Question about Hoover U5780-900 Windtunnel Cyclonic Bagless UprightVacuum
Noise making a loud noise
Samsung vcu366 making loud noise but picks up
what does the really loud noise sound like? Is it a loud, whining sound? if so, the motor may be getting ready to go out. Also check that the belt isn't stuck-though you would smell burning rubber if that were the case.
Mar 08, 2014 | Samsung Vacuums
Dyson making loud noise
Not sure if this will help but mine sometimes make a loud noise as well and its usually due to hairs stuck UNDER the belt in the motor area. Get some sharp skinny scissors and long skinny pliers and get under that belt, cut the hairs and use the pliers to pull out those hairs. That noise is usually because too much hairs stuck under the thing that turns the belt and the belt cant spin so it makes a lot of noise. When i do this it solves the problem of noise, but eventually hairs will collect in there again and make the noise again so i just take the hairs out again and problem solved.
Dec 14, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
Rainbow motor makes loud noise
Depending on the age of the Rainbow, it could be the bearings. Does the noise happen with just the Rainbow or from the power nozzle?
RainVac
www.rainvac.com
800-523-0510
Mar 10, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Dyson DC17 making loud noise
Hi Liz,
I'm sorry to hear that you're concerned about the noise your DC17 is making. It will be difficult for us to help without hearing the noise, so it's probably best if you get in touch with us directly. One of our Helpline experts will be able to determine the cause of the issue, and will be able to recommend the best course of action.
You can call us free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Oct 27, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuum shaking badly right up to handle and very loud noise
Could be a broker motor retainer. There should be two motor retainers in this model, when one is borken, it causes the unit to
shake and vibrate.
May 13, 2010 | Hoover U5507900 Elite Rewind Bagless...
Makes a loud noise like a grinding noise then smokes comes out and it smells like burning rubber? When I take the (rod) brush off with the belt then run the vacuum there is no more noise? Please help me...
Your belt is worn and stretched and so it is slipping on the motor drive shaft. That is why it is noisy and smells like burning rubber. You simply need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Nov 30, 2009 | Vacuums
Makes a terrible loud noise. It hurts my ears.
time to check your filters
if you bought it used check your hoses also
some people think sunp pump hose is just like vacume hose but man does it whistle (almost enought to pop your ears loud )
Jul 29, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
He dyson is making a very loud grinding noise
The belt that rotates the beater bar may be damaged - call the Dyson helpline for troubleshooting and for a solution to the problem.
Jul 03, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Loud 'drilling' noise from motor area when turned on.
Sounds like bad bushings/bearings in the motor -- need to replace them.
May 27, 2009 | Electrolux Vacuums
Loud noise
When the motor bearings start to go bad, they will make a loud noise. Some motors if a piece broke off of the fan, then it also will make a loud noise. You may have to replace the motor.
Dec 25, 2007 | Westinghouse WST1500 Wired Special Edition...
Hoover U5780-900 Windtunnel Cyclonic Bagless UprightVacuum Logo
81 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
