Question about Standard Furniture City Park Kids Double Dresser & Mirror 4859-4868
Need replacment draw - Standard Furniture City Park Kids Double Dresser & Mirror 4859-4868
Leaking brake line on top of rearend of 95 explorer. Need drawing so I can replace them.
No need for a drawing. Each line is shaped differently and will not fit improperly
Aug 07, 2016 | Cars & Trucks
How to replace dishwasher drawer lid motor
On both sides of the draw you will see two plastic pins .Using some long nose pliers you will need to turn them in order to pull them out. Once you have support the draw and get someone to push the sliders backwards into the dishwasher as you pull the draw forward.
You will need to push the draw to one side and place it on a stable chair or box of some sort. Be aware you will have to leave all the hoses attached .
This will now give you access
Sep 05, 2014 | Fisher and Paykel Dishwashers
1999 chevy surburban fell dead while driving
Look at visor lights are they turning off? You need to do a parasitic draw test to isolate draw. without a meter testing draw its hard to locate source of draw. Dirty battery connections can also not let charge get to battery.
Feb 02, 2013 | 1999 Chevrolet Suburban
1992 gmc pickup keeps blowing heater fuses I replaced the blow motor and it keeps blowing
Have you replaced the blower resistor . some times they can cause the fuse to blow . You may need a muiltmeter to test the current draw on the blower motor circuit. the draw should be less then half of the rated fuse .( 20 amp fues draw is less then 10 amps) You did not say but does the blower work on high only or the lower speeds with out blowing the fuse ? if it does work on low or high with out blowing the fuse i would replace the blower resistor
Mar 06, 2011 | GMC Sierra 1500 Cars & Trucks
Will not get cold. hear a clicking noise from back around compressor
That sound is the sound of death....... The compressor is trying to start but can't and the overload is tripping. May only need a new start capacitor or a 3 in 1 start capacitor which replaces the overload start relay and capacitor. If you have a amp meter you can check the amp draw to see if it is drawing Locked Rotor Amps. Look at the name plate on the compressor and it will give you LRA.and see if it is close to it. Then check it again after you replace the start components and see what it is drawing if it has not started and still drawing high amps then the compressor is locked up and will have to be replaced.
Feb 08, 2011 | Maytag MSD2758GEW
The top drawer will not take in water. The tap symbol flashes. The bottom drawer is working perfectly. I have cleaned and checked it - no obvious obstruction in the drawer.
1 the inlet valve need replacing its bottom of the draw bit tricky to replace it to check it just unclip bottom draw to the side disconect the hose from the inlet top draw valve and turn it on for a sec see if water pumps out make sure you got small bucket if that works finne. 2 its the pump under neath the dish draw thats very tricky took me 1 hour to do
Sep 17, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My Minolta CSPro 5,000 machine shows that there is a paper jam in all areas of the machine. I have checked all locations and there is no paper whatsoever. Is there a way to bypass this? If not, is there a...
replace the roller in the paper draw first, try a different paper draw if that fails replace the paper draw roller as, then have the rollers though out the machine cleaned, get tech to come out and look the machine over very old machine might need maintenance
Sep 14, 2010 | Minolta EP4000/5000 CS/PRO Copier
2002 golf . replaced battery 18 mounths ago now
You need to check if some accessory is drawing power when the car is not running.
About any inexpensive digital multimeter will have a 10 Amp unswitched range. You would need to detach the negative (ground) cable from the battery and put the meter in series with the leads plugged into it to access that range. - Do NOT turn on anything while so connected! It will fry the meter. Normally, there will be a very small amount of current flowing even with everything 'off.' This is normal as there are things still 'on' even though the car isn't running; the ECU will draw a tiny bit, your radio will too and any kind of clock that keeps time will also draw some current.
If you find anything over 1 ampere, you have a problem which must be found as this will drain any normal battery over a two-day period.
One item may have a failed part and cause this; your alternator. It has semiconductor parts in it (normally 6) called diodes and if one has been slightly damaged, it can draw current from the battery with the engine off and not light the warning light on the dashboard.
Good luck-
Sep 28, 2009 | 2001 Volkswagen Golf
LOOKING TO REPLACE BROKEN PART # 355JJ2019A
I was able to get online and go to parts.com and order the part. Figure I am not the only one that has had the draw cover to break. Noted that all of the next generation French door models no longer have that style of draw cover. The idea was good but not very practical.
Jan 03, 2009 | LG LFX25960ST Stainless Steel French Door...
Standard Furniture City Park Kids Double Dresser & Mirror 4859-4868 Logo
61 people viewed this question
Top Standard Furniture Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Standard Furniture Furniture Expert? Answer questions, earn points and help others
