Question about Poulan Snowblower 205cc 8.0 TP Briggs OHV ES 27 PR8P27ES
My puolan pro 96194001002 snow thrower will not throw snow
Huskee snow thrower spout clogs
Before use spray chute/housing with Pam or WD-40
Also push unit faster to move snow through easier.
Feb 24, 2015 | Huskee 21 in. Single-Stage Snow Thrower
Snow blower will not throw snow far
I take it that you have a 2-stage snow blower, that is is has the auger blades and then the 2-stage impeller. The impeller blade is damaged <<OR>> the motor is to small to through the snow far. If you have a 5-horse engine and throwing heavy snow, the snow may not go as far as the light fluffy stuff.
A single stage snow thrower is not designed to throw snow far, just move it over a bit.
Oct 10, 2014 | Garden
My Poland Pro snow thrower will not throw snow
Check the shear pin in the auger shaft
Jan 03, 2014 | Garden
Accidently hit stick in side yard. now wont throw snow. Everything else seems good
blower might still work but gear case that runs auger is shot or you sheared the shear pins in auger
Dec 17, 2013 | Yard Machines 31AS63EE700 208cc Gas 24-in...
Poulan Pro snow thrower PR8P27ES Brand new and unable to pull recoil handle or turn over with electric start. is anyone aware of a safty mechenism.
no known safety- did you assemble anything? if not- return it. if you did asssemble anything- slowly go back thru in reverse and see if you have a bolt in wrong
Dec 14, 2013 | Poulan Pro 27-Inch 208cc LCT Gas Powered...
What is a snow blower?
A snow blower gets rid of snow. There are one stage blowers (called snow throwers) that just throw the snow away. There are also two stage blowers that have one stage where the snow is put into the machine and then a second stage where the snow is blown away.
Jan 16, 2013 | Garden
!332 Snow Thrower will not Start - At full choke
change gas filter and spark plug
Oct 07, 2009 | Garden
Just purchased a Poulan Pro Snow Thrower and on first start after assembly [new gas and 10W30 oil] the engine RPM has a rythemic surges about once a second. When a little choke is applied, the RPM becomes...
i just purchased the poulan pro PR1030ES snow thrower, and the recoil spring is broken, anyone know of a place to buy a new one...can't even get an answer from poulan...did you ever get yours fixed
Oct 01, 2009 | Garden
Poulan Snowblower 205cc 8.0 TP Briggs OHV ES 27 PR8P27ES Logo
60 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
