Question about Exercise & Fitness
Reebok z7 run treadmill manual - Exercise & Fitness
  • 64 Answers
SOURCE: reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
Posted on Jun 08, 2009
greenspan
  • 1734 Answers
SOURCE: I have just bought a Reebok 3 series treadmill.Do
If manufacturer and google are of no help, ask them. They already found some hard to find Reebok manuals. I guess they have the TR3 for download on their site.
Posted on Aug 23, 2009
maxtreadmill
  • 832 Answers
SOURCE: hello,my reebok i-run treadmill belt is not moving
Usually a spark means you have a problem with either the drive motor or motor controller board became damaged. Unplug unit remove the motor shroud physically inspect the motor and board for any signs of arching then replaced the board. Next use a multi meter to check continuity of the drive motor by removing the red and black leads that attached to the board if a reading is much more than 1.0 to 2.0 ohms then your motor is also damaged need to be replaced.
Posted on May 14, 2010
SOURCE: How do I oil my Reebok i-run treadmill?
I have a problem with my reebok i walk i run treadmill. The belt does not move on the lower speeds and after using it there is a burning smell even though it is working fine once I get past the first two speeds. I have had it 2 years but have never oiled it as I am not sure how and where.
Posted on Sep 24, 2010
  • 5 Answers
SOURCE: Need manual
Here:
http://www.iconservice.com/CustomerService/manualsProductList.do?manufacturer=RB&model=&modelName=&language=&x=8&y=6
Posted on Jan 24, 2011
Need Reebok Z7 maintenance manual
If you wish to get some details about treadmill maintenance ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 19, 2016 | Reebok Exercise & Fitness
Reebok I-run got E5 code on display
A simiar manual (the functions are the same ones, it only changes the carcass)
I-run manual
Just press "search" to find out a motor is failing.
Feb 11, 2015 | Reebok treadmill i-run s
Does the reebok z7 treadmill have connection for an mp3 player
Normally Not, however you can add this device, You must check your owner manual or get ONLINE via chat from your supplier manufacturer for to see the cost + installation.
God bless you
Oct 08, 2012 | Exercise & Fitness
My reebok z7 treadmill wont switch on
1) put some desk lamp in the outlet wall, if lamp is ON the circuit is o.k if NOT c.breaker of fuse are blown or tripped, replace and reset .
2) otherwise, test the power cord for open, and break.
3) test the power switch for defective.
4) reset the c.breaker and test the fuse replace and reset
5) Try again. if the problem persist the problem is around the power supply see the block attached.
God bless you
Sep 05, 2012 | Exercise & Fitness
I have a reebok Z7 treadmill and it's showing err 2 when I switch it on
this happen can be E1 OR E2 whatever because this change from some manufacture to another. This mean:
1) LUBE the deck belt,very well
2) lube the rollers bearing
3) measure the input voltage motor, if there are the motor need repair
4) measure the output voltage board, for input voltage motor, if there ARE not, the board is faulty.
see the block. Try to run the sofware calibration after you fix,
God bless you
Jun 28, 2012 | Reebok Exercise & Fitness
Taking it apart a reedok performance runner
If the treadmill is a Reebok 8050 they have manual for it at iconservice.com. This compamy manufactures a wide variety of treadmills and the only way for sure to find the correct manual because they have the assembly instructions that canbe useful in the disassembly procedure.
Reebok
  • For questions about parts, service, user's manuals or non-working products for Reebok Home Fitness equipment, please call our Reebok Customer Service Department at 1-877-994-4999.
Jun 25, 2010 | Reebok 8050 ES Treadmill
Where can i get a reebok TR3 treadmill user manual
Updated linkhttp://www.iconservice.com/CustomerService/manualsProductManuals.do?model=RETL1600&modelName=REEBOK+RT1000+TREADMILL&version=1&company=11&language=
Oct 25, 2009 | Reebok Rt1000 Treadmill Walking Belt
Exercise & Fitness Logo
155 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
