Question about Dryers
Af mean cabrio dryer - Dryers
SOURCE: error code AF Whirlpool cabrio dryer
I found the answer to the code AF also and it means the air flow is blocked. I checked my dryer vent on the outside and it was clear. However when I removed the dryer duct it was clogged just inside the machine. I had washed and dried a blanket that shed alot!
Posted on Jan 10, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Cabrio Dryer 3 months old
"AF" is a restricted air flow condition. You say you've only had your dryer for 3 months, but have you ever cleaned the ducting? You need to check the lint screen after every load, AND you need to perform routine cleaning of the dryer venting (inside the dryer, as well as the vent line from the dryer to where it exits the house) about every three months. If left in this condition, the dryer heating circuitry will eventually failed and/or you could cause a fire hazard. An easy way to check to see if you have a clog somewhere is to remove the dryer vent hose from the back of the dryer. Run the dryer to see if you have air flow coming from the back of the unit. The air should be about 140 degrees F and forceful. Check to see if the error comes back. If everything runs fine, then you know the problem exists in the vent line between the dryer and where it exits the house. If you still have problems, you will need to unplug the dryer, remove the back panel and inspect the interior for clogs. At least you have a dryer that warns you when the air flow become restricted or blocked. Most dryers will continue to run until they overheat or fail. I hope this information is helpful. Post back with your comments and let me know.
Posted on Jan 27, 2008
SolutionGuy
  • 331 Answers
SOURCE: AF flashing on our Whirpool Cabrio Dryer.
Hi Terry,
AF flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
I suspect it's the vent connecting the dryer to the wall or the vent pipe in the wall to the outside. Without moving your dryer, look behind it to see if the flex duct is crushed or pinched. If it is, it's pinching off your air flow, too. Pull the dryer out straighten or replace the hose (you can get vent hose at Home Depot, Lowes or Ace Hardware) then slide the dryer back being careful to keep it about 8" from the wall (8" is the recommended distance from the back of the dryer to the wall, btw).
If the flex vent is NOT pinched off, then you should call a chimney sweep to come out and clean the vent pipe that's in the wall.
*Note---> If you want to test this diagnosis to verify it, just disconnect the flex hose from the wall and run a load of clothes. The error code should not reappear.
SG
Posted on Mar 27, 2009
SOURCE: what does AF error mean on Cabrio electric dryer
AF on your Cabrio means the Air Flow is being obstructed. Make sure the vent is secure and free of debris at the back of the appliance. Also ensure there is no obstruction where it is vented outside of your home. Lastly, make sure the lint trap is clean. Your dryer will still run normally, but it's best to go through your checklist so no further issues arise.
Posted on Dec 29, 2010
SOURCE: I have a whirlpool electric dryer (cabrio) every
I checked all the obvious things posted throughout the internet about this code on my 5 month old WED7800XL and none of them were the problem. What I found on my dryer was the belt that drives the fan had come off. After further inspection I also noticed that the pulley on the top of the fan was missing. After removing the front panel from the dryer I found the pulley, reinstalled it and the belt, the removed panels and it was fixed.
Also FYI, underneath the electronic panel there is a service manual for the dryer.
Posted on Feb 21, 2011
Dryer not drying-the sceen has af flashing please help..whirlpool cabrio
An "AF" code means there is a low airflow condition and the clothes may not dry properly. To remedy this, check to make sure the lint screen is cleaned off and that there is no blockage in either the vent duct that runs from the dryer to the wall or the vent hood on the exterior of the house.
Thanks for using FixYa.
Sep 17, 2011 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
Whirlpool dryer Cabrio 6 months old. message on screen is "AF" what does that mean?
Code AF means the air flow is blocked.
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Jan 07, 2011 | Dryers
What does AF error mean on Cabrio electric dryer
Dec 21, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
The dryer display for the time is displaying "AF".
"AF" means there is an air flow problem within the venting system. There is either a restriction in the hose, outside vent cover, the front vent, or maybe the lower blower assist isn't rotating.
Nov 13, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
I have a whirlpool cabrio dryer and it is showing AF on the display and it isn't drying. what could be the problem?
AF Error Code for the Whirlpool Cabrio Dryer is a Air Flow problem. Check your dryer vent and the outside exhast vent.
Jan 13, 2010 | Dryers
Cabrio dryer is working but there is a code "AF" blinking, What does this mean?
means air flow sounds like vent that goes outside may be plugged up with lint
Jan 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Hi Terry,
obstructed.
SG
Mar 27, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
af on your cabrio dryer means clean your air filter
Dec 14, 2008 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
Dryers Logo
13 people viewed this question
Top Dryers Experts
