Apr 15, 2011 | Office Equipment & Supplies
When I turn the printer on I get a message U051. Print head is not installed. Install the print head. The print heads are installed and I have taken them out and put them back and even changed them and...
It seems that the cartridge is not recognized by the printer. There are two possibilities: the cartridge is faulty or the carriage unit is faulty. Carriage unit is cartridge housing where you used to install the cartridge inside printer.
Please try this first,clean contact area of the cartridge and carriage unit with dry clothe. Sometimes,bad contact cause such problem.
Feb 19, 2011 | Canon PIXMA MP470 All-in-One Printer
The type of print head is incorrect. Install the
yes . put exactly the cartridge that is compatible with your printer , make sure that you are replacing with the one that has the same number on it as that of the previous cartridge
Jul 07, 2010 | Canon Pixma MP500 All-In-One InkJet...
I get error 1401 - print heads not installed (properly). WRONG!
Make sure you removed all the shipping tape from the bottom of the cartridges and that you installed the cartridges in the correct bays.
Oct 06, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Jul 17, 2009 | Canon PIXMA MP470 All-in-One Printer
Nothing will print
5 times The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 / 1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on. This might help
Mar 10, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA MG4250 Inkjet Multifunction Printer - Colour - Photo Print Logo
old marine
old marine
