Question about Whirlpool ED5FHEXMQ Side by Side Refrigerator
Ice maker and water dispencer
The ice maker stopped making ice altogether. I used to be rather slow, now its stopped altogether. As for the water dispencer, it would take about 5 min to get a half glass of water, now nothing comes out. What a pain. I should have kept the old refregerator and continued to make ice the way we used to make it.
  • Whirlpool Master
  • 19,396 Answers
Check the water inlet located at the back of the fridge.
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 21, 2009
ICE MAKER DOES NOT DISPENCE ICE
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
imufo2
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 26, 2011 | General Electric GSH25JFX Side by Side...
I have a Maytag side by side w/ ice and water dispencer. Have been having intermittent problems with unit not dispencing water and not making ice(water not filling in to ice tray)unit is now making ice but...
YOU COULD HAVE A BAD WATER VALVE OR YOUR TANK IS CLOGGED UP AND STOPPING THE WATER FLOW THROUGH THE LINES. MOST MODELS HAVE A TANK IN THE BACK OF THE SHELVES ON THE REFRIGERATOR SIDE DOWN AT THE BOTTOM. IT WILL BE LOCATED BEHIND A PANEL YOU WOULD HAVE TO REMOVE SHELVES AND SCREWS TO GET TO IT BUT FIRST CHECK VALVE SOME SYSTEMS HAVE MULTI VALVES WHERE ON CONTROLS THE ICE MAKER AND THE OTHER ON THE DISPENSER.
Dec 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
No ice
Check whether the water is reaching the ice maker. If something is blocking its way get it cleared. Once it start taking water it should produce ice.
Apr 20, 2010 | Whirlpool GS6NBEXR Side by Side...
Hotpoint refridger ice maker not despencing ice or water
my ice maker stop making ice there is ice cubes in the tray but the ice maker does not dispence the ice
Apr 04, 2010 | Hotpoint HSS25GFP Side by Side...
GE REFRIG
Most likely your water control valve for the icemaker side, you can check the ice maker by filling with water and when freezes and if dumps then the water control valve. Part number WR57X10032
Sea Breeze
Aug 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My refrigertor has stop making ice.
just check if the lever in the ice maker is turned to on or off,because that causes the ice maker to stop making ice
Aug 15, 2009 | Refrigerators
Slow ice maker,poor water dispencer flow
If you used a self piercing saddle valve to hook up to the water supply it is probably the source of your problem. These should never be used. You need to install a drill in type which will increase the water flow and probably never clog.
Apr 10, 2009 | GE PSS26SGRSS Stainless Steel Side by Side...
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Unit stop producing ice
Boss, please read the following articles in the link. www.hometips.com/repair-fix/freezer-ice-maker.html
don't forget to rate me!!
Dec 27, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire side by side ice maker, water and ice dispencer inop
It would depend on the age of the refrigerator whether repair is economical. If the refrigerator is under ten years old repair it. If it is over ten years old you have to consider how much life is remaining for the refrigerator. Burnt smell source must be located because that is the key to your problem. It could be a simple matter of replacing the switch in the door.
Jul 05, 2008 | Refrigerators
Whirlpool ED5FHEXMQ Side by Side Refrigerator Logo
257 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
