Question about Element Televison & Video
Soniq lcd tv wont scan channels
Channels aren't active
4 Suggested Answers
  • 5189 Answers
SOURCE: AOC L24H898 LCD TV
Do you have power surge or failure issues with your electricity? Try plugging your TV into an uninterruptable power supply (UPS) to get line conditioning and the continuous power.
Otherwise, I'd guess there is something else causing memory failures (bad chip or something).
I hope this helps.
Posted on Apr 21, 2010
walesarumi
  • 6993 Answers
SOURCE: Soniq QSP320T drops the channel
Saw your response, does this means that your problem is solved? If not, please let me know so that I may assist you further.
Bye for now.
Posted on Apr 18, 2011
SOURCE: Hello, Well I have a Jensen
I have the same problem with my soniq hd tv i got a digital antenna that plugs into the power and i have also tried the roof antenna and neither worked.. Could it be the tv?
Posted on Mar 13, 2012
How can I Watch Music Channels on Your Roku
Music channels are one of the most watched and heard channels of Roku. These channels telecast music all day long for you entertainment. These music channels are now available on Roku. You could always activate the ABC channel by setting up your Roku Code link. To activate these channels's you need to first activate your Roku device and then get the subscription for the Roku Music Channels.
Steps to Activate Channels
•If you have an online Roku account, go to the Channel Store.
•Select the required music channels.
•Enter the code.
•Activate the channel and go ahead.
If you don't have an online account:
•First generate the Code.
•Register the Roku Code link.
•Create your online user account.
•Then follow the above steps.
Music Channel List:
The following is a list of Music Channels:
•Pandora
• Vevo
• iHeart Radio
• TuneIn Radio
•Baeble Music
•Camer Music
Need to Activate Music Channels?
There might be some errors or some issues at times while activating the Roku device which needs to be rectified by the correct way or else will lead to the unsuccessful activation of the device. To avoid such issues get the best technical support always to activate your device. If you still are wondering upon how to activate this channel on your Roku give a call @1-844-965-4357.
Sep 27, 2017 | Roku Televison & Video
How to put in showtime anytime activate code?
Hi friends
you can try the following steps to activate showtime anytime channel:
Search the SHOWTIME ANYTIME channel in the Streaming Channels list under the Movies and Television category.Now, you can add the SHOWTIME ANYTIME channel to your Roku streaming.
Click on the channel button, and then select the activate.
The screen will show a link code, you can activate showtime anytime channel on deviceif you don't have already login into SHOWTIME ANYTIME channel, then you will need Spectrum username and password.
Once you can connect your Roku account to Showtime channel, A welcome message shown on your screen.
Now, you can access this channel on Roku streaming player.
My name is White Jones, I have faced a similar problem, but I used these steps and my problem is fixed. I get these steps from Roku com link
May 19, 2016 | Cell Phones
How do i disable the child lock
Many Jensen TVs have a parental lock that can be set to stop children from watching certain television shows or channels. In order to activate or deactivate the controls, you have to know the four-digit code or parental lock passcode. If you forget the passcode or if the lock gets set accidentally, you can still unlock the TV.
Turn on the TV using the remote control. In most cases, you will need the original Jensen remote to unlock the TV if you aren't sure of the unlock code. You can purchase an original replacement online if necessary.
• Look at the screen. If you see a red key on the bottom of the screen, press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
• Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
•Call the technical support service number in your owner's manual if neither of those codes work. A technician can help you troubleshoot the television as the problem may not be the parental lock feature. Have the model number and serial number of the TV available when you call.
• Take your television to a TV repair shop if neither of the codes work and the TV locked by itself while it was turned on. In this case, the TV may need to be rewired
Sep 18, 2012 | Jensen TS2750J TV
I am looking for the fuses on an Adcom GFA 7807. The amp has no output on some of the channels.
Fuses aren't channel-specific; it's all on or all dead fuse-wise. Maybe you have dead / improperly connected speakers, source connection issues. Track it back or swap source channels and speakers to isolate.
Jul 24, 2011 | Audio Players & Recorders
Where can I get the full circuit schematic for this mixer?
Contact Peavey support. They will usually email you a schematic. Try phone 601-483-5365 for support. They aren't too clear of a phone for support.
Apr 30, 2011 | Peavey 16FX 16 Channel Mixer
Recently purchased yamaha rx-v665 av receiver, was working fine, but for last 15 days while playing either movies on DVD or any audio, the AUDIO shuts off and the speaker display on the receivers front...
Check to make sure your wires aren't crossing on your speakers or if any of them are loose. Could easily be the cause for knocking out your speakers. That's the easy fix. Other than that it sounds like a computer issue. I'd take it back to where I got it from if it was me and it had only been two weeks.
I am kind of curious, though. Why aren't you using all seven channels? You really shouldn't leave channels open like that.
Apr 27, 2011 | Yamaha RXV665BL Receiver
Whats the process to change RF to channel 4?
1 Press POWER to turn the power off.
2 Press TV/VCR, current VCR Output Channel will appear on the LCD display.
3 Each time TV/VCR is pressed for 2 seconds, the LCD display changes as follow
clock press tv/vcr RF3 2 secondes later RF4.
• VCR Output Channel is automatically set during EZ Set Up.
1. If Channel 3 (or 4) is an active broadcast channel in your area, the Channel 4 (or 3) will be set.
2. If both channel are the active channel or none active channel, the VCR Output Channel will be set to Channel 3.
• Cancelled the EZ Set Up by pressing POWER during EZ Set Up before setting the Output Channel.
• VCR Output Channel will not change to previous VCR Output Channel if TV/VCR is pressed continuosly for more than 2
seconds.
May 27, 2010 | Sharp VC-H965U VHS VCR
Pro-96 ,channels 1 thru 9 are locked out ,only 0 is
You are referring to banks, not channels. When bank 0 is active, then you push 0 to de-activate it, you have now removed all your banks from the scan list. To re-activate any bank, just press any number. This is confusing because locking out a channel and removing a bank from the scan list are two very different operations but use the same terminology.
For more information and some tutorials to help with various functions, visit this site: http://support.radioshack.com/support_tutorials/communications/20-526.htm
Feb 11, 2010 | Radio Shack Pro-96 Scanner
Activation of both RAM channels
if you have your manual please check the gap if you have 4 slots on your motherboard for your ram ushally its the first one on the left skip one slot and put it in the 3rd slot.
Aug 05, 2008 | Intel D102GGC2 Motherboard
Televison & Video Logo
15 people viewed this question
Top Element Televison & Video Experts
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
