Question about LG Dryers
Lg true steam dryer noise when turning
Noise when turning
JOE LLAMA
  • 26 Answers
SOURCE: LG ELECTRIC DRYER
Henry, its going to be 1 of 2 things. Check inside your drum, see if the vent in the rear has burning or discoloration around it. If it does, it sounds as if your vent is restricted causing the unit to overheat, so clean/fix/replace the venting and your support pulleys will need to be repalce ie flat spots from overheat. If there is no scoarching marks and you know its not the vent or heat issue, the drum seam may have parted causing the thump as every revolution is made.
Posted on Apr 04, 2008
SOURCE: lg td-c70045e electric dryer power on but not turning
I had the same problem. Replaced the capacitor and now all is ok. Dryer is working 100%. If you hear a humming sound from the motor then it means the capcitor is faulty and does not start the motor properly.
Posted on Jan 10, 2009
dragonsthatk
  • 547 Answers
SOURCE: LG TROMM Gas Dryer has intermittent rattle noise while turning
change the drum rollers
Posted on Feb 18, 2009
SOURCE: Lg Gas dryer Dlg0332w drum making noise
The drum on my DLG0332W was also making noise at the back of the dryer...kind of a thump thump thump as the drum rotated. My dryer is only 4 years old. I got brave, downloaded the service manual and opened up the dryer. I found that the drum's welded seam was starting to separate where the roller wheels were coming into contact with the drum at the back of the dryer. Looks like a new drum is in order.
Posted on Jul 25, 2009
  • 76 Answers
SOURCE: When I turn on my dryer on it gives a rattling/vibrating noise.
There maybe a lot of lont build up in the blower wheel housing. Take off bottom panel and take apart the blower wheel house and check for any lint build up....if it check ok, your drum rollers maybe worn....try checkin the blower wheel housing...hope this helps
Posted on Aug 04, 2009
Making a banging (thumping noise when in use
There is 4 support rollers that the drum run on they are probably worn out causing the thumping
May 10, 2016 | LG 7.3 cu. ft. Electric Steam Dryer, White...
Lg dryer drum makes a scraping noise when turned on, what could it be?
The noise is caused by the drum support rollers that are faulty.
Please supply the machine model number.
Feb 13, 2016 | LG Dryers
What does it mean when my LG true steam dryer has and indicator on that says flow sensor
That might have something to do with the exhaust vent in back of the machine. It could be that it isn't venting properly. Or the other thing it could be is that where the cold water hose is connected to the dryer for the steam could be kinked therefore not allowing sufficient water flow.
Dec 01, 2015 | LG Dryers
Lg true steam heats up but won't steam
What is the make and model number of your unit?
Nov 05, 2012 | LG Dryers
My LG Tromm Dryer is making a horrible squeeking noise when running. I turned the Drum manually to see if I could still hear it and the faster i turned the clearer the noise. Any advice would be greatly...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 12, 2010 | LG DLE5955 Dryer
My LG Dryer steam dryer is making a loud noise with a vibration.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 13, 2010 | LG Dryers
Dryer making sqeaking noise
greetings,
the most likely answer is the belt pulley..the rollers can also make noise,but they usually will make a thump thump noise..remove belt pulley and lubricate and see if this helps
May 17, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
My LG steam dryer was running for a little while and then it made a pop noise like a fuse blew and then that was it! It won't turn on in anyway except for the light inside the dryer, please help.
The popping noise could have been one of a multitude of issues (e.g.: short circuit in wiring, fuse, etc. Contact an appliance service company.
Feb 20, 2010 | LG DLE2514 Electric Dryer
Clunking noise
The clunking noise may be a broken weld on the drum.  Every time it turns and passes through the guide wheel supports, it makes a thunk thunk noise.  You will need to have a qualified LG technician diagnose the problem correctly but that's what it sounds like.
Jun 07, 2008 | LG DLG5988 Stainless Steel Gas Dryer
Dryers Logo
60 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
